2021 | New Knowledge Support Articles | Revit
3 ANTWORTEN 3
Nachricht 1 von 4
lim.wendy
3357 Aufrufe, 3 Antworten
Here is the list of the latest Autodesk Knowledge Network support solutions that were created in 2021:
Dec 2021
Summary
Knowledge Article
Incident Reported
Non-English One-Way Indicator family (in Route Analysis panel) in Revit doesn't work.
Non-English one way indicator family (in Route Analysis panel) in Revit doesn't work
Yes
How to create a Lighting Fixture family that behaves like an LED strip in Revit? Currently, such elements can be created using the Sweep function. Is there a faster way to create these elements from the selected paths in one shot?
Creating a Lighting Fixture family that behaves like an LED strip in Revit
No
Duplicate Material and Assets feature is not available in Revit 2022.1
Duplicate Material and Assets feature in Revit
No
In 3D view the flex pipe full geometry will be displayed, in plan view, only a symbolic representation is used. How to change the display settings, to achieve a more realistic display in plan view?
Flex pipe representation in plan view is different than in 3D view in Revit
No
"Data in file (filename).rvt is corrupt and needs to be manually recovered" message appears when opening file-based worshared project in Revit.
"Data in file (file name).rvt is corrupt and needs to be manually recovered" when opening file-based...
No
When synchronizing the cloud worksharing model in Revit, at the Local Regeneration stage the following error message is displayed and after it Revit crashes: "A serious error has occurred. The current action has been cancelled...".
"A serious error has occurred. The current action has been cancelled..." when synchronizing cloud wo...
No
When attempting to change the profile or use Model Reviewer, Revit displays permissions errors.
Revit displays permissions errors when changing or using the Model Reviewer
No
Users reported that when several project members collaborate on a particular cloud workshared model in Revit, the following error message randomly appears and blocks the workflow: "Can't edit the element. It was deleted in the Central Model".
"Can't edit the element. It was deleted in the Central Model" randomly appears when several project ...
Yes
Floor slab from Archicad IFC is not a volume object but only outline in Revit
Floor slab from IFC is not a volume object but only outline in Revit
Yes
When exporting a Revit model which contains Fabrication content to DWG, the layer mapping is ignored.
When exporting Revit Fabrication content to DWG, the layer mapping is not followed
No
Revit hangs when changing material type on multiple instances of a Floor
Yes
Daylighting Analysis Shows Incorrect Illumination in Some Rooms
Lighting Analysis Shows Incorrect Illumination in Some Rooms
No
Not able to import a draft view from a model to another in Revit
No
Users reported that top rails ends are not exported to IFC from Revit.
Top rails ends not exported to IFC from Revit
Yes
Where to download the CivilConnection package for Revit and Civil 3D version 2022? Will this Dynamo package for the 2022 version of products be available?
No
People Flow toolkit add-in download location
No
Unable to access Revit Server Administrator panel from a mainstream web browser after installing Revit Server 202X.1. The following warning appears: "Server Error in '/RevitServerAdmin202X' Application...Runtime Error...".
"Server Error in '/RevitServerAdmin202X' Application...Runtime Error..." when trying to browse Revit...
No
Results Manager and Results Explorer options missing from  Revit 2022 Analyze tab after Robot Structural Analysis 2022 update.
Results Manager and Results Explorer missing from Analyze tab in Revit 2022
No
User reported that when dimensioning rebar in Revit, tick mark line of dimension points to opposite edge of rebar.
When dimensioning rebar in Revit, tick mark line of dimension points to another site of rebar
Yes
User reported that when mirroring rebar in Revit, new rebar is placed not symmetrically. It is moved by half of wall thickness
Mirrored bar is placed asymmetrically in Revit. It is moved by half of wall thickness
Yes
Global parameters assigned to a project/type parameter for a loadable family get disassociated on duplicating the family type.
Global parameters assigned to a loadable family parameter gets disassociated on duplicating the fami...
Yes
Serious error when mirroring a project. The cause is related to some type of bad elements. For a workaround, have Development team repair the file.
"A serious error has occurred" when mirroring a project in Revit
Yes
Windows with nested components in Revit are not behaving correctly when copied or mirrored in the project.
Windows with nested components in Revit are not behaving correctly when copied or mirrored in the pr...
Yes
Can I create a Revit 2022 Deployment with different Content Packs?
No
When working in Revit and looking at the naming for local files, the local file has an appended timestamp at the end
Some local Revit models have an appended timestamp
No
Nested annotation families are not visible in some views after loading the host family into Revit project.
Nested annotation families not visible in some Revit project views
Yes
When export SMLX from Revit and import it in Advance Steel the rule based mapping is not used as expected.
When export SMLX from Revit and import it in Advance Steel the rule based mapping is not used as exp...
No
User reported that specific SAT files cannot be imported in family editor in Revit 2022.
Cannot insert SAT file in family editor in Revit 2022
Yes
Significant increase in the size of NWC file exported from Revit 2022 compared to export from previous Revit version.
Significant increase in size of NWC file exported  from Revit 2022 compared to export from previous ...
No
When using the FamilyInstance.SetType node (from Clockwork package) in Dynamo with views, no change is made to the view.
Set Type (FamilyInstance.SetType) node in Dynamo not working to change View type in Dynamo
No
When attempting to path to a Shared Parameter file in Revit, the Shared Parameter list is empty in the dialog.
Shared Parameter files appear blank when pathed to in a Revit project
No
User reported that Dynamo Player for Revit 2022 uses same folder as Dynamo Player for Revit 2021
Yes
Toggling view Crop Region causes some split sections to flip in Revit
Yes
When exporting IFC file from Revit with the option 'split walls, columns, ducts by level' while exporting IFC, ducts are exported as single objects, are not split by the levels.
Ducts not split with the option 'split walls, columns, ducts by level' while exporting IFC from Revi...
Yes
When linking or importing a DWG into Revit, an error appears, "Revit cannot import some of the geometry", and the operation fails.
"Revit cannot import some of the geometry" appears when trying to link or import a DWG file into Rev...
No
How to create Callout that is dependent on another view in Revit
How to create Callout as a dependent view in Revit
No
After syncing a cloud workshared model in Revit, other users cannot run the sync operation.
Some users cannot sync a cloud workshared model after another user syncs in Revit
No
Crop View is greyed out in Revit, unable to change crop view in a specific view.
Crop View greyed out in Revit
No
Multi Rebar Annotation changes after copy/ paste to duplicated view with the option align to current view or align to the same place in Revit.
Multi Rebar Annotation changes after pasting by align to current view/same place in Revit
Yes
SQLDUMPER.EXE window opening and closing when working in Revit
No
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Beschriftungen (1)
  • e
3 ANTWORTEN 3
Nachricht 2 von 4
lim.wendy
als Antwort auf: lim.wendy
Nov 2021
Summary
Knowledge Article
Incident Reported
Unable to insert Room boundaries into a room from an IFC linked in Revit. If a room has an opening or gap in the wall at floor level, this operation cannot be performed.
