- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
hi i am a new user of revit, and I have a question here:
I am trying to build a very simple 2d toilet family to use in floor plans. in the family, I draw a masking region, hoping to use it to mask the floor tile lines when I use it in projects. But this mask region will not mask anything when I load this family into the project. I googled for an answer, and I actually found a section below:
Adding a Masking Region to a 2D Element in a Model Family
If you create a model family that only contains 2D elements (for example, a 2D toilet fixture) and you want to apply a masking region to the 2D element, you must include an invisible line to represent the Z dimension, which is where the masking region is drawn. The invisible line must be drawn above the level and must be a minimal length (such as 1/8”) so that the masking region does not obscure any other elements in the view.
Could anybody explain it in plain English? how can an invisible line represent the Z dimension? How can i draw this masking region so that I can use it to block the tile lines in project?
Thanks in advance!!!
