2D Plant elevations
2D Plant elevations
Message 1 of 8
2D Plant elevations
Are there any 2D plant elevations for Revit out there? I sketched an elevation of a house rather than modeling - took me an hour. I have spent the last 6 hours trying to add plants. Have tried converting dwgs - not working (wrong version), and found some in Revit v 2017 - I have 2016. By this point I could have modeled the house and added some vegetation because I havve plenty of 3D plants - I'm under the wire!!!!!! Any sources out there?  Thanks much -
Replies (7)
Message 2 of 8
I responded to your post on Revit Forum. Archvision is a good source for RPC families. BTW, you can also create entourage families that do not use RPC content for render appearances.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Message 3 of 8
@Anonymous
A simple google search for CAD drawings of tree elevation gives plenty.  Download and import in Revit either as detail component family or directly in project.
http://www.cad-blocks.net/vegetation-cad-blocks-trees-elevation.html
Message 4 of 8
Thank you for your response - unfortunately I keep getting an assortment of error messages when trying to import dwg files such as "content can't be found", or wrong version, they come in as one big file - more like a jpeg (can't split them apart) - I tried using photoshop for jpegs but they kept coming in behind the house - wouldn't move above it even after I tried grouping the lines - I'm pretty much done - have spent now over 8 hours on something that should have taken me one hour. SH_T!
SORRY about wining, and thank you again -
Message 5 of 8
Thank you for responding; I don't know what an RCP is, and I would like to know soon - meanwhile I was just hoping that there was a way to insert a jpeg, with a transparent background into revit. I know they exist because I found one on Revitcity, but it was cartoonish. I tried making transparent jpegs in Photoshop but they didn't come in to Revit that way. Thank you for the suggestion though - I will experiment with that soon.
Message 6 of 8
Uhm you need to go to the link in my post, download the zip file, unzip it to a folder, and import the dwg fike or files in Revit. The picture in the post is just a screenshot showing what the webpage looks like. Do not import it please.
Message 7 of 8
Attached is a CAD drawing of plant elevation symbols from the same source I have pointed you to.
Message 8 of 8
constantin.stroescu
For Elevation Views and other 2 d Views, I use Detail Items and Raster Images( the most of them made by myself 😞
  • Detail Items - Annotate>Component>Detail Component - You can made them by yourself using a .dwg base
  • Raster Images with alpha mask : .png or tiff
  • .DWG Files
For 3D Views ,I use Raster Images  into Sheets ( mainly .png wit alpha mask)
Of course , you can use .RPC files for rendering purposes and not only  and 3d models from .dwg
on SHEET:
I,ve attached two examples of Detail Items and one .png file , made by me.
Constantin Stroescu