Room boundaries cannot be inserted into a room from an IFC linked in Revit if there is an opening or...
Yes
Users reported a performance drop when working with a model, specifically on a structural plan with rebars. The Detail Level has been changed from Coarse to Medium or Fine. The problem occurs especially when navigating, zooming in and out of the view in Revit.
Slow performance when zooming in and out on structural plan with rebars after changing the Detail Le...
Yes
Desktop connector freezes when trying to use Reference Explorer
Yes
Users reported that they are not able to unload or reload Topography link in Revit 2021 and 2022 using Desktop Connector 15.0.0.1450 and 15.1.0.1587 version. When opening a model with Topography link added previously, this message appears in Revit: "It looks like the requested service is currently unavailable. Please try again". Additionally, the status of the Topography link is as 'Not Found'.
Failed to unload or reload Topography link in Revit 2021 and 2022 using Desktop Connector 15.0.0.145...
No
A model initiated, for example, in Revit 2021 and saved to Revit Server 2021 is later visible when opening the Revit Server 2022 Administrator panel in a web browser. It is not listed in the Revit Server 2021 Administrator panel. The issue is related to a specific version and configuration.
Central models saved in Revit Server are in a different version than the Revit from which they were ...
No
Users reported that it is not possible to import or open 1.6 GB IFC file in Revit.
Unable to import or open large IFC file in Revit
Yes
How to open desired 3D view from Revit in Navisworks? Is it possible to export a specific view from Revit so that the visible geometry adjusted with filters is displayed in Navisworks? When opening a model in Navisworks, another 3D view is opened by default, even if the model was saved with the desired, most recently active 3D view.
No
Users reported that specific geometry of walls and floors join will be inaccurate at IFC export from Revit.
Incorrect geometry at IFC export of walls cut by floors from Revit
Yes
Users reported that model are exported with wrong Z coordinates to IFC with Shared Coordinates with IFC 22.3 from Revit 2022.
Wrong Z coordinates exporting model to IFC with Shared Coordinates with IFC 22.3 from Revit 2022
Yes
Cannot access Revit Server Administrator panel after installing Revit Server in 20##.1 version, which supports mainstream web browsers. Loading process freezes, and folder structure and saved models are not displayed in the drop-down tree on the left.
Revit Server Administrator panel freezes on Loading stage after installing Revit Server in 20##.1 ve...
No
Users reported that parameters Hook Rotation At Start Hook and Rotation At End remain 0 after changing graphically hook rotation in family in Revit.
Parameters Hook Rotation At Start and Hook and Rotation At End remain 0 after changing graphically h...
Yes
How to turn off worksets when opening workshared Revit models.
No
Users reported that editing dimensions with many witness lines is lagging in Revit.
Dimensions lagging in Revit
No
Users reported that when trying to upgrade a model, an error is displayed in Revit.
"Data in the file xxx.rvt needs to be manually upgraded" when upgrading a Revit model
No
When creating an assembly out of Pipes of different lengths in Revit the pipes are assigned to the same assembly group.
When creating an assembly out of Pipes of different lengths in Revit the pipes are assigned to the s...
Yes
Incorrect graphic display while editing section box in Revit 3D view or moving elements. The edges will be multiplied until the command will be finished. When the edition mode is no longer active, only a single edge will be displayed.
Incorrect edges display while editing elements in Revit 3D view
No
Users reported that dragging a level line grip is very slow and can sometimes cause Revit to not respond.
Slow performance when dragging a level line grip in Revit
No
Users reported that the opening on the floor slab is exported as a void in the floor boundary in IFC 4, which is different than in IFC2x3, where the separate opening element will be exported from Revit.
Opening on the floor slab is exported differently in IFC4 than in IFC2x3 from Revit
Yes
When opening a Revit model that contains Links that utilize Shared Coordinates for positioning, the Shared Site name is lost in the properties of the link.
Linked models lose Shared Site name when the host model is opened in Revit
No
Users reported that Saturation and Shadows terminology is inverted when using French Revit
Inverted terminology in French language Color Correction dialog in Revit
Yes
Users reported that they need support for mainstream web browsers in Revit Server 2019 as is the case for recent versions of Revit Server 2020 and above. Managing projects and folder structure is done on project participants' computers using Internet Explorer in Windows 10 environment. In addition, Microsoft plans to stop supporting Internet Explorer for Windows 10: "Internet Explorer 11 desktop application will be retired and go out of support on June 15, 2022, for certain versions of Windows 10".
Support web browsers other than Internet Explorer for Revit Server 2019
No
After pasting families and selecting "Edit Pasted Elements" from the Ribbon, the toolbar does not display.
Edit Pasted Elements toolbar does not display after selecting the command from the Revit Ribbon
No
Autodesk Desktop Connector update 15.0.0.1540 breaks shortcut links. Update to newest version of Autodesk Desktop Connector, required to fix shortcuts manually.
No
When attempting to create a value lower than 0.1 for Air Dynamic Viscosity, the program changes the number to 0.0.
Cannot adjust Air Dynamic Viscosity in Revit lower than 0.1
No
"You do not have access rights to [path\filename]. See your administrator..." when accessing shared files in Revit
"You do not have access rights to [path\filename]. See your administrator..." when accessing shared ...
No
What are the terms of use of the Revit sample models for marketing purposes?
No
The lines for the Pipe Accessories and Pipe Fittings families seem to merge together to form a single point in Revit. Their symbol does not show up correct in view due to excessive line thickness. When editing families and checking the thickness of the lines used for their symbols, the line is thin and less than 1 mm. Is there any other way to adjust these line thicknesses?
How to control line thickness for Pipe Accessories and Pipe Fittings in Revit
No
How to model a floor with multiple slopes and a variable thickness in Revit.
No
Users reported that an incorrect MEP fabrication transition part tag value is not correct in Revit.
Offset tag SU/SD top parameter reporting incorrectly in Revit
Yes
Elements are not placed at the expected elevations when they are placed in floor plan in Revit
Elements are not placed at the expected elevations when placed in floor plan in Revit
No
Users reported that certain IfcSpace parametersets and attributes inside them are getting exported to IFC2x3 as expected, but not when trying to export the same model to IFC4 format from Revit.
IFC Space attributes missing after exporting models to IFC4 from Revit
Yes
Users reported that transferring View Templates via Project Standards unexpectedly copies the list of linked CAD Imports from the source file into the  Visibility/Graphic Override Dialog of new project files.
Transferring View Templates via Project Standards unexpectedly transfers the list of linked CAD Impo...
Yes
Users reported that specific beam joins change if the beam's width edited specific way.
Beams join change depending on the beam's width and joining's column's geometry in Revit
Yes
Users reported that damaged parts and lines which running in different directions from object imported from SAT are displayed in Revit.
Damaged parts and lines which running in different directions from object imported from SAT displaye...
Yes
Wires are moving on upgrading a model to Revit 2022
Yes
Users reported that number display cannot be set after the following digit grouping format: 123 456.789
Specific digit grouping display cannot be set in Revit
Yes
Revit Revision Schedules do not allow additional fields to be added.
