2022 | New Knowledge Support Articles | Revit
lim.wendy
Alumni Alumni
Message 1 of 10
lim.wendy
Scroll below to view Autodesk Knowledge Network support solutions that were created in 2022.
Looking for older articles? They're posted below:
2021 | New Knowledge Support Articles | Revit
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Replies (9)
Message 2 of 10
lim.wendy
Mar 2022
Published Date
Summary
Knowledge Article
Incident Logged
22-Mar-22
What is the difference in IFC export when "Export Bounding Box" is checked in Revit?
No
29-Mar-22
Fitting elements from Revit cannot be exported to IFC.
No
03-Mar-22
Is it possible to show more than one Design Option for a Linked Revit model?
How to show more than one Design Option for a Linked model in Revit
No
31-Mar-22
Text in CAD file nested in linked RVT file is hidden by model things in the host file when printed using vector processing in Revit
Text in CAD file nested in linked RVT file is hidden by model things in the host file when printed u...
Yes
18-Mar-22
User reported that worksets visibility in a linked file is not working well in host file in Revit.
Worksets visibility in a linked file is not working well in host file in Revit
Yes
17-Mar-22
IFC models are shifted after exporting them from Revit.
IFC do not lie on top of each other after exporting them from Revit
No
05-Mar-22
After installing a new Revit Server Accelerator, the model data is not being cached.
Revit Server Accelerator not caching model data after initial setup
No
09-Mar-22
How to hide part of the Annotation Tag in Revit?
No
08-Mar-22
The message "Can't keep wall and roof joined error in Revit" appears in Revit when creating dormers for the existing Roof.
"Can't keep wall and roof joined" when creating dormers in Revit
No
18-Mar-22
How to present pipe center line in Revit
How to show pipe center line in Revit
No
07-Mar-22
Revit crashes when editing profiles.
Crashing Revit session when editing profiles
No
23-Mar-22
How to change or apply Revit category to imported IFC elements created in Civil 3D?
No
01-Mar-22
Custom Flow parameter for connector is greyed out for Mechanical Equipment when loaded into a Revit project.
Custom Flow parameter for Connector is grayed out in the Revit project
No
16-Mar-22
Users reported that white are prints to pdf behind some railings in Revit.
White area prints behind railing when view is on a sheet in Revit
Yes
24-Mar-22
User reported that if a Revit link model is bind further commands ungroup and delete the model groups deletes also the Line Based Families.
If a Revit link model is bind further commands ungroup and delete the model groups deletes also the ...
Yes
25-Mar-22
Can recovery files created during a crash be used to recover unsaved/sync’d work for Revit cloud models?
Can recovery file be synched to cloud project in Revit?
No
14-Mar-22
Users reported that while rendering the view in Revit the edges of elements are not visible, even if the 'Show edges' option from Graphic Display Options is active.
Edges not visible while rendering view in Revit
Yes
24-Mar-22
Cannot see the plane or cross-section axis on elevation views in Revit
Cannot see the plane or cross section axis on elevation views in Revit
No
15-Mar-22
Version History option is missing in Revit
No
25-Mar-22
Roof layers missing in Revit section views
Yes
03-Mar-22
Users reported that while rendering the view in Revit, some elements appear, that are not visible in the model before rendering.
Unexpected shadows while rendering the view with specific glass material applied in Revit
Yes
16-Mar-22
Users reported that Revit doesn't display joined column and wall elements with the expected graphics in specific situations.
Unexpected display of floor plan view of joined column and wall in Revit
Yes
25-Mar-22
User reported that scale parameter is not aligned with other parameters in Titleblock in Revit.
Scale parameter not aligned with other parameters in Titleblock in Revit
Yes
25-Mar-22
User reported that when move or align a beam/brace in Revit model the Start/End Attachment Distance is not recalculated.
When move or align a beam/brace in Revit model the Start/End Attachment Distance is not recalculated
Yes
29-Mar-22
Users reported that when using Revit in a Windows 11 OS, the Color Fills Calculation background process takes an unexpectedly long time and fails.
“Color Fills calculation failed” when using Revit in a Windows 11 OS environment
No
17-Mar-22
How to define line style when importing CAD files into Revit? Is it possible to define line styles mapping, similar to line weight while importing CAD files?
No
30-Mar-22
When working in a Revit model with links, the linked model does not show colors or materials.
Color/Materials from linked model not displayed in Revit host model.
No
17-Mar-22
How to transform local coordinates to Gauss-Krüger coordinates in Revit?
No
17-Mar-22
"Can't place inserts outside of hosts" when copying elements in Revit.
No
31-Mar-22
How to export a group of model elements to one merged IFC object from Revit?
No
31-Mar-22
How to convert a project template from Metric to Imperial in Revit?
No
21-Mar-22
Users reported that Revit turns instance parameters of a label into type parameters when copying the nested label into other families.
Shared instance parameters change to type parameters when copied into a new host family in Revit
Yes
22-Mar-22
Section Head Annotation Label contains a limited list of parameters in Revit. Unable to add additional "Sheet Name" parameter or any shared parameter to the list.
Section Head Annotation Label contains limited list of parameters in Revit
Yes
08-Mar-22
User reported that spot elevation shows additional digits with not rounded value for meters and centimeters unit type in Revit.
Spot elevation shows additional digits with no value for meters and centimeters unit type in Revit
Yes
09-Mar-22
When needing to edit the order of Revisions in Revit, the revisions do not organize as expected on the sheet.
Unable to reorder Revisions on Sheet in Revit
No
08-Mar-22
User reported that stair landing and floor base quantities are incorrectly exported to IFC from Revit
Stair landing and floor base quantities incorrectly exported to IFC from Revit
Yes
10-Mar-22
How to completely clear the value of the number parameter in Revit?
How to reset value of mass density or any other parameter of number type in Revit
No
09-Mar-22
Inserting MagiCAD ventilation products causes Revit 2022.1 to close unexpectedly
No
09-Mar-22
Pipe accessories are not recorded in terms of quantity in a Panel Schedule in Revit
Yes
04-Mar-22
How to set up Shared Coordinates in a Site or Base Revit model and how to move or relocate the model as needed.
How to set up Shared Coordinates using one Revit model as the Site or Base file
No
03-Mar-22
How to place Fabrication fittings on a side of a straight channel in Revit
How to place Fabrication fittings on a side of a Straight channel in Revit
No
07-Mar-22
Users reported that the filter rule is not displaying the associated parameter value in Revit User Interface.
Filter rule is not displaying the associated parameter value in Revit User Interface
Yes
07-Mar-22
Users reported that grids cannot be exported to IFC from some Revit projects.
Grids not exported to IFC from Revit project
Yes
15-Mar-22
Room gets randomly cut out in Revit.
No
25-Mar-22
Users reported that elements disappear in plan view when linked model is loaded and crop region isn't rectangular in Revit
Elements disappear in plan view when linked model is loaded and crop region isn't rectangular in Rev...
Yes
12-Mar-22
Where can one find the information, tools and support required for developing add-ins for Revit and other Autodesk products?
Where can one find information and resources for developing Revit add-ins ?
No
14-Mar-22
Dynamo Player cannot be launched in Revit 2022. The following error message appears: "Revit Cannot run the external application 'Generative
Design'. Contact the provider for assistance. Information they provided to Revit about their identity...".
"Revit Cannot run the external application 'Generative Design'..." when running Dynamo Player in Rev...
No
04-Mar-22
Cannot access BIM 360 models through Revit on two computers at the same time.
Cannot work on Revit BIM360 projects between multiple devices
No
06-Mar-22
Where to find mechanical, electrical, or plumbing (MEP) training for beginners in Revit?
Available mechanical, electrical and plumbing (MEP) training for beginners in Revit
No
17-Mar-22
Cannot export geometry into IFC from Revit
Cannot export IFC from Revit
No
28-Mar-22
Users reported that nothing is displayed after IFC import in Revit.
Nothing is displayed after importing IFC in Revit
Yes
09-Mar-22
After selecting an Elevation marker, the grips and crop box are not displayed.
Elevation grips not displaying in Revit floor plan
No
09-Mar-22
After moving the host model and RVT links to a drive other than the default C: e.g., to 😧 it caused a performance drop in Revit. Comparing the opening time of the same dataset between drives, a difference of tens of percent was noted.
Performance drop in Revit after moving models to a drive other than the default C:
No
30-Mar-22
After exporting a Revit model to IFC version 4 format, the geometry is not correct. Some elements are in the wrong spot and a large number of them are missing.
Incorrect geometry after exporting Revit model to IFC 4
No
22-Mar-22
After selecting an RVT model and loading it as a model group, the geometry is not visible on the floor plan and 3D view in Revit.​​​
Unable to load RVT model as a model group to an open model in Revit
Yes
31-Mar-22
Users reported that nothing happens after activation keyboard shortcut just after validation of selection filter in Revit.
Nothing happens after activation keyboard shortcut just after validation of selection filter in Revi...
No
Feb 2022
Created Date
Summary
Knowledge Article
Incident Logged
25-Feb-22
When viewing the Pipe Size in the properties of Revit, the Size is incorrect.
Pipe size is not correct in Revit
No
25-Feb-22
Users reported that Yes/no parameters are not working in lookup tables in Revit.
Yes
25-Feb-22
Users reported that parameter values with units get incorrectly exported when activating the Export Option "Export user defined parameter sets" and "Export parameter mapping table"
Incorrect export of unit defined parameter values in User defined parameter sets in Revit
Yes
26-Feb-22
“Group instances of the same type do not contain identical members" error when placing a room in a group in Revit
“Group instances of the same type do not contain identical members" error when placing a room in a g...
Yes
12-Feb-22
Unable to make connection with C Channels to Concrete/ Steel Column in Revit.
Yes
15-Feb-22
Users reported that when trying to save a Revit family, the "Type Selector" tooltip dialogue opens up and it cannot be closed while the save window is open.
When trying to save a Revit family, the Type Selector tooltip dialogue opens up and it cannot be clo...
Yes
01-Feb-22
"Autodesk Revit has stopped working" when importing/linking DWG file in to Revit
No
02-Feb-22
When using the GetParameterValueByName (Element.GetParameterValueByName) node in a Dynamo graph with Revit models, the Material parameter returns “Material” instead of the materials name.
GetParameterValueByName returning “Material” for Revit element’s material parameter in Dynamo graph
No
02-Feb-22
"Linked file could not be located. It will be displayed as it was when this project was last saved" when linking the DWG file in Revit
"Linked file could not be located. It will be displayed as it was when this project was last saved" ...
Yes
08-Feb-22
Weather tab in location dialog is missing in Revit 2022
Weather tab is missing in Revit 2022
No
16-Feb-22
When exporting a project from Revit to NWC, Spaces which are not visible in the model are showing up in the NWC.
Exporting to NWC from Revit is unexpectedly showing Spaces in Navisworks.
No
17-Feb-22
Dimension text rotation is not preserved when exporting a Sheet to PDF with a horizontal view break in Revit
Dimension text rotation is not preserved when exporting a Sheet to PDF with a horizontal view break ...
Yes
03-Feb-22
User reported that IFC linked models are located incorrectly in Revit if IFC import template has different project base point than Revit host model
IFC linked model located incorrectly in Revit if IFC import template has different project base poin...
Yes
18-Feb-22
User reported that Linear and Aligned Multi-Rebar Annotation don't work as expected in Revit
Yes
10-Feb-22
The same glazing material appears different when used in different families in Realistic views in Revit 2022. This occurs in the elevation & section views in realistic mode.
Same glazing material appears different when used in different families in Revit
Yes
07-Feb-22
Shared Parameter values change when IFC file is exported from Revit
IFC Export from Revit shows different Parameter Values
Yes
22-Feb-22
Model lines are missing when printing to PDF in Revit
No
08-Feb-22
When utilizing a Spot Coordinate in Revit, the Coordinates are reporting incorrect values.
Spot Coordinate reports incorrect value in Revit
No
10-Feb-22
When creating a Schedule for Fabrication Parts in Revit, how to use the Product Entry parameter as a Field in the schedule.
How to push the Product Entry Parameter for a Fabrication Part into a Schedule in Revit
Yes
10-Feb-22
User reported that multi rebar annotation shows different Rebar number than structural rebar tag after changing set type to "Varying Rebar Set".
Rebar numbering issue in Revit - multi rebar annotation shows different Rebar number than structural...
Yes
15-Feb-22
How to tag the tread depth of a spiral stair at the specified offset from the stair boundary in Revit?
How to tag the tread depth of a spiral stair at the specified offset from stair boundary in Revit
No
16-Feb-22
Unable to link IFC 4x3 file into Revit.
No
02-Feb-22
The BIM 360 icon on the Home Page screen of Revit doesn't react until toggling the "Maximize"/"Restore Down" button of the application.
Unreactive BIM 360 icon on the Home page screen of Revit
No
25-Feb-22
Elements in the IFC file are missing when IFC is opened in Revit 2020 and 2021
Yes
25-Feb-22
"To save the model to the cloud, you need access to Autodesk Docs" when try to save as cloud model in Revit.
"To save the model to the cloud, you need access to Autodesk Docs" when try to save as cloud model i...
No
18-Feb-22
The folder structure of BIM projects is not displayed completely in Revit or in Desktop Connector.
Folder structure of BIM projects not displayed completely in Revit or in Desktop Connector
No
18-Feb-22
Where to find Auto Section Box Add-on for Revit.
Where to find and install Auto Section Box Add-on for Revit
No
19-Feb-22
IFC exported from Revit model shows an incorrect model with additional elements in Navisworks and BIM 360
IFC exported from Revit model shows an incorrect model with additional elements in Navisworks and BI...
Yes
18-Feb-22
Users reported that rebar handles are not displayed for some plan views when depth clipping with or without line is enabled in Revit.
Rebar handles are not displayed in plan view when depth clipping is enabled in Revit
Yes
21-Feb-22
Users reported that Cable Trays are not visible when linking IFC to Revit 2021.
