3D View orientation - can it be changed?
donnia.tabor-hanson
donnia.tabor-hanson
So they have their project on True North but want the 3D view to come in by Project North not True North so they can take advantage of the View Cuge with Front, Right, etc and it look orthogonal.
Can this be done?
Donnia
#AutodeskExpertElite #CADMama
Thanks y'all,
Donnia Tabor
CADMama and Revit Family Counselor
Twitter @DonniaTH
LinkedIn
Can this be done?
Donnia
In a 3D top view, the red arrow should be Project North, letter N is True North.  Did you rotate project North?
Here is an example of my project
donnia.tabor-hanson
They can get the plan views oriented just fine. They want the 3D view to be squared up so that the "Front" of the view cube will take them square on one side and not on a corner which it shows now.
This is strictly about the 3D view.
Thanks y'all,
Donnia Tabor
Twitter @DonniaTH
LinkedIn
What I show you is a 3D top view.
donnia.tabor-hanson
Yes, and the plan is skewed so that if you go to the cube "Front" view, you would see the prominent souther corner of the building and the two side off that corner. They would like to see perpendicularly to the one long side of the building instead in that cube "Front" view.
Thanks y'all,
Donnia Tabor
Twitter @DonniaTH
LinkedIn
donnia.tabor-hanson
I found the answer. By having an elevation that is named, I can reorient the "Front" of the cube to be set to one of the elevations.
Thanks y'all,
Donnia Tabor
Twitter @DonniaTH
LinkedIn