Revit Revision Schedule will not allow additional fields
No
gbXML export via MEP rooms outputs ceilings as roofs in Revit
Yes
Unable to select 'Detach from Central' when opening a specific model in Revit. This option is grayed out and when trying to open a model in the Open dialog box.
'Detach from Central' option is grayed out when trying to open a specific Revit model
No
Users reported that rooms lost their room boundaries in a specific Revit files and cannot be closed. "Room is not in a properly enclosed region" warning appears.
Not enclosed rooms in a specific Revit file
Yes
When performing a Revit Cloud Model Upgrade, many elements are duplicated.
Many elements duplicated during Revit Cloud Upgrade
Yes
User reported that IFC file is not properly imported in Revit 2022.1
IFC file imported not properly in Revit 2022.1
No
Combined parameters (CP) created from shared parameters (SP) used for schedules does not stay with the Revit model when all of the families that use the SP have been removed from the project.
Combined parameters for schedules does not stay with the Revit model
No
User reported that geometry from Dynamo is not inserted in Family Types in Revit 2022. FamilyType.ByGeometry node is used. Empty Family Types are produced. Instances can be placed in model.
Invisible or ghost element created in Dynamo in Revit 2022
Yes
User reported that it is impossible to work with GIS Plugin when IFC model is imported in Revit 2022.1. IFC is not inserted properly.
It is impossible to work with GIS Plugin when IFC model is imported in Revit 2022.1
No
Users reported that clicking the Revit Server icon in the file open dialog is very slow to show the contents in Revit.
Clicking the Revit Server icon is very slow in Revit
No
Users reported that Area and Circumference are calculated incorrect for Windows cut by voids with Buildingbook in Revit.
Incorrect Area and Circumference calculation for Windows cut by voids with Buildingbook in Revit
Yes
Users reported that while attempting to remove the linked file from borrowed Workset, the file disappears after selecting 'cancel' in Revit. The file can be loaded only in the new Revit session.
While attempting to remove the linked file from borrowed Workset, the file disappears after selectin...
Yes
When placing a wall material tag without a leader line in Revit 2022, a question mark "?" is displayed instead of the material value.
Material tag without leader line fails to show material value and shows a question mark in Revit
Yes
Cannot add dimension to a Multistory stair railing in Revit when removing the Top Rail.
Yes
User reported that it is not possible to export Revit Parts as IfcBeam using IfcExportAs parameter.
Cannot export Revit Parts as IfcBeam using IfcExportAs parameter
Yes
How to generate a list of elements in a Selection Filter in Revit?
No
Why does Revit generate additional materials when importing or linking a CAD file and why do these stay in the host Revit project after removing the inserted CAD file?
About materials generated when importing a CAD file in Revit
No
How to report roof footprint dimensions via Instance and Global Parameters in Revit?
No
When working with a Dynamo graph that is set up to work with Generative Design, the option to "Export for Generative Design" is missing.
Export for Generative Design option is missing for graph opened in Dynamo
No
Keyboards shortcut alt key indicators stop working after a three level deep command is used in Revit.
Keyboard shortcut combos sometimes break in Revit
Yes
Oct 2021
Summary
Knowledge Article
Incident Reported
When the system loses Internet connectivity, Revit is hanging up.
Revit freezing when losing Internet connectivity
No
Correct linking of georeferenced DWG as In-Place Mass is not possible in Revit
Correct linking of DWG as In-Place Mass is not possible in Revit
Yes
How to set the position of the symbolic line representation of structural braces in Revit floor plan views?
Yes
Can Panel, Circuit Number and Breaker Amperage be added to Families for Electrical Equipment Schedule in Revit
Can Panel, Circuit Number and Breaker Amperage be added to Families for Electrical Equipment Schedul...
No
Users reported that the display of slanted windows in slanted walls on plan view is different than in 3D view.
Different display of slanted windows in slanted walls on plan than in 3D view in Revit
Yes
Users reported different beam displays while joining with structural column and structural wall in RCP in Revit.
Different beam displays while joining with structural column and structural wall in RCP in Revit
Yes
When linking and then binding the Revit model some of the model elements disappear
Yes
Cannot download latest update for Revit version that is no longer supported. Currently, the last supported version is Revit 2019, and it is the last version for which updates are available.
No
Users reported that miter cut is not displayed on plan view in Revit.
Miter cut not displayed on plan view in Revit
Yes
When linking a DWG file into Revit, the background shows but none of the piping or hangers show.
Pipes in linked DWG not showing in Revit
No
When exporting a model to PCF, items are not being coded as expected.
Items in Revit not coding as expected in PCF export
Yes
Revit crashes when modifying parameters of a fabrication part
Yes
Is there a way to give access rights to folders located on a Revit Server? For example, give two different project groups permissions to two different folders.
Unable to grant access rights to folders located on the Revit Server
No
Users reported that specific lines from generic models get lost at dwg export in Revit.
Missing lines of generic model at DWG export in Revit
Yes
Revit crashes in local RVT model only in certain area
No
How to perform a complete uninstall of Revit Server. The uninstall from Control Panel > All Control Panel Items > Programs and Features was not completely successful.
No
Wall tags are not attached to wall in Revit
Yes
Offset is changed by using the spacebar when placing a pipe or duct directly from the vertical connector in Revit. In addition, the length of the vertical segment is automatically calculated and cannot be changed to a desired value.
Offset is changed by using the spacebar when placing a pipe or duct directly from the vertical conne...
No
When reloading a cloud type link via External Resource from BIM 360 in Revit, the following error message appears: "Linked document bim 360://<path>/<file name>.rvt not found. The link will be unloaded".
"Linked document bim 360://<path>/<file name>.rvt not found. The link will be unloaded" when reloadi...
No
No Generative Design Tool in Revit 2022
Generative Design Tool missing in Revit 2022
No
Users reported that the display of window family is different depending on the elevation position in Revit. When the elevation is created vertical or horizontal in relation to the plan view the display is transparent, when the elevation it rotated display of the same window is opaque.
Different window family display depending on the elevation position in Revit
Yes
IFC file exported using survey point is not coming at the correct location when linked in Revit 2022
IFC file exported using survey point is not coming at correct location when linked in Revit 2022
No
Displace Elements button appears greyed out in Revit.
No
Dimensions are mirrored in the linked Revit model
Yes
User reported that when modeling steel nodes and bolts in Revit - bolts diameters contain units
Issues when modeling steel nodes and bolts in Revit - bolts diameters contain units
Yes
How to transfer a parameter from a linked model to the host in Revit.
No
User reported that "Estimated reinforcement volume" parameter value is not deleted from original host after picking new host in Revit
"Estimated reinforcement volume" parameter value not deleted from original host in Revit
Yes
When importing an SMLX file from Advance Steel to Revit, different elements are missing.
Missing elements when importing an SMLX file in Revit
No
After linking a topography in Revit, the topography cannot be assigned to a different workset as this option appears greyed out.
