3d realistic view
3d realistic view
hatchethunter
Message 1 of 28
3d realistic view
hatchethunter
Every time I save Revit projects,whether that be different ones, there seems to be more problems with the realistic view on all Revit files, such as lines appearing through walls, dark colours appearing on model (when shadows aren’t enabled) and being able to select objects through walls. The 3D view isn’t corrupt and it happens on multiple devices,does anyone know what this problem could be?Could it be account related?
Replies (27)
Message 2 of 28
Revit 2021? Maybe Hardware related? Maybe the Video Card?  Have you checked for updates?   What are your computer specs?
Message 3 of 28
hatchethunter
Yes Revit 2021,I have no updates according to Autodesk app, windows 10,GeForce GT 710, i7 processor.
Message 4 of 28
I was referring to the Video Card driver.  Perhaps there's another or newer driver available.
Message 5 of 28
hatchethunter
Yes there is one possible driver update for the GeForce GT 710,however it states that it’s more suited,although it has been brought in very recently (January) so would you recommend downloading this?
Message 6 of 28
hatchethunter
More suited to gaming*
Message 7 of 28
Install through Windows Device Manager=>Display Adapters
...try it. You can always roll back.
Message 8 of 28
Is the shadowing you're seeing coming from Ambient Shadows?
Message 9 of 28
hatchethunter
No shadows are turned off
Message 10 of 28
hatchethunter
there are also no driver updates
Message 11 of 28
You can still show Ambient Shadows with Shadows turned off.  Look under the View's Graphic Display Options and see if "Show Ambient Shadows" is checked.
Message 12 of 28
Which Version are you using? 461.09?
Message 13 of 28
hatchethunter
Yes,”show ambient shadows” isn’t checked
Message 14 of 28
hatchethunter
The driver version is 27.21.14.5671
Message 15 of 28
You can always post your file here for us to look at.
Message 16 of 28
hatchethunter
It’s not a single file though,it’s happening on files also sent from other people! It’s fine on their Revit but on my PC or laptop it has strange shadows and strange ongoings in realistic view.I appreciate this continued support btw. Everytime I save a Revit file,it affects each realistic view on any of my Revit projects more and more.This is why I’m thinking it could be account ordinated or something
Message 17 of 28
You think the issue is related to your account?
Message 18 of 28
hatchethunter
I have a feeling, because when an issue (such as the black shadows) happens on one project, when I open up another project, that same problem (black shadows) appear
Message 19 of 28
Geforce GT 710 is a weak card so artifacts in realistic views are normal.
"PassMark - GeForce GT 710 - Price performance comparison" https://www.videocardbenchmark.net/gpu.php?gpu=GeForce+GT+710&id=2910
Message 20 of 28
hatchethunter
  The problem still occurs on another PC with intel (R) HD graphics family
