3D view shows transparency in any model display style
marcbartolucci
Message 1 of 9
marcbartolucci
My model shows transparency regardless of the model display style  (see attached snip).
I tried all of the different styles, the walls have materials assigned to them, transparency is set to 0.... What else could cause this?
Replies (8)
Message 2 of 9
WEC17
Upload you model to have a better idea.
Message 3 of 9
mauricio_mssf
Simply delete this 3D view in your project browser and create a new one (view -> 3d view) and the bug will disappear.
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and let a like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Message 4 of 9
syman2000
Your eye elevation and target elevation may encounter huge value. Typically I would use the viewcube to reset it back
When you use viewcube, it will change back to proper eye & target elevation.
Message 5 of 9
Message 6 of 9
Turn off CAD links.
Message 7 of 9
s.borello
It's a bug... delete your 3d view and recreate it and you will be good to go.
Message 8 of 9
lmpka
Can't tell without seeing your settings, but do you have links turned on, and are they set to "Underlay"?  If so, turn off the underlay option for your links.
Message 9 of 9
Kennedy250527
Community Visitor
Community Visitor
I have a similar problem. This is for a school project
