3D waterslide
3D waterslide
3D waterslide
Does anybody know how to create a 3D waterslide?
syman2000
It really depends what you want. I usually go with manufacturer default objects
https://www.bimobject.com/en-us/sr-smith/product/577-022
ennujozlagam
you can also check HERE. thanks
constantin.stroescu
I understood you want to know how to make a water slider.
If so , then I suggest to:
  • use an Adaptive Points Family (Generic Model Adaptive) - more Adaptive Points allows a more complex water slider. Create a Path by using Spline through Points (Reference Line) and a Profile placed on a normal plane to Path of a Hosted Point (hosted by the spline). Create the Form - a Spline.
  • Load the Family into a Project or Mass family .
  • In Mass Editor create a curved surface - vertical Extrusion or a tapered surface, to be used as guide for the path of the water slider. Use UV Grids with Activate Nodes to be used as snap points.
  • Place the Adaptive Point Family
https://knowledge.autodesk.com/community/screencast/6358e2de-30cd-4eb2-ba07-3bb48c66278e
Constantin Stroescu
Sure! What are you thinking? "Tropical", "Reflecting", "Swimming" or something else?
"Bubbles" is our most popular model. But, if you order within the next ten minutes, I will upgrade you to "Clear Lake" at no extra charge.
constantin.stroescu
and for a tubular water slider
  • by combining Solid Form Sweep with a Void Sweep:
https://knowledge.autodesk.com/community/screencast/b9bf1ca1-3824-43b3-82c2-0c14ca4dbcdd
Constantin Stroescu
