Stairs - how to specify actual riser height and tread depth
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
design1001
435 Aufrufe, 2 Antworten
When I create stairs the actual riser height and actual tread depth is greyed out, how do I create stairs by adding a value here?
2 ANTWORTEN 2
Nachricht 2 von 3
vitorbortoncello
als Antwort auf: design1001
hi! you can only control actual riser height by adjustig base and top level, and desired number of rises. also, you can control tread depth when finishing edit mode and selecting the stair.
you can´t add values in actual riser height.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 3
design1001
als Antwort auf: vitorbortoncello
Thank you that is SO helpful!