Unable to change the topography's workset in Revit
No
When attempting to utilize the Navisworks export utility in Revit, an error appears stating, " Autodesk Navisworks Exporters 20## exporter generated warnings.  Some parts of your file may not have been generated properly, see .log ".
Unable to export to NWC using Navisworks export utility, as the operation fails to complete from Rev...
Yes
IFC color for different layers vary when floor is edited using modify sub-element in Revit
Yes
Is it possible to create a Schedule (i.e.: For Walls or Windows) in Revit that contains the orientations of the elements?
How to create a schedule containing the orientation of elements in Revit
No
Users reported that IFC cannot be loaded or model is "exploded" in Revit 2022.
Yes
Ducts are not replaced with a Fabrication Straight of the same length in Revit
No
Custom symbols stored in SHX format in a DWG file appear as fonts when linked in a Revit project.
No
Walls showing transparent unexpectedly in Elevation and section views in Revit.
No
Users reported that Exchange Requirement selection is missing in File Header Information dialog for IFC IFC2x3 Export Settings in Revit 2022.
Exchange Requirement selection missing for IFC export settings in Revit 2022
Yes
Cannot Add or Remove host to multi-leader tags when the tag command is initiated in Revit 2022.1.
Cannot add or remove host to multi-leader tags when the tag command is initiated in Revit
Yes
Users reported that when export to IFC with option Export elements visible in view checked, an error occur and not all the walls are exported to IFC.
"Unexpected errors occurred while exporting these elements to the IFC file." error appears in Revit ...
Yes
Users reported that exporting layout including linked elements to DWG from Revit, some hatch patterns are missing.
Missing pattern while exporting layout including links to DWG from Revit
Yes
Visibility parameter of a specific element of a family does not work in a project in Revit.
Visibility parameter of a family does not work in a project in Revit
No
Beam disappears from floor plan view after being moved in Revit
Yes
Revit crashes at IFC Export
Yes
Fabrication Straight Length set to "Value" when using "Optimize Lengths" in Revit
No
Beam annotation doesn't work for linked model in Revit. It's a limitation of the software.
Beam annotations are not working for linked model in Revit
No
User reported that model is not responding while stretching bars in Revit
Corrupt model is not responding while stretching bars in Revit
Yes
Drawing of HVAC pipes is very slow in the plan view when the DWG file linked in Revit
No
When attempting to delete a pinned sheet from a Revit project using the Project Browser, an error appears, "Pinned objects were not deleted".
Pinned Sheets Cannot Be Deleted Using Project Browser in Revit
No
Users reported that they have problems with publishing different Revit models in BIM 360. Sometimes the time required to publish the same model differs significantly. For example, the total time to publish the model until its preview in BIM 360 viewer will be available is around 5 minutes. Then making a second attempt on the same day takes several hours, and in extreme cases even more than 10 hours. Additionally, some users noted that the publishing process is slow on specific days, e.g., it is Friday at a fixed time of day.
Unexpectedly long time to publish Revit model in BIM 360
Yes
Unable to select Heating or Cooling Loads in Insight to visualize results of an energy analysis started in Revit. These options used to be available and now are missing in Insight.
Cannot visualize Heating or Cooling Loads in Insight after creating energy model in Revit
No
Accepting Primary Design Options unexpectedly deletes some elements in Revit 2019. When accepting one of Design Options as primary, the following message appears: "Deleting an Option Set causes all of its Secondary Options and associated elements to be deleted also. Are you sure you want to delete this Option Set?".
Accepting Primary Design Options deletes some elements in Revit 2019
No
Beams with an offset of Z=0 are not visible on a floor plan view in Revit.
Beams are not visible in a Floor Plan view in Revit
No
Users reported that linking Revit file makes some elements to disappear from view in Revit.
Linking Revit file makes some elements to disappear from view in Revit
Yes
How to edit the graphics of a nested family independently of the parent family in Revit.
How to edit graphics of a nested family in Revit
No
Users reported that RAM memory is not completely released while closing project in Revit.
Revit RAM memory accumulation after closing project
Yes
Unable to install LunchBox package 2018.7.7 for Dynamo in Revit. After installing the specified version, this package does not appear in the list of available packages on the left side in Dynamo. After trying to install it in Workspace References there is still a red "X" indicating as if the package has not been installed and the following message appears: "This graph depends on LunchBox for Dynamo 2018.7.7. Would you like to download and install this package?".
No
Users reported that a custom pipe fitting does not work at 90 degrees in Revit
Pipe fitting elbow cannot be created when angle between pipes is 90 degrees in Revit
No
Users reported that model is shifted 3mm exporting it to IFC from Revit.
Model shifted 3mm exporting to IFC from Revit
Yes
Users reported error "System.NullReferenceException" while attempting to edit `Construction Floor Area` if Revit is running in German language.
Error: "System.NullReferenceException" while editing Construction Floor Area in Roombook in Revit in...
Yes
When accessing BIM 360 in Revit, certain projects do not appear.
Some BIM 360 projects do not appear in Revit
Yes
Revit crashed with CER when editing a plan region.
Yes
Sep 2021
Summary
Knowledge Article
Incident Reported
When loading or re-loading a link in Revit, the following error is received: Revit cannot load {File} because the add-in that provides that resource is not installed.
Revit cannot load {File} because the add-in that provides that resource is not installed error when ...
No
A project parameter needs to be translated to represent another parameter in Revit.
How to use a parameter to modify output of another parameter in Revit
No
Users reported that negative volumes might be reported by API calls (using Dynamo for instance) for some objects when importing (opening) IFC files in Revit.
Negative volumes are reported for some floors for an IFC file imported into Revit.
Yes
After installing Revit (or Revit LT) 2022 you are finding that the keynote files available in prior versions are not installed with Revit.
Missing keynotes text file in Revit 2022
Yes
There are extra lines on a floor (slab) structural when create a section in Revit.
There are extra lines on a floor (slab) structural section view in Revit
Yes
When trying to transfer project standards between files, a error message of "These Project Standards cannot be transferred." appears when the Arrowhead Styles is checked in Revit.
"These Project Standards cannot be transferred." appears when transferring project standards is chec...
Yes
Users reported incorrect placement when pasting unhosted area loads to the selected levels in Revit.
Incorrect placement when pasting unhosted area loads to the selected levels in Revit
Yes
Users reported that after binding two or more IFC files that have the same element types, into Revit, the elevation of some elements is changed.
Changed element elevation after binding IFC to Revit
Yes
How to recover the original version of a Revit file when a BIM 360 project is accidentally upgraded to a newer version.
How to recover a previous version of a Revit Cloud model from an accidentally upgraded BIM 360 proje...
No
Revit family does not show as expected in a plan view.
Family not shown as expected in Revit
No
After clicking, Open Generative Design Tools in Dynamo for Revit. A dialog is displayed stating something went wrong and Dynamo crashes.
"Uh oh... something went wrong..." after clicking Generative Design Tools in Dynamo for Revit
No
User reported that when export SMLX file or synchronize in Revit by using Advance Steel Extension for Revit "Costrains are not satisfied" error occurs.
