3D Family issues.
i have just create a family for a complex window sill of concrete. Basically have two slanted areas as you can see in the picture. In autocad and Rhino is quite easy, but in Revit I could only make it two extrusions, remove a volume and then place together. The difficult thing was making the 2 one that is a plane that goes througe 3 lines with differente gradiant. As I said in Rhino is easy but here I could onle make it aproximately rotating, trying and error. Is it possible to make it exact knowint the position and gradiant of the 2 lines?
Second thing is possible to have the intersections lines B and remove the tangent lines A?
Finally in the family the 3d view is perfect but when I upload it to the project then it has a corner that doesnt match? Is tehre a reason gor this?
Thank you
