3D scan drone to revit
laurensV9CRL
laurensV9CRL
hellow,
anyone who has experience with a 3d scan from a dji air 3s, mini 4pro or other drones wit lidar technology? Is it possible to make a 3D scan with these drones from a building and insert it to revit so i can draw it in revit?
RDAOU
@laurensV9CRL
In principle, yes but I believe the mentioned models from DJI use photogrammetry and not lidar. And you would need to connect it to your tablet or PC and use a 3rd party flight planer because the remote controler that comes with the Air 3S does not have that (or at least did not use to)
Best if you check on the DJI forum before you buy
this might also be helpful for you to watch (DJI Drone Scane to Revit)
luisPDAN6
There is also the possibility to create Revit topography from lidar point clouds if the points are classified. Have a look on this page: here:https://apps.autodesk.com/RVT/en/Detail/Index?id=705615533998621884&appLang=en&os=Win64