Cable Trays missing when linking IFC to Revit
Yes
25-Feb-22
"<Username> is currently working on <Filename.rvt>" when opening a Cloud Model for Revit
"[Username] is currently working on [Filename.rvt] Only one person can be in the model at a time" wh...
Yes
02-Feb-22
Vertical Bracing Symbols are not displaying in Revit floor plans.
No
04-Feb-22
When exporting to IFC from Revit the stair railing is duplicated and shoots through the roof.
When exporting to IFC from Revit the stair railing shoots through the roof
Yes
04-Feb-22
Cannot find and add a parameter in Revit to the pipe or duct accessory families to specify in which space they are located.
How to add information about the space where duct or pipe accessories are located to these family ty...
No
04-Feb-22
Users reported that Z coordinate is wrong exporting model to IFC with Shared Coordinates from Revit
Wrong Z coordinate exporting model to IFC with Shared Coordinates from Revit
Yes
06-Feb-22
When editing a Curtain Wall, the following error message appears and Revit crashes: "A serious error has occurred. The current action has been cancelled. It is strongly recommended that you save your work in a new file before continuing. Would you like to save a recovery file?"
"A serious error has occurred. The current action has been cancelled..." while editing Curtain Wall,...
No
06-Feb-22
A specific model with links cannot be opened in Revit. The loading process stops at 75-80%. There is no error message or program crash. Opening with the Audit option does not help. Opening this model on a fresh Revit installation has the same result.
Cannot open specific model with links and loading stops at 75-80% in Revit
No
19-Feb-22
After creating and annotating a Concrete Slab, if the element is split the annotations are removed.
When splitting a Concrete Slab in Revit the annotations are lost
No
08-Feb-22
When trying to place a Revit Piping Accessory on a piece of Fabrication Pipe, the element does not connect or break into the pipe.
Unable to add Revit Pipe Accessory to MEP Fabrication Pipework
No
23-Feb-22
Users reported that drop down windows appear transparent in Revit.
Drop down windows appear transparent in Revit
Yes
22-Feb-22
Warning message "System.NullReferenceException:..." appears after clicking selection icon in Areabook Extension in Revit
Warning message "System.NullReferenceException:..." appears in Areabook Extension in Revit
Yes
26-Feb-22
Is it possible to configure a local server with Windows Server operating system on which Revit would be installed? When users connect remotely to a server using Hyper-V, will a graphics card routed to the terminal using Discrete Device Assignment (DDA) be detected? It is critical that the Hardware Acceleration option be enabled in Revit.
Configuration of a local server with Windows Server operating system that can be used by multiple Re...
No
25-Feb-22
Users reported that “The duct/pipe has been modified to be in the opposite direction causing the connections to be invalid.” is displayed syncing model to central in Revit.
“The duct/pipe has been modified to be in the opposite direction causing the connections to be inval...
Yes
15-Feb-22
How to use cloud rendering services for files
No
16-Feb-22
Export to Revit RFA doesn't include all expected geometry in Inventor.
No
18-Feb-22
In Revit, the fabrication duct size changes on its own such that width and height under properties are swapped.
The fabrication duct size changes on its own such that width and height properties are swapped.
Yes
Jan 2022
Published Date
Summary
Knowledge Article
Incident Reported
08-Jan-22
Revit files saved in Sharepoint are being deleted
No
07-Jan-22
"A serious error occurred. The current action has been canceled. It is strongly recommended..." error appears when bind Revit link
"A serious error occurred. The current action has been canceled. It is strongly recommended..." erro...
Yes
13-Jan-22
When loading a titleblock family, Revit crashes
Revit crashes when loading titleblock family
Yes
12-Jan-22
When placing a family with a large radius, the program displays the curve as many segmented lines.
Large radius Revit family shows up as segmented lines
No
18-Jan-22
Without a clear pattern, it was noticed that opening and synchronizing the cloud workshared model (host) in Revit, takes longer than expected and often exceeds 30 minutes. Dozens of RVT links and nested links added to the host model are stored in the Desktop Connector (Autodesk Docs Drive).
Slow opening and syncing of a cloud shared model (host) in Revit that contains dozens of RVT links s...
Yes
27-Jan-22
Cannot delete certain elements in Revit model.
Delete grayed out for nested family in Revit
No
19-Jan-22
Snap doesn't work for single points from linked DWG files in Revit. Points from DWG are not recognized in Revit, even if all snap options are activated.
Snap doesn't work for points from linked DWG files in Revit
No
28-Jan-22
Options for hyperlinking in PDFs exported from Revit
PDF Hyperlinks with Revit
No
28-Jan-22
When exporting any file to IFC, Revit crashes without any error messages.
Crash with no error message for any model when exporting to IFC in Revit
No
28-Jan-22
User reported that most elements imported from IFC file are far from project origin in Revit. IfcGrid and IfcDistributionPort elements are separated from the model.
IFC elements are not displayed correctly after linking IFC file in Revit
Yes
21-Jan-22
Joining two vent pipes using trim adds an elbow having sanitary system between the two pipes if one of the two vent pipes is connected to a sanitary system.
Yes
17-Jan-22
Issue while changing desired stair height and desired number of risers when updating the "Actual Riser Height" of stairs in Revit
Issue while changing desired stair height and desired number of risers when updating the "Actual Ris...
Yes
07-Jan-22
Users reported that view Reference Annotation works unexpectedly in projects based on German templates in Revit. The Sheet Number and Detail number will be not displayed, even if the views are placed correctly on the sheets.
View Reference Annotation works unexpectedly in projects based on German templates in Revit
Yes
21-Jan-22
Users reported that Revit 2019 crashes when loading specific families into a specific project file.
Crash when loading certain families into a specific project file in Revit 2019
Yes
10-Jan-22
Users reported that the geometry of stairs created by sketch in Revit will be displayed incorrectly.
Incorrect stair geometry while creating stair by sketch in Revit
Yes
24-Jan-22
"The naming rule can not be applied to the selected views or sheets" message appears while creating PDF Export from Revit and the Parameter Sheet Number is included in the File Name setup.
"The naming rule can not be applied to the selected views or sheets" while creating PDF Export from ...
Yes
11-Jan-22
Users reported that type parameter of specific groups cannot be changed through a schedule in Revit.
Unable to change a type parameter of specific groups through  schedules in Revit
Yes
27-Jan-22
Hatch pattern invisible for wall made as an in-Place model in Revit plan view when cutting the elements. The hatch is visible for regular wall elements.
Hatch pattern invisible for wall made as in-Place model in Revit
No
14-Jan-22
Users reported that the estimated value and not the calculated value is shown on the report.
Insight Analytical Space generation shows estimated value from zone component load summary in Revit
Yes
14-Jan-22
Users reported unexpected behavior of 'has no value' or 'has a value' Filter Operators in Revit. When the filter is used in a case when the Parameter value was entered and removed, the filter will be not updated.
Unexpected behavior of 'has a value' and 'has no value' Filter Operators in Revit
Yes
28-Jan-22
Users reported that Revit mistakenly reports different pipe fittings as duplicates amongst the model warnings.
Different MEP elements falsely reported as duplicates in Revit
Yes
06-Jan-22
When opening sheets, Revit will crash without an error.
When opening some sheets Revit crashes
No
05-Jan-22
Users reported that  rebar set disappears or only appears to a certain extent after adjusting View Visibility States to View as solid in Revit.
Rebar Set disappears after adjusting View Visibility States to View as solid in Revit
Yes
21-Jan-22
Users reported crashes at printing/ printing to pdf a specific sheet at vector processing in Revit 2021.
Revit quits at printing a specific sheet with vector processing
Yes
23-Jan-22
When the host model is opened, all project members except one see the geometry loaded from a specific RVT link in Revit. For this person, the geometry is not visible. Reloading that link does not help either.
For a particular project member, the geometry from the RVT link is not visible in Revit
No
24-Jan-22
Users reported that Revit closes without error message or crashes pressing Export button on IFC Export window
No
26-Jan-22
When reviewing Revit Link Manager, there are some DWG links which are missing or duplicated.
DWG links are missing or duplicated in Revit Link Manager
No
27-Jan-22
After opening an exported NWC model from Revit 2022 in Navisworks, the ceiling cutouts are not correct when compared to the same model exported from Revit 2021.
Incorrect cutouts in the ceiling when opening NWC exported from Revit 2022
Yes
28-Jan-22
When opening Revit models or linking different formats, the file name is shortened, and ~[number] appears at the end of its name in the Revit dialog box.
The name of all file types are renamed/shortened and ~[number] appears at the end when trying to lin...
No
29-Jan-22
After linking the model from which Design Options has been deleted along with the elements, some of them are still visible in Revit. For example, Design Options containing MEP elements should not be displayed on the following Section View in the host model after linking the model from which these Design Options have been removed.
Elements from deleted Design Options in a particular model are displayed when it is linked to anothe...
No
29-Jan-22
Is it possible for .dwf data be read in Vault?
Ability to read .dwf metadata in Vault
No
05-Jan-22
User reported that Precast doesn't apply view templates for Shop drawings in Revit
Precast does not apply view template generating drawings in Revit
Yes
25-Jan-22
When utilizing a Selection box to select elements from a model, Revit does not pick up certain elements that are visible on screen.
Selection box does not pick up some families when utilized to select elements in Revit
No
06-Jan-22
When attempting to upgrade a Revit model to a newer version, an error appears, "Data in File is corrupt and needs to be manually recovered." and the operation fails to complete.
"Data in File is corrupt and needs to be manually recovered." appears when attempting to upgrade a R...
Yes
26-Jan-22
How to use commands like Pan, Orbit, and Zoom in Revit without the middle mouse button.
How to navigate in Revit without the middle mouse button.
No
25-Jan-22
When apply Notch connection the beam web extends abnormally in Revit.
Yes
11-Jan-22
When launching Revit, a warning about the unsigned add-in CollaborateDB is displayed.
"The publisher of this add-in could not be verified" for CollaborateDB when starting Revit
No
26-Jan-22
User reported that linking or importing DWG files in Revit causes slow performance of views
Text in DWG files linked or imported to Revit hinders performance of Revit views
Yes
29-Jan-22
When trying to create a new study in Generative Design the following error message appears: "The Generative Design version you have installed is not compatible with this version of Revit. Please upgrade to Revit 2021.1 or later. Alternatively, remove this version of Generative Design and install an earlier version."
"The Generative Design version you have installed is not compatible with this version of Revit..." w...
No
21-Jan-22
Users reported that not all dimensions can be copy/pasted from one view to another in Revit.
"One or more dimension references are or have become invalid" when pasting dimensions in Revit
No
Wendy Lim
Rails Summit
Message 3 of 10
lim.wendy
June 2022
Published Date
Summary
Knowledge Article
Incident Logged
04-Jun-22
After running a custom Python script in Dynamo that changes the transparency setting for all model categories in Revit, a crash occurs and the following error message appears: "A fatal error has occurred. The application will be terminated. You have the opportunity to save recovery files for all of your changed projects...".
"A fatal error has occurred. The application will be terminated..." and Revit crashes after running ...
No
23-Jun-22
Customer is creating sweep families using custom add-in which they have developed inhouse. Sweep family consists of path which is a combination of some arcs and lines. The profile consists of a circle. In some families they are not able to change the profile radius, where as some other families are working perfectly fine. For some values of radius, sweep is working fine, but when customer changes radius to higher value he gets an error saying - Can't create Sweep. While changing radius, it is made sure that the profile radius does not exceeds the radius of arc in the sweep path.
"Can't create Sweep" while changing the radius of circular profile in Sweep family in Revit
Yes
09-Jun-22
"Can't cut instance(s) of (...) out of its host." When cutting perpendicular families from each other in Revit
"Can't cut instance(s) of (...) out of its host." When cutting perpendicular families from each othe...
Yes
22-Jun-22
"Invalid Formula" message appears when the family parameter is modified in Revit
"Invalid Formula" message appears when the family is modified in Revit
No
28-Jun-22
Users reported that all project members of a particular Plant collaboration project in version 2022 cannot open any AutoCAD Plant 3D project via P&ID Modeler in Revit 2022. Despite being Project Admins and using the latest version of Revit 2022, the following error message appears: "Issue occurs when connecting to Plant collaboration project. Please check network connection and open your collaboration project again."
"Issue occurs when connecting to Plant collaboration project..." when opening an AutoCAD Plant 3D co...
Yes
29-Jun-22
"Processing failed" error when uploading Revit file to BIM 360
Yes
30-Jun-22
Cannot link Topography from BIM 360 to an open Revit model. During this operation, despite all required services being assigned to the Autodesk account, a dialog box displays this message: "To link topography, you need access to BIM 360 Contact your BIM 360 administrator for access."
"To link topography, you need access to BIM 360..." when trying to link Topography from BIM 360 proj...
No
10-Jun-22
3D model space is not matching with the 2D location for the Revit model on BIM 360 or ACC
Yes
13-Jun-22
Users reported that all elements from IFC file are missing after linking/opening it in Revit.
All elements from IFC file are missing after linking/opening it in Revit
Yes
04-Jun-22
Users reported that door tags will be deleted at moving them into another position. The message "Elements will be deleted" appears before.
Annotation tags get lost at moving elements in Revit
Yes
28-Jun-22
Users reported that assemblies are exported to IFC in wrong elevation from Revit
Assemblies exported to IFC in wrong elevation from Revit
Yes
09-Jun-22
Can the Construction Cloud be used with Inventor and Revit version 2019?
No
06-Jun-22
Unable to map IFCFlowTerminal as Sprinkler using IFC mapping table when linking IFC in Revit.
Cannot map IFCFlowTerminal as Sprinkler using IFC-mapping table when linking IFC in Revit
No
06-Jun-22
Cannot rotate elements using align function in Revit
No
09-Jun-22
Change Callout default to be intersecting view in Revit
Change Callout default to be intersecting views in Revit
No
15-Jun-22
Users reported that Revit crashes editing title block data in Properties panel.
Crash editing title block data in Properties panel in Revit
Yes
03-Jun-22
Users reported that a custom family highlights unexpectedly when loaded into a project and hovering over an area outside of its extents in Revit.
