A line based family in Revit as an egress path
jledgewood409
Message 1 of 13
jledgewood409
i am having trouble with the scheduling. I am familiar with shared parameters. but I cannot figure out how to make the label that is the generic annotation as a shared parameter and have it show up in the schedule?
https://www.youtube.com/watch?v=gqIvwwmQ0ME&lc=z13cellrimvbu1fgl04celxbflf1d3ko5z40k.150275746874494...
I have attached the family, hoping someone can see where I went wrong.
Replies (12)
Message 2 of 13
Sahay_R
Let me share an approach that has worked and I have added to our template -
1) Abandon the family.. You're wasting your time.
2) Create a Railing type.Call it Egress. Use a super tiny profile, maybe make it 6" or so high.
3) Create a railing tag
4) When you need to show egress insert the railing
5) Add the tag
If needed, you can also create a schedule for your Egress paths. Good luck!
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 13
The label in the nested generic annotation family needs to be also a shared parameter, pointing to the same shared parameter as the main family. Right now you have that parameter in the label as a family parameter.
In order for the shared parameter to work across files, they all need to reference the same shared parameter in the same shared parameter text file. This means the project model file, the family file, and the nested family file all need to reference the same shared parameter. If they do that, you should be good.
Also, not sure why the 'Egress Distance Label' is a family type parameter. This does nothing for your family.
IMHO, I know it can be neat to use other tools like railings to "cheat the system", but I only advocate that as a means of last resort. As shown in the YouTube tutorial, you can do what you want without resorting to those kinds of tricks.
Message 4 of 13
Sahay_R
It's a matter of what works. And if 'tricks' help to get the job done quickly and efficiently (even along stairs and ramps) , then that is what matters.
Rina Sahay
Message 5 of 13
Using a railing works easily but you need to introduce extra work to filter it out of other views. It is also a 3d element so it is accounted in Interference checking and IFC export.
It is good to know how to link labels from a generic annotation to a geometry family to project. I don't have Revit for a week so I cannot demonstrate any further than what already said by austin above.
Message 6 of 13
Sahay_R
Thank you for reminding me of this missed step, @ToanDN. The egress railing will need to be filtered out of all views other than Life Safety plans.
You poor thing - you  must be bored out of your skull without Revit!! How did this disaster happen?
Rina Sahay
Message 7 of 13
I am exiled to a tropical island to watch Game of Thrones.
Message 8 of 13
Sahay_R
What agony!
Rina Sahay
Message 9 of 13
amorap
Another "trick" to define egress path I'm using is by property lines.
As railings are used very often in our projects, if you use a railing family to show an egress path, it's needed to do a hard work filtering and cheking all of your revit views.
Then, I prefer property lines, because it are much less used than railings.
You can tag every segment of property line and schedule it in order to get the total lenght. The only issue is that only works in a XY plane, it doesn not work to measure the distance over stairs or ramps.
Yes, its only a trick, I know.
Regards from Spain.
Augusto Mora
Architect & teacher of Building Projects at CPIFP Pirámide. Huesca (Spain).
Revit 2014 certified profesional.
Message 10 of 13
kadmonkee
try this one
you can add whatever Shared Parameter you need to it.
it is a Generic Model category s othe shared Parameter will need to be associated to this.
create a generic tag and assign the shared parameter to the category Generic Model.
as long as the Shared Parameter is in both the family and the Tag it should work for you
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 11 of 13
Viveka_CD
Hi @jledgewood409
I just wanted to follow up here, any progress on this issue?
Please mark any posts that help with "Accept as Solution" and thanks!
Message 12 of 13
jledgewood409
sorry for the delay in response. I have been caught up in projects and haven't had time to test the suggestions. hopefully I will have time in the next couple of weeks.
Message 13 of 13
Viveka_CD