"Costrains are not satisfied" when export SMLX file or synchronize in Revit by using Advance Steel E...
Yes
When accessing the Manage Cloud Models for a specific model in Revit, the program freezes.
Opening Manage Cloud Models for a specific project freezes Revit
No
When utilizing a third party addin in Revit, the addin does not function as expected in a specific version or Revit.
Third party addin does not function as expected in a specific version of Revit
No
After placing a Door family in a Revit Elevation, parts of the door family are obscuring other elements in the view.
Door Family obscures other elements in Elevation when placed in Revit
No
When working in Revit, opening certain views causes Revit to crash without any errors or warnings.
Crash with no warnings when opening specific views in Revit
Yes
When drawing a Tray in Revit, the error “The routing solution failed because there is no default fitting type specified…” appears.
“The routing solution failed because there is no default fitting type specified…” appears when drawi...
Yes
When trying to edit a walls location by editing a dimension, the editable dimension is not displayed in Revit.
Unable to move walls by editing dimensions in Revit
No
How to mitigate risk when Revit Server Host is down and Revit Accelerator is up
No
Users reported that in Revit realistic mode, color display for fills in annotation elements nested in model families is different, depending on lighting,
Different color display for fills in annotation elements in realistic mode in Revit
Yes
After exporting NWC from Revit the upper face of a slab is not displayed in Navisworks.
No
Users reported inconsistent behavior while copying/pasting structural top constrained elements with the option 'aligh to selected levels' tool in Revit.
Inconsistent behavior while pasting structural elements to selected levels in Revit
Yes
"The linked file does not contain geolocation data." when acquiring coordinates in Revit
No
Unable to include pressure drop and flow parameters of MEP systems in Revit schedules.
No
Increasing the DB Link character limit in Revit
Yes
Users reported, that the Revit journal file contains lines with "API_Error : Assembly version conflicts".
"API_Error : Assembly version conflicts" reported in the Revit journal file
No
Add/Remove Wall to a wall sweep results in the "A serious error has occurred. It is strongly recommended that you use Save As to save your work in a new file before continuing" error for stacked walls.
"A serious error has occurred" when adding or removing a wall to a wall sweep
Yes
While working in a workshared Revit model, multiple views move off sheets unexpectedly.
Multiple views shift on Sheets in Revit
No
Users reported that after applying steel modifier for a structural member in Revit, the display is changed unexpectedly and this can not be undone, even after removing the modifier.
Changed display after applying steel modifier in Revit
Yes
Users reported that it is not possible to group a railing along with a dimension or tag in Revit.
"Can´t make change to Group with more than one instance..." adding tag or dimension and railing to g...
Yes
Users reported that Fabrication elements in Revit projects do not display with the right fill pattern applied by a view filter override in floor plan views.
Fabrication parts unexpectedly show with solid fill paterns in Revit views
Yes
How to rotate an object to a specific angle during placement using the spacebar in Revit
How to rotate an object to a specific angle during placement in Revit
No
When there is more than one user working in a model and adding Structural Reinforcement Paths, an Editing Request will be generated for the Structural Reinforcement Path Symbol. This happens even when working on different levels of the project.
Editing Requests for Structural Reinforcement Path Symbols in Revit
Yes
When starting collaboration to the cloud, the process fails at the "Uploading model to the Cloud" stage in Revit.
Collaboration fails at "Uploading model to the cloud" in Revit
No
No system heating loads results when using Room or Space mode in Revit
Yes
When attempting to make a 3D DGN using the ini modification to use the 2012 encoder or exporter. The exporter does not use the assigned level names and assigns all elements to Level 1.
When exporting a 3D DGN, the level mapping is not followed
Yes
Users reported that Revit does not consider the Fabrication Database setting "Display locked Dims" for Fabrication elements.
Fabrication Database setting "Display locked Dims" for Fabrication elements doesn't get respected in...
Yes
Users reported that some walls and rails wrongly exported to IFC from Revit.
Some walls and rails wrongly exported to IFC from Revit
Yes
Users reported that some assemblies exported to IFC contain openings not assigned to these assemblies in Revit.
Some assemblies exported to IFC contain openings not assigned to these assemblies in Revit
Yes
Users reported that formula results are not displayed in "meters and centimeters" unit in tags in Revit
Formula results not displayed in "meters and centimeters" unit in tags in Revit
Yes
Aug 2021
Summary
Knowledge Article
Incident Reported
When internet becomes disconnected Revit crashes with a Customer Error Report. An add-in is causing the conflict. Disable it to clear the issue.
No
When running a graph in Dynamo for Revit, some nodes show an "Unresolved" error message and the run does not complete.
Some nodes show "Unresolved" status when a graph is run in Dynamo for Revit
No
Design to Fabrication does not convert Elbow and Tee fittings in Revit
No
Loads do not update in the panel schedule after changing the loads in Revit for Electrical equipment.
No
"Parts were not pasted" when trying to combine models with fabrication parts in Revit
"Parts were not pasted" when trying to combine models in Revit
No
When trying to link a topography from Civil 3D in Revit, the DWG uploaded to the BIM360 site does not appear.
Uploaded DWG to BIM360 does not appear when trying to link topography in Revit
No
Users reported that when navigating or zooming in/out of different views in a specific model, Revit hangs.
Revit hangs when navigating or Zooming in different views for a specific model
Yes
Fabrication button image displays incorrectly in Properties Palette in Revit
No
User reported that base of monitor stand is not showing in plan view in Revit
Base of monitor stand is not showing in plan view in Revit
Yes
Columns are not visible in plan view but are visible in the 3D view in Revit.
Yes
"Data corruption in file an unnamed file" when moving an element in Revit.  "Data in file (file name).rvt is corrupt and needs to be manually recovered" when open with audit. The file is corrupt. Use a backup.
No
Cannot overwrite an inserted file until Revit is fully closed. Set the inserted file properties to "read-only" then insert it, and overwrite, and set the inserted file properties to "read-only" again.
"The action can't be completed because..." when overwriting an inserted file in Revit
Yes
When opening a model from Revit's Recent Files list, an exception is thrown, "External component has thrown an exception.", and Revit fails to open.
"External component has thrown an exception." appears when opening a model from Recent Files list on...
No
Graphic overrides defined by view filter do not get applied on all elements equally in Revit.
Graphic overrides defined by a view filter do not get applied consistently on all affected elements ...
No
The Analyze in the Cloud feature is missing in the Robot Structural Analysis in Revit addon.
Analyze in the Cloud feature missing in Robot Structural Analysis in Revit add-on
No
What to do when the wrong version was selected in Revit Cloud Model Upgrade process on BIM 360.
What to do when the wrong version was selected in Revit Cloud Model Upgrade on BIM 360
No
How to recover the latest version of a workshared Revit model after it was overwritten with an older version.
Recovering latest model after workshared Revit file is overwritten by older copy
No
After adding new Steel Connections to a Revit model the Modify Parameters button is greyed out and inactive.
Unable to Modify Parameters on new Steel Connections in Revit
No
When inserting a CAD link, the “Current view only” checkbox is checked and grayed out so that it cannot be unchecked.