Custom family highlights unexpectedly when hovering over an area outside of its extents in Revit
Yes
29-Jun-22
Users reported that rotating point clouds with changed visibility settings to "Intensity" or "Normal" causes warning in Revit: Display error "An error occurred drawing the contents of this view. The view will be closed."
Display error "An error occurred drawing the contents of this view. The view will be closed." when r...
Yes
03-Jun-22
Electrical elements copied to another floor via clipboard, this elements are not visible in the new floor in Revit.
Electrical elements copied to another floor via the clipboard are not visible in Revit
Yes
01-Jun-22
Users reported that EQ constraint not working properly with linked models in Revit.
Yes
20-Jun-22
Users reported that the filter doesn't work as expected for railing in rotated section view in Revit.
Filter doesn't work as expected for railing in rotated section view in Revit
Yes
30-Jun-22
Users reported that filters for linked IFC files don´t work for all pieces of elements in Revit.
Filters for linked IFC files don´t work for all pieces of elements in Revit
Yes
10-Jun-22
Grids appear slightly off-axis in project north view when rotating true north angle is 0.1 degree or lower in Revit.
Grids appear slightly off-axis in project north view when true north angle is 0.1 degree or lower in...
Yes
20-Jun-22
How to change wall wrapping thickness at opening reveal in Revit?
No
22-Jun-22
How to convert STP file into IFC in Revit?
No
01-Jun-22
How to create a door family with a glass panel in Revit?
No
28-Jun-22
Ceiling patterns of the same element don't align the same way on both the upper and the lower face of the ceiling in Revit.
How to display the ceiling pattern aligned the same way on both sides in Revit
No
01-Jun-22
Is it possible to open Revit model restored from Revit Server locally?
How to open locally Revit model restored from Revit Server
No
25-Jun-22
What is the process for setting up the connection between Revit and Revit Server Accelerator?
How to set up a connection to Revit Server Accelerator
No
21-Jun-22
How to use Model In-Place in Revit?
No
27-Jun-22
How the selected discipline affects the elements visibility in Revit.
How to use view by discipline in Revit
No
29-Jun-22
IFC files exported from Revit with different Coordinate base settings are linked to Revit the same way regardless of the export option.
IFC files exported from Revit with different Coordinate base settings are linked to Revit in the sam...
No
15-Jun-22
IFC model has the scale 1000 times bigger than the correct one when linked to Revit.
The scale is correct when checking the model in IFC viewers such as Solibri, BIM vision or Navisworks using the "Legacy" IFC-import option.
IFC model show 1000 times bigger than the correct one when linked to Revit
Yes
17-Jun-22
In family templates for title blocks, the origin is set to the bottom right in German template as co...
Yes
27-Jun-22
Despite correct unit settings for an open Revit model, after exporting data to Excel via iConstruct, values for the area, volume and length do not match those in the element properties in Navisworks.
Incorrect values for area, volume and length after exporting data to Excel via iConstruct from an op...
No
07-Jun-22
When working with Coordination models linked into Revit, these models do not live update as other files do.
Linked Coordination models do not live update in Revit
No
28-Jun-22
Users reported that exporting MAJ file show the wrong size for some elements in Revit.
MAJ exported contains wrong size value for certain fabrication elements in Revit
Yes
28-Jun-22
Users reported that the material takeoff for Ramps reports 0 values for the "Material: Volume" property in Revit.
Material takeoff for Ramps reports 0 values for Material: Volume property in Revit
Yes
18-Jun-22
Microsoft Office updates break Dynamo and excel links
No
30-Jun-22
Users reported that not all parameters are imported from IFC in Revit.
Not all parameters imported from IFC in Revit
Yes
13-Jun-22
Openings missing when exporting parts from Revit to IFC.
No
10-Jun-22
Users reported that pile caps hidden lines are not displayed in Revit properly.
Pile Caps (isolated foundation) displayed incorrectly in Revit
Yes
09-Jun-22
Railings modeled on Level 1 floor plan are visible in Level 2 plan as well even when the railings are outside of the view range of Level 2 plan.
This behavior is observe in metric unit system when the upper level elevation is less than 2300mm and in imperial unit system when the upper level elevation is less that 4'.
Railings drawn on Level 1 are appearing on Level 2 floor plan even when they are outside the View Ra...
Yes
01-Jun-22
Users reported that rebar schedules are generated much slower in Revit 2023 than in Revit 2022.
Rebar schedules generated much slower in Revit 2023 than in Revit 2022
Yes
13-Jun-22
Work with point clouds on a new computer is slow in comparison to another machine.
Revit is slow on a new computer when working with point clouds
No
13-Jun-22
The rooms do not occupy the entire space under the dormers, they only go up to the first roof in Revit.
Rooms do not cover the entire space under the dormers in Revit
No
13-Jun-22
Yes
27-Jun-22
Section cuts not disappearing from callouts when outside of the view even when the annotation crop is set in Revit.
Sections not disappearing from Callouts when outside of the view in Revit
Yes
15-Jun-22
Users reported slow refreshing material thumbnails while opening the material browser in Revit.
Slow performance when refreshing material thumbnails in Revit
Yes
22-Jun-22
Slow performance while Revit is installed directly on Windows Server 2019.
No
22-Jun-22
Stair Families created as model in-place not correctly assigned to the level after IFC export from Revit.
Stair Families created as model in-place not correctly assigned to the level after IFC export from R...
No
25-Jun-22
BIM Booster add-in does not start in Revit. There is a problem with the license.
Unable to run BIM Booster plugin in Revit
No
06-Jun-22
Unable to select automatically parameter values for all categories while creating Filter in Revit. For some categories values already entered in the project have to be placed manually in the filtering rule.
Unable to select automatically parameter values for all Categories while creating Filter in Revit
No
01-Jun-22
Warning: String.Contains operation failed when running Dynamo for Revit script
No
21-Jun-22
When same families exported to the DWG file from Revit, some families exports as same blocks and some families exports as different blocks
When same families exported to the DWG file from Revit, some families exports as same blocks and som...
Yes
09-Jun-22
Workplane based family is not placed in the corresponding level of group in Revit
Yes
14-Jun-22
Users reported wrong elevation Z value of imported IFC in Revit.
Wrong elevation Z value of imported IFC in Revit
Yes
May 2022
Published Date
Summary
Knowledge Article
Incident Logged
24-May-22
"Imported Toposurface Points are located a large distance from the model [...]" while creating a site model from points in Revit
"Imported Toposurface Points are located a large distance from the model [...]" while creating site ...
No
26-May-22
The following error happens when trying to add Keynotes in a Revit project to plans & sections: "Revit encountered a serious error. The current action could not be completed".
"Revit encountered a serious error. The current action could not be completed" when adding keynotes ...
No
26-May-22
Yes
19-May-22
When connecting single phase panelboards to transformers fed from 3 phase distribution equipment in Revit, you get an error ""Selected distribution system is invalid"
"Selected distribution system is invalid" when connecting panelboard to transformers in Revit
Yes
18-May-22
"The value is out of range! Enter a number in range..." warning in Revit
No
31-May-22
Users reported that "There has been an unrecoverable error during export Revit." warning is displayed exporting model to IFC from Revit.
"There has been an unrecoverable error during export Revit." when exporting model to IFC from Revit
Yes
03-May-22
When trying to save a model to the cloud, you receive the following message: To save the model to the cloud, you need access to Revit Cloud Worksharing
"To save the model to the cloud, you need access to Revit Cloud Worksharing" when saving model to cl...
No
28-May-22
unable, cannot, perform, run, perform, solar, analysis, one, specific, particular, user, project, member, error, revit, weather, station, more, 50mi, 50, miles, 80km, 80, kilometers, site, location, far, away, insight, green, building, studio, missing, data, list,
"Weather station is more than 50mi/80km from the site location..." when trying to run Solar Analysis...
No
3%-May-22
“Invalid order of phases: an object cannot be demolished before it was created.” message while loading model group into Revit project.
“Invalid order of phases: an object cannot be demolished before it was created” while loading model ...
No
12-May-22
A skylight created in a window family does not display as expected when above the cut plane in a pla...
Yes
17-May-22
Installing the March 2022 security update KB5011486 for Windows Server 2012 R2 resulted in an inability to synchronize between Revit and Revit Server.
After installing Security Update KB5011486 for Windows Server 2012 R2, synchronization between Revit...
No
02-May-22
Is it possible to avoid the Privacy Statement window prompt at first launch after installation in Autodesk Products?
Avoiding the Privacy Statement window prompt at first launch after installation in Autodesk Products
No
09-May-22
Users reported that beams are not dashed, but solid in structural view in Revit.
Beams not dashed but solid in structural view in Revit
Yes
17-May-22
The bluebeam PDF reader does not allow deleting pages from a PDF which is exported from the native PDF exporter tool in Revit 2022.
Bluebeam does not allow deleting pages from a PDF exported from the native PDF exporter tool in Revi...
No
23-May-22
Segment length parameters of the rebars from linked model are not visible in Fields in Revit schedule.
Cannot add rebar parameters from linked model in rebar schedule in Revit
No
10-May-22
Cannot correctly position IFC file exported in global coordinates during import in Revit
No
10-May-22
No
10-May-22
No
28-May-22
Revisions are corrupted and a new cannot be added in Revit.
Corrupted revisions in Revit
No
18-May-22
When selecting the path to change a image for a decal type
Crash when trying to change a decal type in Revit
Yes
12-May-22
When running a daylight analysis using Insight in Revit, the results are incomplete and not all rooms show
Daylight Analysis incomplete when using Insight in Revit
Yes
18-May-22
Users reported that DWG exported from 3D view to do not get the same placing like IFC model exported from the same view from Revit.
DWG exported from 3D view to do not get the same placing like IFC model exported from the same view ...
Yes
10-May-22
Element in Revit file show multiple worksets in the properties when loaded using issues plugin in Navisworks
Element in Revit file show multiple worksets in the properties when loaded using issues plugin in Na...
Yes
27-May-22
Users reported that Estimated Reinforcement Volume value is not correct after creating, copying or modifying free form rebars in Revit
Estimated Reinforcement Volume value is not correct after creating, copying or modifying free form r...
Yes
16-May-22
Users reported that extended wall layers are not exported to IFC from Revit.
Extended wall layers not exported to IFC from Revit
Yes
27-May-22
Users reported that geometry of facade elements (curtain walls) is incorrectly exported to IFC 2x3 from Revit with custom exporter, version 22.5.0.0.
Geometry of facade elements (curtain walls) is incorrectly exported to IFC 2x3 from Revit
Yes
03-May-22
Grid name is not updated in a Schedule when changing grid name in a plan view in Revit
Yes
04-May-22
How to add parameter value to all family types without opening families in editor in Revit?
No
13-May-22
How to control the display order in Annotation Family in Revit project to prevent some elements from being covered by others?
How to control display order in Annotation Family in Revit
No
18-May-22
How to create structural framing tags below the structural framing by default in Revit?
No
23-May-22
How to customize Section Head size independent of the view scale in Revit?
No
06-May-22
How to edit default settings of Fabrication fittings and Services in Revit without Fabrication products installed
How to edit the Fabrication configuration in Revit without Fabrication products installed
No
12-May-22
How to export a DWG from Revit with different layers for the different wall types?
How to export a DWG from Revit with different layers based on wall types
No
12-May-22
How to locate or place a family after loading it into a Revit model?
How to find/place families loaded into Revit model
No
11-May-22
How to import geometry from .asc file as topography in Revit
How to import geometry from asc file as topography in Revit
No
23-May-22
How to include the window clear height value into the dimension line in Revit?
How to include window clear height into the dimension line in Revit
No
11-May-22
How to obtain UTM 32 coordinates (ETRS89) coordinates from DWG file in Revit
No
11-May-22
How to place railings on Model In-Place stairs in Revit? It is not possible to pick the model-in-place stairs to place the railings on them.
No
12-May-22
How to show reference levels for pipes in schedule in Revit?
How to show levels for pipes in schedule in Revit
No
12-May-22
How to show pipe volume in liters in schedule in Revit?
How to show pipe volume in schedule in Revit
No
09-May-22
How to show top and bottom elevation with spot elevation for wall opening in Revit?
No
25-May-22
How to sort and hide levels within one project in the constraint dropdown list in Revit? When one Revit project contains multiple buildings, is it possible to separate and hide some levels from the selection list while creating 3D objects?
No
23-May-22
IfcBuildingStoreys exported with the value -519 to IFC from Revit, while the value for the level is set to 0.
No
16-May-22
Users reported many "unnamed" materials exporting structural connections to IFC from Revit.
Many "unnamed" materials exporting structural connections to IFC from Revit
Yes
24-May-22
Material colors do not display correctly in NWC exported from Revit when viewed in Navisworks
Yes
18-May-22
Users reported that a nested annotation symbol in a generic model family disappears in floor plan views when turning on the "Structural Framing" category in Revit.
Nested annotation in a generic model disappears in floor plans when turning on the  "Structural Fram...
Yes
27-May-22
New family created when reloading a new version of a group from an external file in Revit.
Yes
13-May-22
Users reported that node Tag.ByElement in Dynamo is not working for Rebars in Revit 2023
Node Tag.ByElement in Dynamo is not working for Rebars in Revit 2023
Yes
18-May-22
Users reported that only two structural framing parameters are exported to IFC as base quantities from Revit.
Only two structural framing parameters exported to IFC as base quantities from Revit
Yes
11-May-22
Material parameter is not exported to IFC from Revit
Parameter of the material is not visible after exporting model to IFC from Revit
No
3%-May-22
Parameters from IFC model are created several times in Revit when linking a new version of the IFC model
Parameters from IFC model are created several times in Revit when linking a new version of the IFC m...
No
17-May-22
In Revit, the pipe cap families do not accurately snap or connect to the ports of a manifold family in section and elevation views.
Pipe cap families do not accurately connect to the ports of a manifold family in the section view of...
Yes
19-May-22
Property Set not exported for specific Categories to IFC from Revit.
No
05-May-22
After updating Revit 2020 to the 2020.2.8 version, running a Dynamo script that uses the Excel Macro-Enabled Worksheet causes a Revit crash.
