2d Family
2d Family
Message 1 of 11
2d Family
Hi everyone
I've created some 2D families, just using symbolic lines and masks, but when i load the family to my project the mask dont work, does anyone knows why?
Replies (10)
Message 2 of 11
Is the View set to Hidden or Wireframe visual style? Is the hatch the floor material surface pattern or Room Color scheme?
Message 3 of 11
the view is hidden Line and the hatch of the floor is a pattern
Message 4 of 11
Maybe the category is set to Transparent, or the masking region is set Invisible. Feel free to upload a family if you want.
Message 5 of 11
ok, here is the file
Message 6 of 11
1. You can add some value to the Offset field of the Furniture without modifying the family.
2. Or try the modified family attached, then no need to Offset.
Message 7 of 11
yeah, this works, but there is another way to fix this without offset?
Message 8 of 11
Yes see the family attached.
Message 9 of 11
You just sent the print, did not you?
I didn't understand what did you do in the 2 option
Message 10 of 11
I forgot to bring in the dialog on screen when I edited the model line visibility.  See below:
Message 11 of 11
Thank you so much, now I understand.
