A strange question for elevation at top & bottom
wang_yilin
Message 1 of 33
wang_yilin
Recently, we find a strange~
usually we create a new revit model and model a slab on Level 1;
for that slab, it has two parameters named " elevtation at top" " elevation at bottom ", shows in the pic. below~
However!! in one model which we get from another company, it changed, and we don't know the reason..
how does the 2nd situation  happen??
Replies (32)
Message 2 of 33
ennujozlagam
@wang_yilinhello, check the level between the two they are totally different. thanks
Message 3 of 33
What is the elevation of FFE level?
Message 4 of 33
wang_yilin
I know they r different
because they r not the same model~
first snap shows the general situation in Revit
Second snap shows a different situation whose model created by another company~
Message 5 of 33
wang_yilin
forget about that, because they r not the same model~
I just wanna know why would the second situation happen, because it is created by another company, and now I could not ask them for answer~
Message 6 of 33
Forget about what? I am asking you a question in order to understand the issue.
Message 7 of 33
ennujozlagam
it could be your project base point elevation. thanks
Message 8 of 33
wang_yilin
yeah, i agree;
but in which condition may cause this problem~ i don't now, and I wanna know how to modify that correctly
Message 9 of 33
wang_yilin
sorry
what I mean is the two snaps upside are two different model~
the second model is wrong~ and I don't know the reason why could that happen....
Message 10 of 33
Then what is the elevation of the FFE level?  Go to an elevation and post a screenshot.
Message 11 of 33
wang_yilin
u could just consider that FFE. Level as Level 1
Message 12 of 33
I sure would if you posted a screenshot of an elevation showing the level.  Is it that difficult to do?
Message 13 of 33
ennujozlagam
Check between two files, go to levle1 or site plan > go to VG > model categories > site > tick project base point and compare elevation betwen the two files. thanks
Message 14 of 33
wang_yilin
Sir, Elevation View like this, the snaps upsides create in 3D VIEW~
Message 15 of 33
wang_yilin
I have already check the Project base point~ but what makes me feel confused is why it would affect the parameter " elevation at top", I don't know the reason~
Message 16 of 33
Thank you!  Can you share the file?
Message 17 of 33
wang_yilin
thank u~ but I could not have a proper way to share my model~
Message 18 of 33
chrisplyler
Because a Slab's Elevation at Top value is based on the Project Base Point.
So your F.F.E level is 149mm above the Project Base Point.
Level type is probably set to be relative to Survey Point so that's why it reads 0 instead.
Message 19 of 33
Alfredo_Medina
Hello, @wang_yilin , welcome to the forum.
The spot elevation tool has a parameter called "Elevation origin". This can be set to read the elevation from the Project Base Point or from the Survey Point, depending on the preference of the office or project managers.
So, you can have 2 types of Spot Elevations, pointing at the same slab, and both of them can show different elevations.  This is normal, it's not an error.
Suppose I have 2 slabs in the same project, where the project base point has an elevation of 149. Then I tag one slab with the Spot Elevation (Project) type and the other slab with the Spot Elevaton (Survey) type. The results will be as shown in these images. This is the elevation or section view:
And this is the plan view:
Message 20 of 33
wang_yilin
sir, u could see the elevation snap, it shows the F.F.E Level shows 0, not 149