Revit crashes after running a Dynamo script that uses an Excel Macro-Enabled Worksheet file
No
21-May-22
Understanding what shows up on top/underneath in Revit models.
Revit element draw order
No
12-May-22
Setting the elevation base parameter to Survey Point changes the levels to incorrect values in Revit
No
31-May-22
Stereo-panorama rendering created from Revit on the cloud gets displayed with a rotation of 180° on screen of mobile devices.
Stereo panorama rendering of a Revit model is displayed rotated 180° on mobile devices
No
06-May-22
Users reported that structural connections elements are not in correct location exporting model to IFC from Revit.
Structural connections elements not in correct location exporting model to IFC from Revit
No
24-May-22
When opening a Revit model in Navisworks, some or all structural members do not display.
Structural members from Revit are not displaying in Navisworks
Yes
27-May-22
How to synchronise the Revit Servers?
Synchronising of Revit Servers
No
3%-May-22
The Roof Menu in Revit is using a Curtain Grid Image (Icon) when used in the Quick Access toolbar.
Yes
24-May-22
Users reported that Topography in wireframe display mode appears solid and hides inserted PDF and raster images set to background in Revit.
Topography in wireframe view appears solid and hides inserted PDF and raster images set to backgroun...
No
24-May-22
Yes
27-May-22
Users reported that Revit doesn't consistently succeed with deleting a shared parameter from a project file.
Unable to delete a shared parameter from a specific project file
Yes
06-May-22
Unable to run macro listed in Macro Manager in Revit. The run command is greyed out and the dialog indicates that the macro is corrupted.
No
04-May-22
Unable to sync to central file when having model groups in Revit. When the model groups will be ungrouped the file can be synchronized.
No
24-May-22
Users reported that some elements are displaced in unexpected way after flip command in Revit.
Unexpected position of some elements after flip command
Yes
09-May-22
Vertical pipe change to slope pipe unexpectedly when adjusting a horizonal pipe in Revit.
Yes
27-May-22
Users reported, that a window gets deleted unexpectedly, when changed to an opening with the same size in a later project phase in Revit.
Window unexpectedly deleted when overlapped with an opening created in a later phase in Revit
Yes
20-May-22
Windows display is incorrect while using phasing in Revit.
Windows display incorrect while using phasing in Revit
No
Apr 2022
Published Date
Summary
Knowledge Article
Incident Logged
22-Apr-22
"Boundary Conditions Settings Incomplete" displayed when setting Boundary Conditions for structural model in Revit
"Boundary Conditions Settings Incomplete" displayed when setting Boundary Conditions for structural ...
No
21-Apr-22
When adding or reloading a specific link to a cloud workshared model in Revit, the following warning appears: Instance of Link Needs Coordination Review.
"Instance of Link Needs Coordination Review" when inserting or reloading a link in Revit
No
20-Apr-22
Unable to access Revit Server Administrator panel. When trying to browse the panel, this error message appears: "Server Error The Revit Server Admin service is unavailable. Please reinstall Revit Server or contact your IT support for assistance".
"Server Error The Revit Server Admin service is unavailable..." when accessing Revit Server Administ...
No
25-Apr-22
"The data in [file name] is corrupt and needs to be manually recovered" when opening a cloud model with links from Desktop Connector in Revit.
"The data in [file name] is corrupt and needs to be manually recovered" when opening a cloud model w...
No
28-Apr-22
"There has been an unrecoverable error during export Revit." exporting model to IFC from Revit
Yes
11-Apr-22
Is there an Add-on for export of Revit Schedules to Excel for Revit 2022?
No
19-Apr-22
When the Work Plane-Based parameter is checked in the family properties, the default placement method is still Place on Face rather Place on Work Plane after loading the family into the Revit project.
Cannot insert Revit families with Place on Work Plane option selected as a default placement method
No
11-Apr-22
Users reported Revit crashes without message while viewing 3D realistic view or exporting to gbXML from Revit
Crash without message while viewing 3D realistic view or exporting to gbXML from Revit
Yes
05-Apr-22
Is there a family for creating green facades in the installed Autodesk Content Pack for Revit?
Dedicated family for green facades in Revit
No
12-Apr-22
Fabrication straights Length is not taken from the Specifications when using Optimize Length in Revit
Fabrication straights Length is not taken from the Specifications when using Optimize Length in Revi...
No
14-Apr-22
User reported that filled region in family loses its transparency when loaded to project in Revit.
Filled region in family loses its transparency when loaded to project in Revit
Yes
28-Apr-22
When adjusting the View Range for views, you are finding that geometry outside the bottom/view depth is still displayed.
Geometry below the bottom/view depth is displayed in Revit views
No
28-Apr-22
After associating an instance parameter to a global parameter in a Revit project, the dragging grips for other parameters disappear
Grips disappear when associating a global parameter to an instance parameter in Revit
Yes
15-Apr-22
How pipe insulation area and volume are calculated in Revit?
No
19-Apr-22
How to automatically edit complex floor shape in Revit
No
26-Apr-22
How to build and manage repeating apartment types across multiple project files in Revit?
No
12-Apr-22
When Revit is stuck in a loading process, what methods are there to stop this process or Cancel the program?
How to cancel or stop Revit from continuing to load when the program is frozen
No
08-Apr-22
How to change model fill pattern scale in Revit?
No
19-Apr-22
What is the fastest and easiest way to convert elements saved in AVEVA PDSM to families in Revit? Are there any available best practices or tools to perform a migration for multiple catalogs containing pipe classes, parts, assemblies and machines for plant construction?
How to convert elements saved in AVEVA PDMS to Revit families
No
07-Apr-22
How to create a wall tag containing instance, type and wall structure parameters in Revit
No
27-Apr-22
How to create custom hatching in Revit family? The hatch need to correspond with family when its size changes.
No
12-Apr-22
How to customize Spot Elevation in Revit?
No
04-Apr-22
How to export floor layers as separate elements to IFC from Revit? Is it possible to export the finish floor layer as a separate IFC element?
No
08-Apr-22
How to export list of points coordinates for foundation with Dynamo for Revit?
No
05-Apr-22
How to export system connectors to IFC from Revit to make them editable after importing them to Revit
How to export system connectors to IFC from Revit to make them editable after importing them to Revi...
No
11%-Apr-22
How to find Category ID list for <Family Type...> parameter type in shared parameters in Revit
How to find Category ID list for "Family Type" parameter type in shared parameters in Revit
No
25-Apr-22
How to move the Project Base Point back to the Internal Origin in Revit?
No
28-Apr-22
How to open a specific file in an external program through Revit
No
16-Apr-22
Impossible to add a new Omniclass number in Revit family.
Impossible to add a new Omniclass in Revit
No
25-Apr-22
User reported that integer type parameter value cannot be changed in Dynamo for Revit 2023
Integer type parameter value cannot be changed in Dynamo for Revit 2023
Yes
04-Apr-22
Users reported that importing a DWG file into a rotated plan view in Revit results in misplaced MText component of block references in Revit.
Misplaced MText components of block references of an imported DWG file in Revit
Yes
21-Apr-22
When moving conduit in Revit, the conduits do not remain connected and disjoin.
Moving conduit in Revit causes the connection to break
No
14-Apr-22
When syncing a model, Reloading Latest hangs and take a long time to finish in Revit.
Reloading Latest hangs and take a long time to process when syncing in Revit
No
06-Apr-22
When trying to load a Dynamo graph Revit does not respond and Dynamo reports an error.
Revit fails to load a Dynamo script and Dynamo reports an error
No
22-Apr-22
Revit is not stable. Unable to open it.
Revit is not stable. Cannot open it.
No
23-Apr-22
Revit to IFC and back to Revit
No
14-Apr-22
Room does not reach the external wall despite the lack of room bounding elements in Revit
No
20-Apr-22
Users reported that shadows for linked elements disappear in the 3D view when zooming and rotating after clicking on the link in Revit.
Shadows in 3D view disappear after clicking at the link in Revit
Yes
19-Apr-22
Users reported that slab edge elements always exported to IFC as IfcBuildingElementProxy from Revit.
Slab edge elements always exported to IFC as IfcBuildingElementProxy from Revit
Yes
05-Apr-22
Users reported slow performance when changing views, selecting elements, zooming in Revit.
Slow performance when changing views, selecting elements, zooming in Revit
Yes
22-Apr-22
User reported that solid patterns and their colors are not exported to DWG from Revit
Solid patterns and their colors not exported to DWG from Revit
Yes
22-Apr-22
Users reported that splits objects are exported as one object to IFC from Revit
Splits objects exported as one object to IFC from Revit
Yes
06-Apr-22
Is it possible to store custom material textures in BIM 360/ACC that are added to Revit Cloud Workshared models? Can the Desktop Connector be used in such a situation and how will this affect model performance?
Storing in BIM 360/ACC custom material textures for Revit Cloud Workshared models
No
13-Apr-22
When changing the survey point elevation in Revit, the level measurement should change from 0' to the desire level, but changes to a scaled number.
Survey point changes units in Revit
No
16-Apr-22
The synchronization process stops at the Reload Latest stage for the specified Revit Cloud Workshared model
Unable to fully synchronize a specific Revit Cloud Workshared model from a certain point in time. This issue can affect one user or a small group of project members. The synchronization process stops at Reload Latest stage, more precisely at 72% during regeneration.
Synchronization process stops at 72% during the Reload Latest stage for a specific Revit Cloud Works...
No
22-Apr-22
After setting up an Ordinate Dimension string in Revit, the text below the dimension string is not displayed.
Text is not displayed below the Ordinate Dimension String in Revit
No
11%-Apr-22
Users reported that it is not possible to export to IFC MEP Flow to SI units from Revit.
Unable to export to IFC MEP Flow to SI units from Revit
Yes
13-Apr-22
Users reported unexpected display when activating hidden lines display for MEP elements in Revit. When changing
Unexpected display when activating hidden lines display for MEP elements in Revit
Yes
12-Apr-22
Unexpected rendering results with artificial lighting when importing or linking CAD objects in Revit.
Yes
01-Apr-22
The color of a view title is changed for one view on a sheet in Revit.
View Title appearance (color, line pattern, weight) is different between views on a sheet in Revit
No
20-Apr-22
When performing automatic Pipe Sizing in Revit the pipe gets an incorrect diameter
Yes
Wendy Lim
Rails Summit
Message 4 of 10
lim.wendy
July 2022
Published Date
Summary
Knowledge Article
Incident Logged
30-Jul-22
Can you load your own families into Revit using the "Load Autodesk Family" tool?
No
30-Jul-22
When trying to split a schedule within a sheet in a Revit project, the “Split Schedule Table” Z break control is missing.
Split Schedule Table control missing for Schedule in Revit
No
29-Jul-22
Users reported that Arabic text is shifted when exporting sheets from Revit to AutoCAD.
Arabic text is shifted when exported from Revit to AutoCAD
Yes
29-Jul-22
Users reported that filled region or rebar patterns are not printed/exported to PDF from Revit.
Filled region or rebar patterns are not printed/exported to PDF from Revit
Yes
29-Jul-22
Is it possible to change the default path for local copies of Revit central models?
How to change the default path for local Revit models
No
29-Jul-22
How to cut a floor intersecting with a roof in Revit.
No
29-Jul-22
Steel connections types not visible in the dialog box or SQLDumperExe window opening and closing when creating steel elements in Revit.
Steel connections types not visible in the dialog box or SQLDumperExe window opening and closing in ...
No
29-Jul-22
The voids of the openings in beams are not exported to IFC from Revit.
Voids in beams are not exported to IFC from Revit
Yes
28-Jul-22
"There is no active document in Autodesk Revit" warning appears in Robot during exporting model to Revit.
"There is no active document in Autodesk Revit" when exporting model from Robot to Revit
No
27-Jul-22
When copying a group from one file to another the dwgs are duplicated in the 'Imported' category for Visibility Graphics but in "Manage Links" are listed only once in Revit.
Copying a group from one file to another results in duplicated DWGs in the 'Imported' category for V...
No
27-Jul-22
Yes
27-Jul-22
DWG text overlapping when linked into Revit
Yes
27-Jul-22
Users reported that hosted line loads applied to panels in Revit are not exported to Robot.
Hosted line loads applied to panels in Revit are not exported to Robot
Yes
27-Jul-22
How to make a reveal profile element visible and assign a material to it in Revit?
How to make a reveal profile element visible and assign material to it in Revit
No
27-Jul-22
Users reported that rebar shape 21 is not correctly displayed after setting "Hook Rotation At Start/End" to 90 degrees in Revit.
Rebar shape 21 is not correctly displayed after setting "Hook Rotation At Start/End" to 90 degrees i...
Yes
11%-Jul-22
Modifying Revit warning settings by adding custom entries in Revit.ini file does not work.
Changing Revit settings by adding custom entries in Revit.ini file does not work
No
11%-Jul-22
When synchronizing changes in a Cloud Worksharing host model in Revit, a linked point cloud unexpectedly shifts its position in the model space.
Point cloud shifts position when synchronizing changes in a Cloud Worksharing host model in Revit
No
11%-Jul-22
When using Place On Face option, some air terminal families in Revit rotate to align with the face, it is being placed on instead of being aligned with the view.
Some air terminal families are placed at a different rotation after rotating the project north in Re...
Yes
11%-Jul-22
There is a parameter "FM-Geschoss" at most of the elements in German Revit projects. What does it mean?
What does it mean the parameter "FM-Geschoss" in German Revit projects?
No
25-Jul-22
Users reported that shadows are incorrectly displayed in Revit views.
Incorrect shadows in Revit
Yes
25-Jul-22
Linking the Revit model instance and assigning a project parameter to that link instance in the host model and creating a multi-category schedule to report the parameter which is assigned to the link instance.
In schedule, the parameter is not reported and the column stays blank.
Parameter assigned to link instances are not appearing in multi-category schedules created in host R...
Yes
25-Jul-22
When the top of the wall is attached to the specific sloped floor, a small gap is visible between the elements in Revit.