“Current view only” checkbox on Link CAD dialog is grayed out in Revit
No
"Sign in to your Autodesk Account" appears when trying to open a model from BIM 360 in Revit
No
Creating schedule results in a double count of elements in Revit 2022
Yes
When attempting to load a railing profile in Revit an error message appears, "Rail profile must have one closed loop", and the profile fails to load in.
"Rail profile must have one closed loop" appears when attempting to load a Railing profile into Revi...
No
When using a schedule to show areas of Roof elements in Revit, the areas are not being calculated correctly for a specific Roof.
Area calculations are not correct for Modeled in-place Roof in Revit
No
When aligning walls in Revit, the geometry of the wall does not change.
Unable to align walls in Revit
No
How to adjust certain elements in Revit links to be different than modeled elements in Revit LT.
How to adjust Revit links in Revit LT
No
Analyze in cloud option for Structural Analysis is missing from Revit.
Analyze in cloud option missing from Revit
No
When importing and IFC created in Revit to an older version of Revit, the program slows down and freezes or elements import out of place in the IFC.
Revit IFC export not properly importing into an older version of Revit
No
FamilyInstance.ByPoint node returning empty list when executing Dynamo script in Revit. Additionally, one of the first nodes in the graph displays the following warning: "Method 'DV()' not found" and Data.ImportExcel nodes, generate lists with ~155000 items that have "null" as the return value.
No
After saving a model to BIM 360 the file icon displays as a broken document.
Revit model displays broken file icon in BIM 360
No
How to create in Revit an angle parameter for some rebar shapes to be shown in schedule?
No
After changing the Soft Terrain Slope, values are reset automatically to 90° in Site Designer for Revit.
Cannot modify slope value in Site Designer for Revit
No
The visible portion of the wall shown does not match the extents of the wall in Revit.
The visible end of the wall does not match the Wall End in Revit
No
When opening any model in Revit, it takes longer than expected. When working later and using any commands there is also a noticeable drop in performance. This only applies to a specific computer. In addition, other software also behaves more slowly than on other machines in the same location.
Slow opening of models in Revit and further work on them due to not full use of CPU resources
No
Material Tags in Design Options are Question Marks until View Activated and Synced in Revit
Yes
Cannot create structural elements with Dynamo that have 'Structural' and 'Enable Analytical Model' options added and enabled in Revit. When an element such as Structural Floor is created manually in Revit, it has these options.
'Structural' and 'Enable Analytical Model' options missing when creating structural elements with Dy...
No
From where and how to install the eTransmit add-in for Revit 2017 version?
How to install the eTransmit add-in for Revit 2017 version
No
After installing Revit on Windows Server OS, the program does not start and throws an error. Looking at the reliability and problem history monitor (Control Panel > All Control Panel Items > Security and Maintenance > Reliability Monitor) on this computer there is a Critical Event for Revit.exe.
No
Users reported that when opening specific section view in particular Revit model then "IdMapColourBuffer.png" image is created in root folder. In most cases, contains outlines of elements on a black background that are visible in this open section view in Revit. For example, if a project is located in the N:\Projects\Project Name\... then IdMapColourBuffer.png image will be created in the root folder on N:\ mapped drive.
"IdMapColourBuffer.png" created in root folder when opening specific section view in particular Revi...
Yes
When trying to install Dynamo, the following message appears: "Newer versions of Dynamo Core & Dynamo Revit already installed. Exiting Setup. . ."
"Newer versions of Dynamo Core & Dynamo Revit already installed." when trying to install Dynamo
No
When trying to enable worksets for a specific Revit Cloud model, the following message appears: "There was an issue with enabling worksharing. This operation could not be completed. Please try again."
"There was an issue with enabling worksharing. This operation could not be completed..." when enabli...
Yes
Users reported that spaces are exported to IFC despite deactivation of their export from Revit
Spaces exported to IFC despite deactivation of their export from Revit
Yes
A file with name: ElementPermissions_down_<user name>.dat was created in the <File Name>\Permissions folder on Revit Server side. After this event, a particular project member is not being able to synchronize a model stored in Revit Server. Later, the same project member cannot open that model and this following error message appears in Revit: "This operation could not be completed. Please try again...".
"ElementPermissions_down_<user name>.dat" file is created and a specific project member cannot synch...
No
Wendy Lim
Rails Summit
Nachricht 3 von 4
lim.wendy
July 2021
Summary
Knowledge Article
Incident Reported
After linking an IFC file exported from SDS/2 in Revit, all "IfcOpeningElement" voids are not cutting through the geometry in the model as expected.
SDS/2 IFC linked in Revit shows all voids not cutting through geometry
Yes
When try to search for the file RvtDwgAddon.dll within the path, C:\Program Files\Autodesk\Revit 2020\AddIns\SteelConnections, for Revit 2021 and Revit 2022, the file is absent.
The file RvtDwgAddon.dll does not exist anymore in the Revit 2021 and Revit 2022 SteelConnections fo...
No
Japanese Kanji text in the Supplemental text of Dimension, blows up when the orientation is anything but horizontal or vertical.
Supplemental text of the Dimension blows up when using Japanese Kanji text in Revit
Yes
When working in a specific model in Revit an error "A fatal error has occurred. The application will be terminated..."  appears frequently and the model crashes.
"A fatal error has occurred. The application will be terminated..."  appears frequently when working...
No
When using a family in Revit that should be cuttable in plan, the family does not display as expected.
Cuttable Family Not Cutting for plan views in Revit
No
Users reported that when exporting Revit views to DWG, solid fill patterns that overlap linework, are cutting out the portion of the line below the fill pattern (visible if the overlapping fill pattern is moved in AutoCAD).
Wireframe DWG export - Solid Fill cuts into Revit linework
Yes
After updating a surface in Civil 3D using an XML file, the linked Topography loses spot elevations in Revit when reloaded.
Updated Topography created in Civil 3D loses spot elevations when reloaded in Revit
No
After re-linking a Topography file into Revit, the Topography no longer shows in views it showed up in previously.
Linked Topography disappears from existing views when re linked into Revit
No
How to use Revit Server Administrator after discontinuation of Internet Explorer
Revit Server Administrator & discontinuation of Internet Explorer
No
Users reported that after creating a parameter that is applied to a view, it is not possible to lock it when selecting a section in a plan. The parameter is correctly locked when the section view is activated in Revit.
Parameter controlled by view template fails to be deactivated in properties palette when the view sy...
Yes
When selecting an Assembly Origin in Revit, the Rotate functionality appears inactive.
Rotate functionality appears greyed out when selecting an Assembly Origin in Revit
No
Users reported, that a specific structural column family exports with unexpected geometry from Revit to IFC2x3 format.
Column family exports with unexpected geometry from Revit to IFC
Yes
Tread annotation is missing some numbers on stairs that change direction or are in sections in Revit.
