A group has been changed outside edit mode
While deleting cell hole in Rolled section
An error is "A group has been changed outside edit mode"
Attached error snap
appreciate your help
-RK
Diego.Faria
What's your doubt?
The error message explains pretty much everything you want to know.
If you don't want to see that next time you make an edit, select your group and use the "Edit Group" command before changing it. Revit will enter in a special mode that only allows changes to this specific group.
Diego Faria
LinkedIn
Sahay_R
Select, ungroup and delete the group in question. That will make Revit stop complaining.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Thanks for your reply.
-RK
-Rk.