When the top of the wall is attached to the specific floor, a small gap is visible between the eleme...
No
23-Jul-22
When drawing a piping/ductwork system out of a equipment, the system automatically does not show the correct system in Revit.
Piping/Ductwork automatically does not draw the correct system out of a equipment in Revit
Yes
23-Jul-22
The site plan in national coordinates is not displayed correctly in Revit
The site plan is not displayed correctly in Revit
No
22-Jul-22
End Caps don't convert to Fabrication Parts in Revit
No
22-Jul-22
How to read the elevation of a window or door in relation to the Survey point in Revit. Sill height and head height are calculated in relation to the insertion level.
No
22-Jul-22
The phase filter in the wall lists does not work, when upgrading a model in Revit.
The phase filter in the schedules does not work when upgrading a model in Revit
Yes
22-Jul-22
Unable to tag a parameter from a linked Revit model
No
22-Jul-22
No
21-Jul-22
What issues may occur when using Revit in different language versions in one project?
What difficulties may occur when using Revit in different language versions in one project
No
20-Jul-22
Changing a length parameter moves a furniture family containing a mirrored and rotated nested family away from its host in Revit.
Changing a length parameter moves a furniture family containing a mirrored and rotated nested family...
Yes
20-Jul-22
The dormer opening tool does not cut the roof surface properly in the ridge area, the roof should be cut horizontally in this area in Revit.
Dormer opening does not cut the roof correctly in Revit
Yes
20-Jul-22
How to display structural elements from the linked file on top of architectural elements in the Revit host file?
How to display structural elements from linked file on top of architectural elements in Revit host f...
No
20-Jul-22
The appearance of the structural elements is not consistent with the plan view in Revit
Inconsistent appearance of the structural elements in plan view in Revit
No
20-Jul-22
Yes
20-Jul-22
The room color fill , which is created via the color scheme, hides the hatchings from the floor slabs in the background in Revit 2023. This happens regardless of the fill pattern (solid or e.g. diagonal). In Revit 2022, the surface patterns of the floor slabs are always in the foreground.
Room color fill hides the background fill from the Floor slab in Revit
Yes
19-Jul-22
"Constrains are not satisfied" message appears while rotating Reference Line when nested family is aligned to it in Revit. The rotation can be completed when the nested family is not aligned to the Reference Line.
"Constrains are not satisfied" while rotating Reference Line when nested family is aligned to it in ...
No
15-Jul-22
When trying to link a model in Revit from a specific BIM360/ACC project in Autodesk Docs, the following message appears and the link is unloaded:  Linked document Autodesk docs://<Hub name>/<Project name>/...rvt  not found. The link will be unloaded.
"Linked document <filename> not found. The link will be unloaded" when linking a model from a specif...
Yes
15-Jul-22
When using the Shared Reference Point tool to import coordinates, the elevation if above / below the expected value.
Elevation messed up when Importing Shared Coordinate Point in Revit
No
15-Jul-22
How to create a tag family containing and displaying different symbols or images in Revit.
No
14-Jul-22
Users reported that "There has been an unrecoverable error during export" to IFC from Revit.
Yes
14-Jul-22
Slow model performance when using the dimension on a family in Revit
Yes
14-Jul-22
Users reported that the parameter "Elevation" is not correctly translated to German at the element properties in Revit.
Wrong German translation of the parameter: "Elevation" at element properties in Revit
Yes
13-Jul-22
Customer is having a problem while reconnecting the Flex duct back to Air Terminal. There is one scope box in customer's Revit model. When customer applies this scope box to a view and removes the scope box again from the view, this issue is happening. The issue is reproducible on Customer's Revit model.
Not able to reconnect Flex duct back to Air Terminal once Flex duct is disconnected from Air Termina...
No
13-Jul-22
No
13-Jul-22
Yes
13-Jul-22
PDF is not completely vectorized after printing it from Revit. Some elements are exported as vectors, the rest as raster.
PDF is not completely vectorized after exporting it from Revit
No
13-Jul-22
When using the view selection dialog in Revit 2023 or later versions, views are missing from the dialog, or mis-ordered.
Missing sheets from view selection dialog or wrong order in Revit
No
12-Jul-22
Some annotation symbols are missing from specific floor plan views in Revit.
Some annotation symbols are not visible in specific floor plan views in Revit
No
12-Jul-22
Users reported that walls are not cut by roof exporting model to IFC from Revit.
Walls not cut by roof exporting model to IFC from Revit
Yes
11-Jul-22
"Unexpected errors occurred while exporting these elements to the IFC file" when generating a model with bind links to IFC in Revit.
"Unexpected errors occurred while exporting these elements to the IFC file" when exporting model wit...
No
11-Jul-22
Users reported that a crash with CER occurs when switching phase in Revit
Crash occurs when switching phase of Element in Revit
No
11-Jul-22
No
08-Jul-22
How to automatically open indicated Revit models and perform data export (all elements and their properties) from Navisworks to an Excel spreadsheet?
Automatically open indicated Revit models and export data from Navisworks to Excel
No
08-Jul-22
All layers of cavity walls are affected by graphic overrides/filters in Revit. Cavity or air gaps are also overriden if the visibility settings are changed.
Cavity walls not displaying correctly with graphic overrides/filters in Revit
No
08-Jul-22
Is it possible to align a floor located between other floors to their surfaces in Revit?
How to align a floor located between other floors to their surfaces in Revit
No
08-Jul-22
How to work with Revit files when there are multiple versions of Revit installed?
How to work with multiple versions of Revit installed on one system
No
07-Jul-22
"Rebar is placed completely outside of its host" warning after rebar propagation in Revit.
No
07-Jul-22
Images correctly displayed in Revit view are missing in the exported PDF.
Images visible in Revit view are missing after exporting PDF
No
07-Jul-22
The building pad does not cut linked topography in Revit.
The building pad does not cut topography in Revit
No
07-Jul-22
When exporting to DWF from Revit the Hebrew text  is not displayed correctly.
Wrong display of the tags in the Hebrew text when exporting to DWF from Revit
Yes
06-Jul-22
When trying to Bind a linked model appears the error 'A serious error has occurred. It is strongly recommended that you use Save As to save your work in a new file before continuing.' in Revit.
"A serious error has occurred" when trying to bind linked models in Revit
Yes
06-Jul-22
Users reported that some kind of geometry is deformed after exporting STL file from Revit.
Geometry is badly exported to STL from Revit
Yes
06-Jul-22
Is it possible to map old "IfcExportAs" and "IfcExportType" parameter values to new "Export to IFC As" and "IFC Predefined Type" parameters in Revit?
How to map old "IfcExportAs" and "IfcExportType" parameter values to new "Export to IFC As" and "IFC...
No
06-Jul-22
When working in a Revit view which is set to show Phase Filter overrides, certain elements do not override as expected.
Phase Filter overrides do not work for certain elements in a Revit view
No
05-Jul-22
Is it possible to set the view title above the drawing on the sheets in Revit?
Change default position of view titles in Revit
No
05-Jul-22
Only part of the Revit model is visible in Autodesk Viewer.
Part of Revit model shown in Autodesk Viewer
No
05-Jul-22
Wall lines appear in different color in view plan after upgrading Revit model to version 2022.1 or newer version.
Wall lines appear in different color after upgrading to Revit 2022.1 or newer
Yes
04-Jul-22
Users reported that beam system end and start are not aligned to beam system boundary sketch in Revit
Beam system end and start have gap from boundary sketch in Revit
Yes
04-Jul-22
Kicker bracing symbol is longer than the actual beam in Revit
Yes
04-Jul-22
Only a few lines are shown after linking an IFC file in Revit.
Only a few lines are displayed from IFC file linked in Revit
No
01-Jul-22
Bing map Elevation does not match with Revit Elevation when setting the Project Location
Yes
01-Jul-22
Is there any way to add instance parameters for stacked walls in Revit?
How to add an instance parameter for stacked walls in Revit
No
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Message 5 of 10
lim.wendy
Aug 2022
Published Date
Summary
Knowledge Article
Incident Logged
31-Aug-22
Users reported that the message "Invalid number of references" is displayed when using NewDimension Method API in Family document in Revit 2023
"Invalid number of references" while using NewDimension Method API in family document in Revit 2023
Yes
31-Aug-22
Can not hide Top Rail that runs perpendicular to section view in Revit
No
31-Aug-22
How to deactivate, disable analytical panels in Revit 2023?
Deactivating of analytical panels in Revit 2023
No
30-Aug-22
"Failed to import Formit file" when importing Formit file into Revit 2022
No
30-Aug-22
The location of the origin in a DWG is determined by a legend rather than a model view when a sheet is exported in Revit.
Location of the origin in an exported DWG is determined by a legend rather than a model view in Revi...
Yes
30-Aug-22
Users reported that room tags do not always place at the correct orientation in Revit.
Room tag orientation is not correct in Revit
Yes
30-Aug-22
Where to find out details about the revit.exe file data transfer between components
No
29-Aug-22
When editing the boundaries of the materials created with the split face option, it gives an error, and if an element is deleted, all the materials disappear in Revit.
Edit boundaries of split face makes all materials disappear in Revit
Yes
29-Aug-22
Is it possible to modify default bar members releases while runing Analytical Automation for model in Revit 2023
Is it possible to modify default bar members releases while runing Analytical Automation for model i...
No
29-Aug-22
What is the impact of bar member Structural Usage definition on analytical model in Revit
What is the impact of bar member Structural Usage type definition on analytical model in Revit
No
29-Aug-22
How to create a Data Exchange for a published 3D view so that contractors can open that view in Revit? Is it possible to create a workflow between teams based on this feature?
How to make changes in Revit to a published 3D view with a created Data Exchange in Autodesk Docs
Yes
27-Aug-22
Fabrication Part is incorrect when trying to place into Revit
Yes
26-Aug-22
Users have reported that when exporting a DWG from Revit any Phase Status modifier will not show for "new" elements.
DWG Export from Revit does not display Phase Modifier for "new" elements
No
26-Aug-22
What is the recommended workflow between AVEVA PDMS and Revit? How export data from AVAVE PDMS to continue further work in Revit?
Export data from AVAVE PDMS to continue later work in Revit
No
26-Aug-22
Users have reported that when applying some view Filters, Revit will crash with the message "Revit encountered a serious error".
Revit encountered a serious error when applying a view filter
Yes
26-Aug-22
Unable to create a new space tag annotation by the feature Tag by Category in Revit.
Unable to create space tag in Revit
No
25-Aug-22
Users reported that all linked elements are overridden while using Filter for Worksets with the 'contains' rule in the host model with links in Revit.
All linked elements overridden while using Filter for Worksets with the 'contains' rule in the host ...
Yes
25-Aug-22
It's impossible to remove any of the vertical grid lines in a curtain wall with fixed vertical grid lines and no horizontal grid lines in Revit.
Cannot remove vertical curtain wall grid lines in Revit
Yes
25-Aug-22
Connecting two cables to one monitor, font width reduced by 50% when printing to PDF from Revit
Yes
25-Aug-22
Detail Number is missing in Properties for some views in Revit.
No
25-Aug-22
Users reported that when exporting a DWG from Revit, the room boundaries polylines have precision differences causing perimeter and area calculation to be incorrect.
Room boundaries polylines are missing or unclosed in DWG exported from Revit
Yes
25-Aug-22
Certain ceiling patterns in upwards-facing underlays are missing when floor plans are exported to DWG in Revit.
Some ceiling patterns in underlays are missing when floor plans are exported to DWG in Revit
Yes
24-Aug-22
"A serious error has occurred" and workset checkout prompt when changing Boolean parameter in Revit
Yes
24-Aug-22
Text overlapping for PDF Export compared to Print to PDF for particular texts in Revit
Yes
24-Aug-22
Windows Defender ATP alerts about active malware of type Trojan:Win32\/Vigorf.A in Revit 2023
Windows Defender ATP alerts about active malware in Revit 2023
No
23-Aug-22
How to assign the default path for libraries in Revit to content from a previous version?
How to assign default path for libraries to content from a previous Revit version
No
23-Aug-22
Users reported that when making changes in a Revit 2023 model in the realistic 3D view, the model turns different colors.
Modifying elements in Revit results in color changes in 3D realistic view
Yes
23-Aug-22
A user running various versions of Revit sees a different number of available BIM 360/ACC cloud projects from the Home page. For example, there are 8 projects available in Revit 2021 and 6 projects in Revit 2023.
Difference in number of available cloud projects from Home page in different Revit versions
No
22-Aug-22
How to define releases for analytical members in Revit.
No
22-Aug-22
Spaces are removed when Phases are merged in Revit
No
22-Aug-22
In structural columns the cut pattern is not visible if columns are shorter than 1219mm in Revit
Structural column cut pattern is not visible if columns are shorter than  1219mm in Revit
Yes
22-Aug-22
Users reported that shared parameters cannot be displayed under fields for Structural Truss Schedule in Revit.
Unable to display shared parameters under fields in Structural Truss Schedule in Revit
Yes
19-Aug-22
45° Wye Tap fitting not converted as expected when using Design to Fabrication in Revit
No
19-Aug-22
What is the difference in the built of window families that some are not recognized by energy analyses in Revit?
What is the difference in built of window families that some are not recognized by energy analyses i...
No
18-Aug-22
When installing Geberit plug-in it is not displayed in Revit 2023.
Geberit plug-in is not displayed in Revit 2023
No
17-Aug-22
Customer has created a Floor Tag Family with the parameter 'Elevation at Top Core' and inserted it in project and reported that the family is not any corresponding returning the value.
Floor Tag Family with the parameter 'Elevation at Top Core' not able to return corresponding value w...
No
17-Aug-22
What are the differences in exporting gbXML files when comparing Revit 2023 and 2022?
gbXML file export differences when comparing Revit 2023 and 2022
No
17-Aug-22
How to export Revit host model with linked IFCs into one IFC file ?
No
17-Aug-22
After creating a Room Annotation Tag and adding multiple parameters to the label, some of them are not displayed in the Revit project.