Tread annotation is missing some numbers on stairs in Revit
No
Users reported that calculations of average estimated illuminance for a rooms are not performed correctly when using a custom created IES file in Revit. The IES file is created from scratch and added to Light Source for Lightning Fixture Family. Using the IES Viewer, some irregularities can be seen when comparing it with the default installed Photometric Web File from Revit.
Incorrect calculations of average estimated illuminance for a rooms when using a custom created IES ...
No
Element/wall continues to display overlapping after making a copy next to the first element, the overlap disappears after zoom or pressing Esc
Element/wall continues to display overlapping after making a copy next to the first element, the ove...
Yes
Unnecessary lines are shown in section view for the roof edited using the modify sub-elements in Revit
Unnecessary lines are shown in section view for the roof edited using the modify sub elements in Rev...
Yes
User reported that when launch Revit 2022 with HotFix 2022.0.1 the following error occurs: Revit cannot run the external application "Results Explorer".
Revit cannot run the external application "Results Explorer" error message when launch Revit 2022 af...
Yes
User have reported that when apply custom steel connection to different sections in Revit the objects inside the connection gets in a different slope position.
Custom steel connection gets in a different slope position when apply to different sections in Revit
Yes
Hidden lines for the overlay elements in the linked Revit model are missing in the PDF printed using vector processing in Revit
Hidden lines for the overlay elements in the linked Revit model are missing in the PDF printed using...
Yes
Publish Settings dialogue box not opening for cloud work-shared models in Revit
No
When booting up the system, or when staring the Desktop Connector manually, the program crashes with a prompt to submit an Autodesk error report.
Desktop Connector crash with prompt for error report when starting system.
No
When comparing elements in a Revit view with a schedule, there are missing items.
Elements visible in plan or 3D view are not displayed on a schedule in Revit.
No
When working in Revit, if the File menu drop down is selected, the program freezes and stops responding.
Program freezes when the File menu is selected in Revit
No
When attempting to use the "Data.ExportToExcel" Dynamo node, a Warning is thrown and the graph fails to run.
"Data.ExportToExcel" node not working in Dynamo for Revit
Yes
When printing a view in Revit some patterns do not print as seen on screen and disappear when zoomed out.
Some patterns disappear when printed or zoomed out in Revit
No
Copying a schedule from one BIM 360 Revit model to another copies the links as well.
No
Mirrored elements in linked Revit model appear transparent in Autodesk Viewer
No
Users reported  temporary graphical issues of generic models in Revit 2021 realistic view typically after quick copy and zoom.
Transparent display in realistic view at copy/ zoom of specific families with complex cuts in Revit ...
Yes
Users reported weak performance at sync with central at a specific cloud worksharing model.
Slow performance at sync with central at a specific cloud worksharing model in Revit
Yes
"Object reference not set to an instance of an object." while model export from Revit Structure 2022 to Robot Structural Analysis 2022
"Object reference not set to an instance of an object." while model export from Revit Structure 2022...
No
Users reported that '-nan m' value appears when changing sill height for a specific window family in Revit. When changing the support height to 0.0 m the following error message appears: "One or more references related to the highlighted element are now incorrect".
Yes
How to keep Revit Server running when support for Microsoft Silverlight is discontinued? Revit Server Administrator Panel and its content will soon be unavailable due to lack of support for Microsoft Silverlight.
No
When using the Insert tab in the Revit ribbon, Coordination Model does not exist as an option
Coordination model not available in Revit ribbon
No
How to create a schedule that includes all Wall Types that are in the Revit model? Data can be exported to Excel file.
No
IFC 2x3 from Archicad cannot be opened in Revit
IFC from Archicad cannot be opened in Revit
No
How to reduce the size of a complex family in Revit? When the family size reaches close to, for example, 50MB and is used multiple times in projects causing the entire Revit model to grow rapidly.
No
When using the Precast Configuration in Revit, the Reinforcement Fabric drop down has no types available to choose
Can not find fabric mesh types in Revit Precast Configuration menu
No
Users reported that tags in detail groups change orientation parameter to 'Model' in different group instances in Revit.
Tags in detail groups change orientation parameter to 'Model' in different group instances in Revit
Yes
Users reported that curved railings material is not exported to IFC from Revit.
Curved railings material not exported to IFC from Revit
Yes
Unable to export all loaded wall types to Excel from Revit.
No
How to change external dimensions of a building without manually moving elements assigned to walls in Revit? This mainly applies to families that have walls as a host, such as wall cupboards, sinks, radiators, etc.
How to change exterior wall dimensions without manually moving assigned elements in Revit
No
After setting up shared coordinates, the "Angle to True North" is different in the link and host Revit models.
After setting up shared coordinates, the "Angle to True North" is different in the link and host Rev...
No
Users reported that a crash occurs every time trying to open a cloud model in Revit.
Crash occurs when trying to open any cloud model in Revit
No
Users reported that MEP elements located behind the section are visible in the section view.
MEP elements located behind section visible in section view in Revit
Yes
After loading and correctly mapping a P&ID Model in Revit, the connection between the Revit model and the P&ID Modeler is not working as expected.
P&ID Modeler does not work properly in Revit despite of correct mapping
No
Add a Filled Region to a 3D view to show hatching around certain elements.
Filled Region in a 3D view in Revit
No
When selecting a specific family inside of a Revit project and trying to change this to another one, the program reports: "Can't use this type in this host".
"Can't use this type in this host" when trying to change a placed family to another one inside of a ...
No
Controlling the Visibility Graphics of the host model elements without affecting the link in Revit so that categories can be hidden in the host model but show in the link model.
No
Components were created as Model In-Place but need to be converted to a Revit Family.
Convert Model In-Place Component to a Family in Revit
No
Wall lines are showing through the Column in Revit even when the wall is joined to the column.
No
Crash when running the Fabrication Worksheet preview in Revit
No
Is it possible to control the size of a scope box by numerical parameters in Revit?
Ability to control the size of a scope box by numerical parameters in Revit
No
User reported that when use Graded Region the error "A serious error has occurred. The current action has been cancelled..." occurs.
"A serious error has occurred. The current action has been cancelled..." error occur when use Graded...
No
Phase filter "None" disappears in Revit LT 2022
Yes
June 2021
Summary
Knowledge Article
Incident Reported
After pinning a model or element in Revit to ensure it doesn't move, if the Move tool is used then the element will move on screen.
Pinned model moves when using the Move tool in Revit
No
When publishing Revit models to BIM 360 teams, certain models fail to complete.
Models fail to publish from Revit to BIM 360 Teams
No
Symbolic lines are not editable for Shaft opening in Revit
Yes
Unable to model a wall of small length in a particular sequence in Revit
Unable to model a wall of small length in particular sequence in Revit
Yes
When trying to hide a linked model by turning off or hiding the workset the model is on in Revit, the model visibility is not affected.
When turning off or hiding a workset that contains a linked model, the link does not turn off or hid...
No
Users reported that pipe accessory families got transformed when using “Use annotation scaling” properties in Revit
Pipe accessory families got transformed when using “Use annotation scaling” properties in Revit
No
Additional black dashed lines are printed when detailed lines are grouped in Revit 2020
Yes
User reported that Revit become unusable on large models when Edit Type a steel connection which was propagated before.
