3D Model not showing in realistic view
djustF9UNE
djustF9UNE
Hi all,
I'm having a bit of an issue with my 3D model. Whenever I change it to the realistic visual style the model seems to disappear. It reappears when zooming and orbiting but as soon as it stands still it disappears. However, I can still select all the walls, roof, etc. All the other 3D visual styles are working fine.
Does someone have a fix for this?
Thanks in advance.
LionelRKatz
Hi, you can turn off the hardware acceleration (see the attached image) to see if that help
This problem seem like something with your GPU, check if you have the latest drivers too.