Some parameters are not displayed in Room Annotation Tag in Revit
No
17-Aug-22
When a structural column is cut in an elevation view, the column is not shown as cut, while architectural columns and other elements are cut in the elevation view in Revit.
The cut pattern from structural columns is not visible in the elevation views in Revit
Yes
17-Aug-22
Underlay walls are shown in PDF exported using default PDF exporter in Revit
Yes
17-Aug-22
Material texture on the rounded edge is displayed in a different direction in Revit
Material on the rounded edge is displayed in a different direction in Revit
No
16-Aug-22
How to Adjust Revit Circuit Tags to show slashes instead of commas.
No
16-Aug-22
Despite a correctly configured ApplicationPreferences.xml file, it is impossible to synchronize only the central model without links to the Vault server using the Vault add-on in Revit. The dataset is located on the Revit Server to which the path is pointed in the Vault add-in. Synchronizing the central model with the links can take tens of minutes. Synchronizing only the changes in the central model would speed up the process significantly.
Cannot synchronize only the central model without links to the Vault server using the Vault add-on i...
Yes
16-Aug-22
Revit certification course materials are not opening in Revit
No
13-Aug-22
"Some error Occurred. . . Please Try Again" when launching Revit
No
13-Aug-22
Openings in sloped floors do not export to IFC in Revit
Yes
12-Aug-22
Users reported that the Background processes dialog displays "Steel connection creation calculation failed" when trying to create a steel connection.
"Steel connection creation calculation failed" message displays in Revit
No
12-Aug-22
Is the Data Exchange tool connected with the Revit model to show the changes done in the project automatically?
Is Data Exchange tool connected with the Revit model to show the changes done automatically
No
11-Aug-22
Unable to permanently delete macro from Revit.
No
10-Aug-22
When creating a custom .ini file for a Revit deployment, some file location paths will not update
Custom .ini file is not making all the changes expected when deploying Revit
No
09-Aug-22
How to export Revit model to shape file?
No
08-Aug-22
"Revit could not execute the external command" error while model export from Revit 2022 to Robot Structural Analysis 2022
"Revit could not execute the external command" error while model export from Revit 2022 to Robot Str...
No
08-Aug-22
Elements missing from the view when specific view template is applied in Revit.
No
08-Aug-22
Users reported that object snap does not detect snap points at creating MEP elements from linked RVT files.
When creating MEP elements object snap does not detect snap points of elements from linked Revit fil...
Yes
08-Aug-22
Yes
08-Aug-22
Yes
06-Aug-22
When trying to open a Revit Server model in Revit, the following errors occur: This operation could not be completed… / Revit could not create a local file from…
“Revit could not create a local file from RSN://…” error when opening Revit Server model
No
06-Aug-22
No
05-Aug-22
Revit crashes regularly on a particular machine, after installing the update Revit 2022.1.3.
Regular program crashes after installing the Update Revit 2022.1.3.
No
04-Aug-22
How to change the size or color of snap objects in Revit?
Yes
04-Aug-22
Illuminated decals appear to be plain white surfaces in realistic mode in Revit.
Yes
04-Aug-22
Mechanical Equipment elements get unexpectedly displayed in a floor plan view in Revit, even though they are above cut plane.
Mechanical Equipment elements above cut plane unexpectedly displayed in a floor plan view in Revit
No
04-Aug-22
Straight duct is shorter when converted to Fabrication part including Cap fitting in Revit
Yes
04-Aug-22
Users reported that wall exported to IFC appears larger than in Revit
Wall exported to IFC appears larger than in Revit
Yes
03-Aug-22
All text is missing from DWG exported from Revit.
Yes
03-Aug-22
Users reported that the "Select all instances/ Visible in View or in Entire Projekt" options are grayed out at trying to use them in edit family mode at in-place families for groups in Revit 2022
Enable "Select All" for in-place edit mode in Revit
Yes
03-Aug-22
Linked CAD getting "hosted" by level and cannot be moved vertically in the elevation views in Revit 2023.
Linked CAD cannot be placed correctly in elevation views in Revit 2023
No
03-Aug-22
Elements are not visible when importing IFC model with user IFC template in Revit.
Missing elements when importing IFC model with user IFC template in Revit
No
03-Aug-22
Revit is hanging during model upgrade. When the progress bar indicates around 70%, Revit freezes and does not respond.
No
02-Aug-22
"Revit encountered a serious error. The current action could not be completed" when upgrading a model in Revit. Model does not upgrade.
"Revit encountered a serious error. The current action could not be completed" when upgrading a mode...
Yes
02-Aug-22
Color scheme is displaying the boundary to the wall center line when the area is calculated to the internal face of the wall in Revit.
Color scheme is displaying the boundary to the wall center line when the area is calculated to the i...
Yes
02-Aug-22
Users reported that the "Phase filters" dialog shows duplicated filters both in German and in English: "Alle anzeigen" and "Sow all" in German Revit templates:
Duplicated phase filters both in German and in English: "Alle anzeigen" and "Sow all" in German Revi...
Yes
02-Aug-22
When printing layout drawings containing hatches and filters in Revit, the hatches from the resulting PDF are cut oddly and only partially printed.
Hatches applied using filters are partially printed in Revit
No
02-Aug-22
Customer is using Revit P&ID modeler to create Piping in Revit. He wants to map P&ID properties with Revit parameter. He has created Shared Parameters of type 'Pipe Dimension' and these are not being visible in the dropdown in P&ID modeler settings.
How to map P&ID properties to Revit Parameter in Revit P&ID modeler
No
02-Aug-22
The line sequence is no longer displayed correctly, when exporting or printing to PDF  or exporting to dwfx from Revit.
Incorrect line display of overlapping lines in PDF export from Revit
Yes
02-Aug-22
Lighting analysis is missing graphic data or does not appear in plan view.
Lighting analysis graphic results do not show up completely on plan view in Revit
Yes
01-Aug-22
Users reported that elements imported from IFC are transformed in 3D space after editing them in Revit.
Elements imported from IFC are moved in 3D space after editing them in Revit
Yes
01-Aug-22
How to perform gas calculations in Revit
No
01-Aug-22
Rectangular symbol is appearing in Revit P&ID modeler while selecting line from P&ID.
While selecting line, rectangular symbol is appearing instead of line in Revit P&ID modeler
Yes
Wendy Lim
Rails Summit
Message 6 of 10
lim.wendy
Sep 2022
Published Date
Summary
Knowledge Article
Incident Logged
01-Sep-22
When the local server crashed, is it possible to recover lost changes/operations in the Revit model?
How to recover lost changes/operation in Revit model when local server crashed
No
02-Sep-22
Imaginary boreholes - "ghosts" appear away from the actual borehole/plate in Revit
Imaginary boreholes appear away from the actual borehole/plate in Revit
No
02-Sep-22
Painting area is not specified and is greyed out in specific model in Revit
Painting area is not specified and is greyed out in Revit
No
06-Sep-22
Cannot export a Revit sheet to PDF.
Sheet is not exported to PDF from Revit
No
07-Sep-22
"A Pad can't extend beyond the edge of a Toposurface" when adding a Building pad in Revit to a linked Topography from BIM 360.
"A Pad can't extend beyond the edge of a Toposurface" when adding a Building pad to a linked Topogra...
No
07-Sep-22
Users reported that the cutout shown in the Family Editor is not visible after loading the Family into Revit project.
Cutout shown in the Family Editor is not visible after loading the Family into Revit project
Yes
07-Sep-22
Yes
07-Sep-22
Yes
07-Sep-22
Yes
07-Sep-22
Yes
07-Sep-22
Revit crashes with CER (Customer Error Report) when selecting specific elements in a model.
Revit crashes with CER when selecting specific elements in a model
No
07-Sep-22
No
08-Sep-22
Users reported that Project Information parameter value is empty for Varying Rebar set in multicategory schedule in Revit.
Project Information parameter empty for Varying Rebar set in multicategory schedule in Revit
Yes
08-Sep-22
Users reported that roof area and volume not correct in exported IFC from Revit.
Roof area and volume not correct in exported IFC from Revit
Yes
08-Sep-22
Turning on or off the 3D Grids affects the display of Ambient Shadows in the Revit model.
Yes
08-Sep-22
What are the reasons for the changes or lack of changes in system requirements between successive versions of Revit?
What are the reasons for the changes or lack of changes in system requirements between successive ve...
No
09-Sep-22
When trying to bind Revit links into a Revit model a "serious error" appears.
Binding link makes Revit crash
Yes
09-Sep-22
How to convert linked IFC into RVT model in Revit?
Convertion of linked IFC into RVT model in Revit
No
09-Sep-22
IFC cannot be opened properly as only lines are visible in Revit 2020.
IFC cannot be opened properly in Revit
No
09-Sep-22
Topography created from CSV is not aligning with survey coordinates in Revit.
Topo is not aligning with survey coordinates in Revit
No
09-Sep-22
What are the recommended ways to work in Revit on a single cloud workshared model with other external contractors? How to control the changes made by them?
Control of changes made by external contractors in a single cloud workshared model in Revit
No
12-Sep-22
Users reported that  "Disable shared position" message shows repeatedly when trying to disable shared position in Revit links. Every time you change the place of a link that had a previous shared position to "not shared", a message will display asking to disable shared position.
"Disable shared position" shows repeatedly when trying to disable shared position in Revit links
Yes
14-Sep-22
How to override the appearance of a stair run or landing that is placed above the cut plane in Revit?
How to override appearance of stair run or landing that is placed above the cut plane in Revit
No
14-Sep-22
The error "Revit has experienced an unexpected error. The operation has been canceled to protect your project from corruption." is triggered when parts of the drawing view are to be moved, rotated or otherwise edited.
Revit crashes when moving, editing or rotating a drawing
Yes
15-Sep-22
Analytical model generated with warnings while Analytical Automation in Revit 2023
No
16-Sep-22
Connection issue and crash when using Load Autodesk Family from the cloud in Revit.
No
16-Sep-22
Users reported that hidden lines are not visible for rectangular Fabrication ducts in Revit plans.
Hidden lines not visible for rectangular Fabrication ducts in Revit plans
Yes
19-Sep-22
Elements from the link are not displayed according to the used settings in Revit.
Incorrect visibility of the links using "Linked by view" option in Revit
No
19-Sep-22
After closing the workset to which the elements inside the linked RVT model are assigned, no automatic regeneration is performed in Revit. Closing the workset to which the entire RVT link is assigned works correctly, but closing/opening the workset to which elements inside the RVT link are assigned causes some elements not to be displayed correctly.
No automatic regeneration after closing the workset to which elements inside the linked RVT model ar...
Yes
20-Sep-22
Custom Revit.ini file is being deleted and replaced by the default file in Revit.
No
21-Sep-22
"Saving is not allowed in the current application mode" when trying to upgrade Revit Cloud model to 2023 version in BIM 360
"Saving is not allowed in the current application mode" during cloud model upgrade to Revit 2023
Yes
21-Sep-22
"There is circular chain of reference…" error displayed when creating a model in place (sweep) railing by setting stairs as a reference plane in Revit
"There is circular chain of reference…" error displayed when creating a model in place (sweep) raili...
Yes
21-Sep-22
Advance Steel Extension is not present in Add-Ins tab in Revit.
Advance Steel Extension missing in Add-Ins tab in Revit
No
21-Sep-22
Slow performance when selecting objects in 'reveal hidden elements' mode in Revit.
Slow performance when selecting objects in Revit
Yes
21-Sep-22
The assignment of the levels to the elements does not work in IFC exported from Revit.
The assignment of the levels does not work in IFC exported from Revit
No
21-Sep-22
Unable to mirror the project in Revit
Yes
21-Sep-22
The snaps settings are lost each time a project is closed in Revit.
Snaps settings are not saved in Revit
Yes
22-Sep-22
When trying to edit a shaped floor Revit crashes.
Revit crashes when editing a shaped floor
Yes
22-Sep-22
When creating a graded region the Cut and Fill values are not populated in Revit
No
23-Sep-22
"The following nested links will not appear because their Reference Type is set to Overlay" while linking a RVT file into a Revit project.
"The following nested links will not appear because their Reference Type is set to Overlay" while li...
No
23-Sep-22
How to change camera position for the specific 3D View in Revit?
How to change camera position in Revit
No
23-Sep-22
Is it possible to create inclined rebar set in Revit?
How to create inclined rebar set in Revit
No
23-Sep-22
Is it possible to omit openings when creating fabric sheets in Revit?
How to omit openings when creating fabric sheets in Revit?
No
23-Sep-22
When importing or linking a PDF or image, the file is not shown when the Draw Layer is set to Background in Revit.
When a PDF or image is set to Background the image does not appear in Revit
No
26-Sep-22
Change in the 'Elevation at the bottom' parameter after switching the join order of foundation and wall in Revit.
Change in the 'Elevation at the bottom' parameter after switching the join order of foundation and w...
Yes
26-Sep-22
Users reported that dimension line placed on Floor Section does not update when changing floor type in Revit.
Dimension line placed on Floor Section does not update when changing floor type in Revit
Yes
26-Sep-22
Users reported that missing elements in IFC4 exported from Revit.
Missing elements in IFC4 exported from Revit
Yes
26-Sep-22
When working or navigating in a specific Revit model, the program crashes with an error: "A serious error has occurred. It is strongly recommended that you save your work in a new file before continuing..."
Program crash with a "A serious error has occured" error when working in a specific model in Revit
No
27-Sep-22
Folders not visible when trying to link or save BIM 360 models into Revit after installing Publish NWC Add-in for Revit
Cannot link / save BIM 360 models after installing Publish NWC add-on for Revit
No
27-Sep-22
Users reported that unloading an NWD or NWC coordination model and re-opening the Revit host file triggers an unexpected warning "Unable to load coordination model" in Revit 2021.
"Unable to load coordination model" when re-opening the Revit host model after unloading a coordinat...
Yes
27-Sep-22
No
27-Sep-22
DWG file exports with wrong hatch or fill from Revit
Yes
27-Sep-22
IFC properties do not export from Revit for a specific file
Yes
27-Sep-22
Yes
27-Sep-22
Yes
27-Sep-22
Yes
27-Sep-22
Yes
27-Sep-22
Yes
27-Sep-22
Yes
27-Sep-22
Some annotations are missed in dependent view though they are existing in the main view in Revit (open the dependent first, even printed without them).
