3D constraints when making a Beam system not not showing as an option
Hi, when I go to create a beam system, I don't get 3d constraints as an option. Can someone tell me why this is?
cbcarch
check here: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/Revit-StructEng/files/GUID-487AE7B8-EBE4-4345-B2C8-016F69AC43A2-htm.html
@cbcarch - This reply has been edited by the moderation team as the legacy links were no longer valid
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Beam SYSTEMS don't have "3D Snapping".  That's a Beam Option.  One edge at a time.  If you are trying to snap multiple "Beams" to a 3D Form, you might look into Divided Surfaces with Pattern-Based Curtain Panels.
