is there a way to show where a 3D View (camera) is taken from in plan for presentation
Solved by Revit_Whisperer. Go to Solution.
Go to a plan view, then on the project browser, find the 3d view that you want to see the placement of the camera, right click on it and select Show Camera...it will show you the camera location in the plan view
Depending on if the view is a default 3d view or a camera view the icon looks a bit different in plan view.
that I know. I was thinking of more along the lines like an elevation tag but for camera locations.
Hi, htews,
You can suggest it as an idea.
Cheers,
Hi, htews,
Cheers,
Hello @htews
Thank you for posting! An elevation tag for camera location would be great!
I encourgae you to submit your idea and comments specific to the software or its functionality for future consideration.
Please submit your comments at the Product Feedback page.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Hello @htews
Viveka CD