Missing dimensions in dependent view in Revit
Yes
28-Sep-22
Block geometry from AutoCAD looks different than in AutoCAD after linking DWG file in Revit.
Block geometry from AutoCAD looks different after linking DWG file in Revit
No
28-Sep-22
How do you investigate the factors that influence synchronization speed outside of Revit?
No
28-Sep-22
Is it possible to exclude IFC-classes while linking IFC files in Revit?
Is it possible to exclude IFC-classes while linking IFC-files in Revit
No
28-Sep-22
When Installing Revit Server, the following error appears: Operating System Unsupported
Operating System Unsupported error when installing Revit Server
No
30-Sep-22
The ceiling grid pattern is not displayed in reflected ceiling plan, but does show up in plan view.
Ceiling grid not visible in Revit reflected ceiling plan view.
No
30-Sep-22
When cropping or uncropping a view, or when zooming in / out the view doesn't change.
Crop/Uncrop and Zoom in/out doesn't change view in Revit.
No
Wendy Lim
Rails Summit
Message 7 of 10
lim.wendy
Oct 2022
Published Date
Summary
Knowledge Article
Incident Logged
31-Oct-22
How to create timber wall framing in Revit
No
31-Oct-22
When attempting to print a section view where a Topography surface is showing, Revit freezes up and print never completes.
Revit freezes when attempting to print a section view with Topography showing
No
29-Oct-22
Users reported that exporting a model to IFC from Revit 2023 and linking it back to the same host file, the two models are not aligned.
Wrong alignment and rotation when linking back exported IFC into the same host in Revit 2023
Yes
28-Oct-22
Appearance Profiler settings are lost when switching to the Clash Detective Report tab in Navisworks.
No
28-Oct-22
No
28-Oct-22
No
28-Oct-22
Missing columns from particular views in Revit.
Columns disappeared from particular levels in Revit
No
28-Oct-22
Users reported that wall is misplaced exporting model to IFC4 Reference View from Revit.
Misplaced wall exporting to IFC4 Reference View from Revit
Yes
28-Oct-22
Walls have different hatch patterns although they are of the same type in Revit.
Walls have different patterns although they are of the same type in Revit
No
28-Oct-22
After acquiring coordinates from a linked CAD file in Revit, the coordinate values are different from the ones in the CAD file opened in AutoCAD.
Wrong coordinate values after acquiring coordinates from a linked CAD file in Revit
No
27-Oct-22
Users reported that "negative" geometry is exported to IFC from Revit
Negative geometry exported to IFC from Revit
Yes
27-Oct-22
When trying to change the sash material of a specific window family in Revit, the parameter doesn't seem to change the display of the element in the view.
Unable to change sash material through an associated parameter of a specific window family in Revit
No
26-Oct-22
Users reported that shared sites in links cannot be modified when linking a cloud model in Revit.
"Shared Sites in the link ** cannot be modified" when linking a cloud model in Revit
Yes
26-Oct-22
Door opening symbol is not visible in some plans in Revit.
Door swing symbol is not visible in some plans in Revit
No
26-Oct-22
How to create the recess or gap in the wall in Revit?
Function for the recess or gap creation in the wall in Revit
No
26-Oct-22
PDF creation in Revit and further viewing of PDF is slow.
PDF creation in Revit is slow
No
26-Oct-22
Wireframe appearance of Plant 3D elements when imported into Revit
Yes
26-Oct-22
Users reported that rotating Lighting fixture and Electric Equipment families with the disjoin option activated in Revit, the placement after rotation is wrong.
Wrong placement when rotating Lighting fixture and Electric Equipment families in Revit
Yes
24-Oct-22
Users reported that "This computer does not have enough memory to open" message is displayed when saving an upgraded Revit model.
"This computer does not have enough memory to save" message when saving an upgraded Revit model
No
24-Oct-22
Yes
24-Oct-22
How export to IFC coordinates with decimals from Revit
No
24-Oct-22
Insulation is not displayed when applied to Fabrication pattern CID 480 in Revit
Yes
21-Oct-22
"Hollow core slab does not support reinforcement" message appears when trying to reinforce the hollow slab with Precast features in Revit.
"Hollow core slab does not support reinforcement" warning appears in Revit
No
21-Oct-22
Background process :  Failed to calculate System Volumes or Modification calculation to steel members failed in Revit
Background process :  Failed to calculate System Volumes or Modification calculation to steel member...
No
21-Oct-22
How to model precast stair run with custom "teeth" at the beginning and at the end in Revit?
How to model stair with custom notches in Revit
No
21-Oct-22
Is it possible to import IFC model to certain phase in Revit?
No
21-Oct-22
Users reported that the volume of floors is incorrectly calculated when cutting them with voids in Revit
Wrong volume of floors when cutting them with voids in Revit
Yes
21-Oct-22
Disturbing additional line after importing Revit model in the host file
Disturbing additional line after linking Revit model in the host file
No
20-Oct-22
When printing from Revit to pdf, in the zone where an opening is place, is not always visible the color fill of the  pipein the PDF but yes in the Revit model.
The solid fill on pipes is not printed when a void is placed in Revit
Yes
20-Oct-22
When creating an analytical model in Revit 2023 many elements are missing
No
20-Oct-22
No
20-Oct-22
No
20-Oct-22
No
20-Oct-22
No
19-Oct-22
When hitting Reload for a model that is hosted on BIM 360 an error appears, "Cannot open linked document autodesk docs://<filename>.  The link will be unloaded" and the link fails to load.
"Cannot open linked document autodesk docs://<filename>.  The link will be unloaded" appears when hi...
No
19-Oct-22
Subregions defined on toposurface are not visible in Revit.
Subregions are not visible in Revit
No
18-Oct-22
Dimensions are deleted giving the error message "one or more dimension references are or have become invalid" when editing shafts in Revit 2023
Dimensions are deleted giving the error message "one or more dimension references are or have become...
Yes
18-Oct-22
Incorrect display of Insulated Fabrication Elements when printed to PDF using Vector processing in Revit
Incorrect display of Insulated Fabrication Elements when printed to PDF using Vector processing in R...
Yes
18-Oct-22
Unable to hide shared nested family after loading the family to Revit project and turning off the visibility parameter for the host family.
Unable to hide shared nested family after loading host family to Revit project
No
17-Oct-22
Cannot create a local model from Revit Server central file using the command line.
Cannot create a local model from Revit Server central file using command line
No
15-Oct-22
Cannot export specific filter option from Autodesk Point Layout in Revit
No
14-Oct-22
How to batch reload files on BIM 360 or ACC from Revit
No
14-Oct-22
How to collaborate multiple Revit models onto BIM 360 or Autodesk Construction Cloud
How to collaborate multiple Revit models to BIM 360 or ACC
No
13-Oct-22
Users reported that "A serious error has occurred. The current action has been cancelled" is displayed upgrading model to Revit 2023
"A serious error has occurred. The current action has been cancelled" upgrading model to Revit 2023
Yes
13-Oct-22
It is not possible to copy and paste elements aligned to selected views in Revit.
Cannot copy and paste elements aligned to selected views in Revit
No
13-Oct-22
How to model objects with a complex shape in Revit?
No
13-Oct-22
Users reported that Ifcopeningelements not turned off from display on plan views by Visibility Graphics in Revit
Yes
13-Oct-22
The ability to edit Keynotes in the Revit project environment
No
12-Oct-22
Users reported that synchronizing fails during reload latest phase in Revit
"Revit cannot reconcile the differences between your local file and the central model..." during Syn...
Yes
12-Oct-22
Users reported that the Associated Models window is empty after opening it from the Issues Tab in Revit.
Associated Models window from Issues tab is empty in Revit
Yes
12-Oct-22
Users reported inconsistent display of unit symbol (L/s) for Flow in Revit German version.
Inconsistent display of unit symbol (L/s) for Flow in Revit German version
Yes
12-Oct-22
User reported missing data in IFC exporting sloped \ elevated floor from Revit
Missing data in IFC exporting sloped \ elevated floor from Revit
Yes
12-Oct-22
Zone of Influence subcategory cannot be disabled when publishing to Assemble from Revit
Yes
11-Oct-22
Users reported that the "System.TypeLoadException[...]" message is displayed while attempting to launch Dynamo and Dynamo Player from Revit. Dynamo cannot be started.
"System.TypeLoadException[...]" while attempting to launch Dynamo and Dynamo Player from Revit
No
11-Oct-22
Yes
11-Oct-22
How to get the location (insertion point) of the doors placed in facades in Dynamo for Revit?
How to get the position of the doors placed in facades in Dynamo for Revit
No
11-Oct-22
How to sort elements by their location, for example, by level or X, Y coordinates in Dynamo for Revit?
How to sort elements by their location in Dynamo for Revit
No
11-Oct-22
Revit cannot be installed on a newly installed and updated Windows 10.
Revit cannot be installed on a newly installed Windows 10
No
10-Oct-22
Is it possible to use the Revit Server workflow with Revit adding cryptographic information protection on a public network?
Does the Revit Server workflow support cryptographic information protection?
No
10-Oct-22
Is the network traffic between Revit client machines and Revit Server encrypted?
Network traffic encryption between Revit client machines and Revit Server
No
10-Oct-22
Users reported that rebar constraints are not respected for all rebars in the layout in Revit.
Rebar constraints are not working for all elements from rebar set in Revit
Yes
8-Oct-22
"Missing data: Categories, Type or Instance" when using Parameter Service on ACC platform
No
7-Oct-22
Exporting a set of views to PDF takes a long time in Revit.
No
7-Oct-22
Warning "Line in Sketch is slightly off axis and may cause inaccuracies." appears when Project North is rotated in Revit.
Warning about the “off-axis” elements appears when Project North is rotated in Revit
No
5-Oct-22
Creation of part on framework in a Revit model not possible because the "Invalid shape found in original. Parts could not be created." message appears.
"Invalid shape found in original. Parts could not be created." message appears when trying to create...
Yes
5-Oct-22
Is it recommended to change the height of the datum (reference point) during the design process in Revit?
Change the height of the datum (reference point) during the design process in Revit
No
5-Oct-22
Freeze for a few minutes when selecting or moving elements from a specific Category in Revit.
Freeze when selecting or moving elements from specific Category in Revit
Yes
5-Oct-22
Is it possible to automatically number elements in Revit?
How to automatically number elements in Revit
No
5-Oct-22
Is it possible to import layers' names, colors, and thickness from the DWG file to Revit?
How to import layers names, colors and thickness from DWG file to Revit
No
5-Oct-22
Missing walls while analytical automation in Revit 2023
No
5-Oct-22
No
5-Oct-22
No
5-Oct-22
No
5-Oct-22
No
5-Oct-22
Users reported that NWC exporter creates larger file sizes from Revit 2022 than from previous Revit versions.
NWC exporter creates larger file size from Revit 2022 than from previous Revit versions
Yes
5-Oct-22
How to print a schedule to PDF without Title Sheet in Revit?
Printing of schedule to PDF in Revit
No
5-Oct-22
Rebar schedule placed on sheet is empty in Revit 2023
No
5-Oct-22
Revit crashes when using third-party add-in Bimsync features.
No
5-Oct-22
How to split and resize a schedule in Revit?
Spliting and resizing of schedule in Revit
No
4-Oct-22
"An exception has occurred when opening the dialog" warning appears when numbering rebars in Revit.
Yes
4-Oct-22
Inserting a door in a thin wall is impossible in Revit.
Cannot insert a door in a thin wall in Revit
No
4-Oct-22
Model stuck while opening in Revit on Windows 11
Yes
4-Oct-22
Yes
4-Oct-22
Yes
4-Oct-22
Yes
4-Oct-22
Yes
4-Oct-22
Yes
4-Oct-22
Yes
4-Oct-22
Sections and elevations are removed from sheets when rotated in Revit
No
4-Oct-22
Type IfcGUID not exported to IFC from Revit
No
3-Oct-22
Users reported that demolished ducts join to new construction ducts in Revit.
Existing demolished Ducts and pipes join to New Construction Ducts/Pipes in Revit
Yes
1-Oct-22
After acquiring coordinates in Revit, the True North rotation does not match the source file.
Acquired Coordinates do not match True North rotation in Revit
No
Wendy Lim
Rails Summit
Message 8 of 10
msb-bwga
Worthless
Message 9 of 10
lim.wendy
November 2022
Published Date
Summary
Knowledge Article
Incident Logged
30-Nov-22
"Unable to create shared views" appears while attempting to create a shared view from a central file or linked central file from Revit Server in Revit.
"Unable to create shared views" from a central file or linked central file from Revit Server in Revi...
No
29-Nov-22
Users reported that the"Export Type to IFC As" and "Type IFC Predefined Type" parameters lost their connectivity to IFC Schema mapping after installing Revit 2023.1 or 2023.1.1 update.
"Export Type to IFC As" and "Type IFC Predefined Type" parameters lost their connectivity to IFC Sch...
No
29-Nov-22
Pipes are not created correctly when linking IFC file using specific template in Revit
After linking IFC file, pipes are not shown correctly using specific template in Revit
No
29-Nov-22
Users reported that using Fabric Area feature in a split wall in Revit creates duplicated fabrics.
Double layer fabric area in a split wall in Revit
Yes
29-Nov-22
Geometry of Fabrication pattern CID 533 breaks when editing the item in Revit
Yes
29-Nov-22
Users reported unexpected circular shadow in a realistic view after the upgrade of the model to Revit 2021 or a newer version.
Unexpected circular shadow in realistic view after upgrade of the model to Revit 2021 or newer versi...
Yes
28-Nov-22
Is it possible to create a multi-segment void that fits the family dimension in Revit?
How to create a multisegment void that fits the family dimension in Revit
No
28-Nov-22
How to request support for the Autodesk Revit add-in, Twinmotion for Revit?
