3D Orbit and Pivot point
jsanders
Message 1 of 21
jsanders
On revit, when you hold scroll wheel and shift to orbit the model, it always goes crazy and out of view unless you select an item, press escape, then orbit around the model.
On Navisworks for example, the software is clever because it puts an automatic pivot point so you don't have to waste time clicking on an object, pressing escape, then orbiting around the model.
Anyone know how to activate a "automatic Pivot point" or "standard 3D CAD software mode" ?
__________________________________________________________________________
ヽ༼ຈل͜ຈ༽ノ Onward still he goes, Yet ne'er looks forward further than his nose ヽ༼ຈل͜ຈ༽ノ
Replies (20)
Message 2 of 21
constantin.stroescu
from Navigation Bar > Full Navigation Wheel - choose Center to place the Orbit Center Point...
Constantin Stroescu
Message 3 of 21
jsanders
Hello @constantin.stroescu thanks for the reply.
I see what you are trying to do, but I was more looking for a setting to activate in the options menu. Your solution still requires as much clicks as what I'm currently doing (clicking then pressing escape).
Ideally Revit needs to "calculate" an automatic pivot point so when you are handling huge files, the model doesn't disappear. This happens all the time, it's frustrating.
Message 4 of 21
constantin.stroescu
As I know , Revit calculates the Original Center for Orbit at the Geometric Center of the paralelipipedic envelope of the whole model.
  • Right click on Center ( Navigation Wheel) > Restore Original Center - the Center will be placed in the geometric center of the envelope.\
  • If you make a Group from your model items you will be able to vizualize this
Constantin Stroescu
Message 5 of 21
loboarch
There is no way to "activate" an automatic pivot point other than selecting an element in the view BEFORE orbiting, but from your post is sounds like you already know this.
You just have to get in the habit of selecting something before you orbit when zoomed in closer than the extents of the model.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 6 of 21
constantin.stroescu
hi Jeff,
You are right about the Pivot Point placed on selected objects.
What I have shown in my post is that if nothing selected ( by default) the origin of the Pivot Point ( Original Center ) is placed in the geometric center of the envelope of the model objects . It's true that this Center does not update automatically and it has to be forced by Restore Original Center comand
Constantin
Constantin Stroescu
Message 7 of 21
jsanders
Unfortunately, I was hopping someone could have said that I was wrong and that something did exist in the options menu. Alas. Maybe we can hope that something good will come in revit 2017 ?
Message 8 of 21
jsanders
Here is for example a problem. Even with puting the pivot point on "center" it doesn't work.
I simply want to have the pivot point of the orbit to be where my mouse is, not in the center of this piece of land I'm working on. It's ever so frustrating. I hope you understand what you mean Smiley Happy
Message 9 of 21
chrisplyler
I completely understand your desire.
My method is just to scroll out, orbit, and then scroll back in.
Message 10 of 21
jsanders
I hope that someone at Autodesk sees this so something can be done in future versions.
Message 11 of 21
fruity101079
5 years later and the problem is still not fixed...
It's not complicated to use the center of the screen for pivot. Like every other softwares do. Every video games do.
It's common sense for f*** sake...
Just give us the option to activate it if you want to keep your stupid way of doing, you don't even understand how it's frustrating to use it because you don't use your own software.
Message 12 of 21
jsanders
I've noticed that Autodesk often take many years to update the user experience... We just have to wait and hope they enhance Revit.
Message 13 of 21
hampus.wiknerWNEXK
I've recently transferred from Autocad Architecture to Revit. Imagine my surprise when my habit of navigating with the spacemouse no longer is possible in an efficient manner....  Two months in and my scrollfinger's starting to give up.
This doesn't feel like it should be a Customer driven enhancement, rather something Autodesk should do and promote there Revit users to benefit from. A healthy and efficient user is a good customer.
Please fix this Autodesk!
Hampus
Message 14 of 21
RobDraw
I don't see where you posted about how to make you mouse work in Revit. That step usually comes before giving up and berating Autodesk. I really don't think your troubles are related to your mouse at all.
Good luck.
Rob
Message 15 of 21
norman2KMXQ
Even the selection pivot point rotation fails when editing 3d points. The funny (not ha ha funny, more weird or odd) thing about this is that I seem to remember an older version of Revit did center around the selection when editing 3d points. I couldn't tell you which version this was since it was many, many years ago.
Message 16 of 21
fruity101079
Another exemple :
When you BX something, it's because you want to work on a specific thing.
But revit will continue pivoting around the last selected object ... really not logical.
It's been years now using revit, and I still can't get in the habit because it's so unnatural...
ps: same thing of revit classical, or mep.
Message 17 of 21
christine_lungay
Community Visitor
Community Visitor
Hi. I'm new to Revit, but I have 10 yrs of experience with other CAD softwares. I'm used to other CAD softwares being able to use the center of the screen for pivot.
Any news on this issue? Has it been resolved by Autodesk? I'm using Revit 2025 now.
Message 18 of 21
mhiserZFHXS
There's nothing to "resolve." This is just how Revit works. Honestly, I prefer the precision of picking the object I'm orbiting around. Its a different software, so it'll just take some getting used to.
Message 19 of 21
hampus.wiknerWNEXK
This issue is "in progress" in the Revit roadmap at the moment.
https://www.autodesk.com/blogs/aec/roadmap/revit-architecture-roadmap/
Message 20 of 21
mhiserZFHXS
It is? I'm not sure if I'm just looking over it or what, but I don't see it.
