45 Degree Door
45 Degree Door
tstewart
45 Degree Door
tstewart
How to make an existing door drawn as 45 degree?
See attached as an example.
tstewart
Where are the Properties menu to change it to 45? Everything is greyed out and when I put your 45 Door Family into my dwg., it converts to 90.
tstewart
It worked!
syman2000
If you on Revit 2022 or above, you load the default Autodesk family
When you add the door, you should be able to adjust swing angle
tstewart
Excellent & thank you.
