- Mute
- Permalink
- Report
I created a template from a past project, and today started a new project. I set the Survey Point based on a CAD linked survey, at 712.0' elevation. I set Project Base Point to 714.3', which will correspond to first floor finish elevation.
When I create a new toposurface for the property, and enter 0'-0" Absolute Elevation (the only option) for the first property corner, it yields a point located at 604.0'. I assume this is a vestige of the past project from which the template was created.
I can't seem to change it. I've tried clipping/unclipping survey point, Moving the Base Point to the internal origin (which puts it at 604.0', directly below where I have it now).
On the grand scale of Revit woes, I admit this is not terrible. I can do some math to set my topo perimeter points (actual value relative to survey point + 108.0' = correctly placed point), my internal topo points can be placed relative to survey point (not an option for the initial topo perimeter points), and my Project Base Point will take care of my levels.
But I'd still like to know how to reset Absolute Elevation to 0, so I won't have to do this every time. Suggestions?
Many thanks.
