6"x48" double herringbone .pat file help
Message 1 of 12
Could anyone help me figure out the code for this pattern? I got the single herringbone .pat code to work from that post, but I don't know how to determine a code for this pattern.
Replies (11)
Message 2 of 12
Sahay_R
Can you share the .pat file?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 12
This is what I used for the plain herringbone from a previous forum post (it's technically a 4"x48")
*HerringBone 48x4, brick herringbone
;%TYPE=MODEL
45, 0,0, 4,4, 52,-44
135, 2.828427124,2.828427124, 4,-4, 52,-44
Message 4 of 12
Code? Do you mean the pattern definition? It's in the .pat file you received. Rename it with a .txt extension and open it in notebook.
...I see your followup post. What is it that your're looking for?
...Oh, I think I see: You want to scale it. Correct?
Message 5 of 12
Sahay_R
Try this.
45, 0,0, 4,4,4, 12,-4,-4
135, 2.828427125, 2.828427125, 2.828427125, 4, -4, -4, 12, -4, -4
Apologies - our servers are down so I cannot test this. Paste into a notepad file, save it with the .pat extension.
Rina Sahay
Message 6 of 12
You can create you own using HatchKit add-in for Revit.
Message 7 of 12
Sahay_R
I would if I had internet connectivity!!!! GRRR!!
Rina Sahay
Message 8 of 12
@barthbradley
He wants this:
Message 9 of 12
Thanks Toan. I was a little confused by "CODE" and I wasn't able to open his jpg initially. I can see it now.  I agree that HatchKit could certainly do it, but I'm surprised this isn't available on-line. It looks fairly common.
Message 10 of 12
Yes! That's what I need Toan.  I looked online and couldn't find the pattern definition (apparently it's not called code ;-P) online.  I don't understand how to establish the definition.  But if I found where someone else had done that I CAN copy/paste/format the text into the .pat file. (Thank you YouTube!)
I'm not sure my network guards will let me install an add-in....
Message 11 of 12
does this help you?: https://www.revitcity.com/forums.php?action=viewthread&thread_id=35129. @PijPiwo provides a definition here.
Message 12 of 12
hugha
HatchKit has a brick and tile generator that handles multi-weave herringbone arrangements:
try this:
;        Written by HatchKit Professional
;        HatchKit Professional (c)1990-2016 Cadro Pty Ltd
;        www.hatchkit.com.au/
;-Date                                   : 2017-04-25
;-Time                                   : 1:50:17 PM
;-HatchKit Version                       : 3.1.9.2674
;-HatchKit Output Filetype               : Revit with HatchKit Add-In
;%VERSION=3.0
;%UNITS=INCH
*6by48,LEFT-HAND 48"x6" weave=2/2
;%TYPE=DRAFTING
90,-48,0,12,-12,60,-36
180,0,0,12,12,60,-36
90,-54,0,12,-12,48,-48
180,0,6,12,12,48,-48
Hugh Adamson
Cadro Pty Ltd