No
25-Nov-22
Is it possible to add cost parameter for different types and diameters of pipes in Revit?
How to add cost parameter for different types and diameters of pipes in Revit
No
25-Nov-22
New coordinates for the model have been established. How to correctly adjust model position in Revit?
How to adjust model position in Revit after coordinates review
No
25-Nov-22
Is it possible to set the position of the analytical beam line to top in Analytical Automation in Revit 2023?
How to change the position of the analytical beam line in Analytical Automation in Revit 2023
No
25-Nov-22
How to export Room boundaries as polylines to DWG from Revit. When exporting the room boundaries to DWG only
Yes
25-Nov-22
Is it possible to read in tags the elevation of the MEP elements according to the internal origin in Revit?
How to read in tags the elevation of the MEP elements according to the internal origin in Revit
No
25-Nov-22
Users reported that IFC PROVISIONFORVOID element not showing in floor plan in Revit.
IFC Provision for Void element not showing in floor plan in Revit
Yes
24-Nov-22
"Autodesk Desktop Connector Update Required" error received after updating to Revit 2023.1
No
24-Nov-22
Revit closes suddenly after launch in Windows 11
No
23-Nov-22
Users reported that IFC.RVT model is wrongly rotated linking it to project with rotated True North in Revit.
Wrongly rotated IFC.RVT linking it to project with rotated True North in Revit
Yes
21-Nov-22
Is it possible to automatically reload edited families in Revit?
How to automatically reload edited families in Revit
No
19-Nov-22
Users reported that it is not possible to save Project Address data in IFC export window in Revit
Impossible to save Project Address data in IFC export window in Revit
Yes
18-Nov-22
How to create easily adaptable schedules for room books in Revit?
How to create intelligent schedules for room books in Revit
No
18-Nov-22
Window does not appear when selecting Design Option tool in Revit
No
17-Nov-22
Structural column with custom defined family is missing when export model from Revit to Advance Steel
Column with custom family disappears when export model from Revit to Advance Steel
No
17-Nov-22
Room separation lines and walls are not bounding rooms in Revit. They seem to be ignored by Revit.
No
17-Nov-22
The family tag displays a question mark not the parameter in Revit
The family tag displays a question mark in Revit
No
16-Nov-22
When attempting to edit or delete a group in Revit, "a serious error has occurred" appears and the group fails to delete
"A serious error has occurred" when editing or deleting a group in Revit
No
16-Nov-22
When exporting to PDF from Revit the filled regions with black lines, are exporting in gray colour.
Filled regions line hatch is printed gray instead of black to PDF from Revit
Yes
16-Nov-22
How to create multiple circuit home run arrows in Revit when multiple circuits are part of one family?
No
16-Nov-22
Is it possible to automatically join elements using Dynamo for Revit?
How to join elements geometry in Dynamo for Revit
No
16-Nov-22
Is it possible to manage issues between teams directly in Revit?
How to manage issues between teams directly in Revit
No
16-Nov-22
Symbols of not editable elements in 3D views are long after using Selection Box option in Revit.
Worksharing lines in 3D views are too long after using Selection Box option in Revit
No
15-Nov-22
When opening a Revit model the error "Elements need to be disconnected" is seen.
"Elements need to be disconnected" when opening a Revit model
No
15-Nov-22
Filled Region from linked RVT file covers the 3D elements from the host model in plan view in Revit. How to move the filled region to the back?
Filled Region from linked RVT file covers the 3D elements from host model in plan view in Revit
Yes
15-Nov-22
How to print a part of view from a Revit to work on a paper drawing?
How to print a part of view from a Revit?
No
15-Nov-22
Is it possible to set different view ranges in one floorplan in Revit?
How to set different view ranges in one floor plan in Revit
No
14-Nov-22
'Analytical panel in not planar' error appears although association is removed in Revit.
Analytical panel in not planar error appears although association is removed in Revit
Yes
14-Nov-22
How to get access to the Revit LIVE Editor for Revit?
No
14-Nov-22
Unable to connect Fabrication pattern 760 as end element to straight in Revit
Unable to connect Fabrication pattern 760 as end element to straights in Revit
No
8-Nov-22
The properties palette or other dialog boxes are missing or offscreen/behind in Revit
Dialog boxes appear off screen or behind Revit
No
8-Nov-22
Users reported that the Decimal symbol/Digit grouping is not reflected in the Properties palette in Revit.
Digit grouping not reflected for Properties palette in Revit
Yes
8-Nov-22
Project or shared parameters don't update in railing schedules in Revit.
Yes
8-Nov-22
Unable to see some Structural elements on screen in Revit plan, or elements appear incorrectly (example: hidden lines show as solid).
Structural elements appear incorrectly or are missing in plan view in Revit
Yes
7-Nov-22
The background color scheme line based fill pattern does not print to PDF when are walls in the lower level in view range in Revit.
The color scheme does not print to PDF when are walls in the lower level in view range in Revit
Yes
5-Nov-22
Models IFC and DWG  are located at the wrong insertion point when compared with source IFC after export from Revit
Models IFC and DWG  are located at the wrong insertion point after export from Revit
No
4-Nov-22
Hidden lines related to linked models are not always visible in dependent views in Revit.
Hidden lines related to linked models are not visible in some dependent views in Revit
Yes
4-Nov-22
Is it possible to create a beam family using a custom profile based on DWG drawing in Revit?
How to create a structural framing family with a custom profile from DWG file in Revit
No
4-Nov-22
Missing properties when roundrip exporting/importing an IFC containing pipes in Revit
No
3-Nov-22
"System.ArgumentNullException" message while starting Dynamo from Revit. Dynamo cannot be started.
No
3-Nov-22
Access to the online library 'Load Autodesk Family' is not possible in Revit.
Access to the online library is not possible in Revit
No
3-Nov-22
How to transfer 2D lines from a non-annotation family to an annotation family in Revit?
How to transfer 2D lines from non-annotation family to an annotation family in Revit
No
3-Nov-22
Missing Project Browser in a Revit model.
Yes
3-Nov-22
The railing does not show cut in section views with a split segment in Revit.
The railing does not show cut in section views in Revit
Yes
3-Nov-22
When trying to right click in the wall drag point in Revit, a new wall gets selected instead of the pop-up properties.
Wall drag point cannot be selected in Revit
No
Wendy Lim
Rails Summit
Message 10 of 10
lim.wendy
December 2022
Published Date
Summary
Knowledge Article
Incident Logged
29-Dec-22
 How to enter the U-value for system families in Revit?
No
29-Dec-22
How to enter the U-value for loadable families in Revit?
No
29-Dec-22
How to enter the U-value to export it to IFC from Revit?
No
28-Dec-22
Users reported that some MEP elements got disconnected at upgrading specific file from Revit 2021 to 2022
"The family is connected in a network and can no longer keep the connectivity." message at upgrading...
Yes
24-Dec-22
How to use FormIt for modelling of additional elements in Revit?
How to use FormIt for modelling in Revit
No
22-Dec-22
Family exported as a few components to IFC from Revit
No
22-Dec-22
Which product versions of Revit are officially supported by Autodesk?
Which are the officially supported product versions of Revit?
No
21-Dec-22
IfcVolumetricFlowRateMeasure unit change needed when exporting IFC from Revit.
IfcVolumetricFlowRateMeasure unit in IFC from Revit
No
21-Dec-22
Keyboard input always hangs for a few seconds in all programs when Revit is started.
Keyboard input always hangs for a few seconds when Revit is started
No
20-Dec-22
"Unhandled exception has occurred in a component in your application" when running Batch Publisher in Revit.
"Unhandled exception has occurred in a component in your application" when running Batch Publisher i...
No
20-Dec-22
When trying to select an area in a Revit view, the window selection does not select all elements.
Some elements do not get selected when using window selection in a view in Revit
No
19-Dec-22
Users reported that "Cannot move analytical surface" warning is displayed while upgrading file in Revit.
"Cannot move analytical surface" while upgrading file in Revit
Yes
19-Dec-22
Analytical nodes are dislocated after running physical to analytical for buildings script in Revit 2023
Analytical nodes are dislocated after running physical to analytical for buildings script in Revit 2...
Yes
19-Dec-22
Rooms in linked files that use geometry from nested links don't report their perimeters correctly in Revit.
Rooms in linked files that use geometry from nested links don't report their perimeters correctly in...
Yes
17-Dec-22
Coordinates from moved linked  georeferenced DWG are incorrectly resaved into linked DWG from Revit.
Coordinates from moved DWG are incorrectly resaved into linked DWG from Revit
Yes
16-Dec-22
"An error occurred drawing the contents of this view. The view will be closed" when Ambient Shadows ...
Yes
16-Dec-22
Extra space appears before special character when exporting PDF from Revit
Yes
16-Dec-22
How to set up the DWG export to avoid covering MEP symbols with other elements in Revit?
Yes
16-Dec-22
Users reported that there is inconsistent duct/pipe filter override, in the parallel sections when cutting thru the elements in Revit.
Inconsistent duct/pipe filter override in parallel section cutting thru the element in Revit
Yes
16-Dec-22
When linking a Revit model in a Revit host model by Shared Coordinates, the geometry of the linked model is missing in a 3D view.
Linked Revit model is not displayed in the host model in Revit
No
16-Dec-22
Revit DB Link export is very slow or the model cannot be exported due to not-responding Revit.
Revit DB Link export is slow or not successful
Yes
16-Dec-22
Netto Area of the room is not calculated according to the parameters included in the room properties in Revit
Room Netto Area is not calculated according to the parameters included in the room properties in Rev...
No
15-Dec-22
Upon launching Autodesk software, a window appears with the message  "No active subscription or trial could be found for this email address"
"No active subscription or trial could be found for this email address" when launching an Autodesk s...
No
15-Dec-22
Slow performance when linking a point cloud file from ACC directly into Revit.
No
15-Dec-22
Some fabrication fittings are bleeding through and showing on the wrong level in Revit
No
14-Dec-22
"File you are trying to open has failed to lock automatically" when opening a Revit file with Desktop Connector 16.0.0.1902
"File you are trying to open has failed to lock automatically" when opening a file with links in Rev...
No
14-Dec-22
How to change the room tags used by the Roombook or Areabook extension in Revit?
How to change the room tags used by the Areabook extension in Revit
No
14-Dec-22
Where to search for knowledge and tutorials about sun analysis in Revit?
Knowledge and tutorials about sun analysis in Revit
No
14-Dec-22
Users reported that user defined property set for bolts is missing while export to IFC from Revit.
Missing user defined property set for bolts while export to IFC from Revit
Yes
14-Dec-22
Specific doors appear in projection, instead of being displayed as cut in specific plan regions of a Revit model.
Wrong display of door in plan region in specific Revit file
Yes
14-Dec-22
Using shared parameter IfcSingleMaterialOverride does not change colors for some elbows and fittings exporting to IFC from Revit
Using shared parameter IfcSingleMaterialOverride does not change colors for some elbows and fittings...
Yes
13-Dec-22
Users reported that elements from inside the building are visible after displaying shadows in a section/elevation view clipped without line in Revit.
Elements from inside the building visible after displaying shadows in section clipped without line i...
Yes
12-Dec-22
Users reported that after creating solids using Solids.ByLoft, Familytype.ByGeometry fails in Dynamo for Revit.
After creating solids using Solids.ByLoft, Familytype.ByGeometry fails in Dynamo for Revit
Yes
12-Dec-22
Users reported that DWG file is not correctly imported when using "Auto - Center to Center" if nothing is visible in Revit view.
DWG file is not correctly imported if nothing is visible in Revit view
Yes
9-Dec-22
Edge cutting profiles are not inserted at extreme parts of the hollow core slab in Revit.
Missing cutting profiles at extreme parts of the prefabricated hollow core slab in Revit
Yes
9-Dec-22
Users reported that there are missing hollows in the hollow core slab after editing floor boundary in Revit
Missing hollows in the hollow core slab after editing floor boundary in Revit
Yes
8-Dec-22
When installing Revit 2023.1.1 Update the installation fails with “Install error: Autodesk Revit 2023.1.1 Update The installation couldn’t finish Error 101”
“Install error: Autodesk Revit 2023.1.1 Update The installation couldn’t finish Error 101” when inst...
No
8-Dec-22
No
7-Dec-22
When navigating to the 'Autodesk Docs' folder to add a project for Desktop Connector in Windows File Explorer, the message for the project appears "Adding Project Failed: Value cannot be null. Parameter name: source".
"Adding Project Failed: Value cannot be null. Parameter name: source" message appears in Windows Fil...
No
7-Dec-22
Users reported that Revit crashes with message "An unrecoverable error has occurred..." when opening specific section views in Revit.
Yes
7-Dec-22
When creating a void as component in the Revit model, the existing elements near by are not cut by the void
Creating void as component does not cut the beam in model in Revit
No
7-Dec-22
Users reported that IfcPredefinedType value for ceilings is not inherited from IfcExportType parameter in Revit.
IFC Predefined Type for ceilings is not inherited from Ifc Export Type parameter in Revit
Yes
7-Dec-22
Revit shows "DBApplication Startup failed" message when starting and the cloud models cannot be opened
Revit shows "DBApplication Startup failed" message when starting and the cloud models cannot be open...
No
6-Dec-22
Revit crashes without warning after using Revit DB Link add-in export.
Revit crashes without warning after using Revit DB Link export
No
6-Dec-22
How to create complex topography shapes in Revit?
No
3-Dec-22
Revit crashes without warning when exporting a specific file to NWC
No
2-Dec-22
Dynamic holes are missing or shown as lines on straight in CAMduct
No
1-Dec-22
Elements cannot be edited or inserted after auditing a file in Revit
Family instances cannot be edited or inserted after auditing a file in Revit
Yes
1-Dec-22
How to adjust railing post height in Revit?
No
1-Dec-22
Users reported, that trying to connect Fabrication parts of different Services via Multi-point Rooting in Revit, the program doesn't provide options and assigns the wrong service to the new parts.
Unable to properly connect Fabrication parts of different Services via Multi-point Rooting in Revit
Yes
Wendy Lim
Rails Summit