When edit steel connections Revit become unusable
Yes
When including a roundup() operation in a Revit schedule formula, the total is significantly inflated.
Formula with roundup() causes large increase in Revit schedule total
No
Generic Model loses its host when splitting the structural framing element In Revit
Yes
When placing beams in a Revit floor plan, they are snapping to random columns or being clipped when near columns.
Beams snapping unexpectedly to incorrect columns in Revit plans
No
When mitering two beams to a column in Revit, the steel connection goes through the column instead of cutting through it.
Miter Beams to a Column in Revit
No
When drawing a path of travel line through a floor opening, the message "Unable to find a route between the points" appears and the path cannot be drawn
"Unable to find a route between the points" when using the Path of Travel tool with a floor opening ...
No
The shadow of the building is not displayed correctly with realistic visual style in a site plan in Revit
The shadow of the building is not displayed correctly in a site plan in Revit
Yes
How to set dynamically changing location of 'Default path for user files' in Revit? It is important that for example for this path: \\xxxx.server.com\%USERNAME%\Documents\Revit_projects\ the xxxx variables were indicated based on the location of the user who logs into the Windows account.
No
When opening a newly saved model from Revit Server, a following error message is displayed: "This operation could not be completed. Please try again...".
"This operation could not be completed. Please try again..." when opening a newly saved model from R...
No
Unable to download and install Issues Addon for Revit. From where to download the current version of this add-on?
No
When running Systems Analysis in Revit the following error message appears: "The process cannot access the file 'eplusout.audit' because it is being used by another process."
"The process cannot access the file 'eplusout.audit'..." when running Systems Analysis in Revit
No
When trying to open specific models from Revit Server this error message appears: "This operation could not be completed. Please
try again...".
"This operation could not be completed..." when trying to open specific models from Revit Server
Yes
The following message displays when opening a gbXML file in Revit: "The XML file does not contain any Results
elements!". Geometry that is contained in *.XML files cannot be imported into Revit. However, it is supported by Autodesk Viewer or Aragog gbXML Viewer 12.39.
"The XML file does not contain any Results elements!" when opening gbXML in Revit
No
Users reported that "Tag all (non tagged)" assigns tags to instances that were added to multi-leader tag in Revit.
Tag all (non tagged) assigns tags to instances that were added to multi-leader tag created by  in Re...
Yes
Are there any issues when opening Revit models with different versions of Security Fix installed? For example, user A saved a model in Revit 2020.2.4 and user B opens it in Revit 2020.0.1. Is this possible? Does this lead to any type of complications?
Opening Revit models with different versions of Security Fix installed
No
Users reported that view name containing Hebrew text and numbers is incorrect in Revit.
Wrong view name containing Hebrew text and numbers in Revit
Yes
Users reported that when applying changes to plan view in Revit 2022, program crashes with a "serious error" and creates a Crash Error Report. The behavior is recurring while changing the title on a sheet, the properties of the view or editing stairs.
Revit 2022 crashes when applying changes to the plan view
No
How to change the text size of a tag label from inside the Revit project.
How to change the text size of a tag from inside the Revit project
No
Users reported that Revit does not keep the perpendicular floor thickness when creating sloped floors using the Modify Sub Elements feature.
Perpendicular floor thickness not kept when creating sloped floors using the Modify Sub Elements fea...
Yes
Incorrect display in realistic mode, artifacts in elevation views in Revit.
Yes
How to view linked models in the BIM360 viewer within the host model?
No
Users reported that Wall Foundation type dimensions set in type properties do not match the placed wall foundation in Revit.
Wall Foundation Type Dimensions not working in Revit
No
Users reported that while printing PDFs using vector processing, text in all foreground links prints in a different color than in Revit view.
Incorrect colors while printing CAD links with vector processing in Revit 2020
Yes
Is it possible to revert back to a previous model state using the Revisions feature in Revit?
No
When assigning a duct system to another Design Option in Revit, the System name of the duct elements get automatically changed.
System name of ducts changes when assigned to a new Design Option in Revit
No
What is the difference between the features Phasing and Design Options in Revit?
No
Is it possible for Revit users to open the actual Revit Cloud Model directly on the Cloud?
No
When importing or linking a DWG in Revit, the geometry appears distorted and deformed.
Distorted display of imported or linked DWG geometry in Revit
No
Extra pages are printed when printing multiple sheets from Revit.
No
Unable to export to Advance Steel from Revit, there seems to be a problem in AdvanceSteelExtension which does not seems to support some kind of particular walls.
"Advance Steel Extension encountered an error. We are sorry for the inconvenience." message received...
Yes
Custom piping annotations inserted into model have labels that do not align correctly in Revit
Custom piping annotation text doesn't line up in Revit
No
When opening a specific 3D view in Revit, there is a faulty display of textures and elements are deformed.
Faulty display of specific 3D view in Revit
No
Users reported that spot elevation with bottom display gives incorrect values for linked objects in Revit.
Spot elevation with bottom display gives incorrect values for linked objects in Revit
Yes
When converting a selection of duct using the Design to Fabrication tool in Revit, additional connected duct that is not selected also gets converted.
Extra duct is getting converted when using the Design to Fabrication tool in Revit
No
When opening the 3D realistic view of a model in Revit, it displays a faulty and glitchy texture.
Faulty display of 3D realistic view in Revit
No
BIM 360 icon is missing from Revit 2022 home page
No
How to make a smooth join or cut in timber beams in Revit?
No
Users reported that a certain type (size) of a custom window family fails to cut one particular wall in a Revit project file.
"Can't cut instance out of Wall" when trying to place a custom window in a curved wall in Revit
Yes
What are the available tools and workflows to create excavation plans in Revit?
Best practices and tools to create excavation plans in Revit
No
When trying to place spaces automatically based on a linked model in Revit, the program reports "Space is not in a properly enclosed region".
"Space is not in a properly enclosed region" when trying to place spaces automatically based on a li...
No
Users reported, that when exporting a Revit model using the Revit IFC v.21.2.1.0 version, some of the openings go missing in the resulting IFC model.
Openings missing in exported IFC file when using Revit IFC Exporter version v.21.2.1.0
No
Users reported that when navigating in a specific model view, some of the elements unexpectedly disappear at a certain zoom scale in Revit.
Disappearing elements at certain Zoom scales in Revit
No
A Revit family with an imported .DWG file is missing from one view even though the family category is turned on.
A Revit family is missing from one view
No
A window is over two different walls but the void is only cutting one of the walls in Revit.
A window that is over two different walls does not cut both walls in Revit
No
May 2021
Summary
Knowledge Article
Incident Reported
How to re-establish the internal coordinate system for a Revit file after it has already been established.
How to re-establish shared coordinates in Revit
No
Locked parameter inside family flexes when the family is loaded into a Revit project.
Locked family parameter is flexing when loaded into Revit
No
When snapping to elevation markers in Revit, the snaps only work for markers placed on the main level.
Snaps for Elevation markers only work on main level in Revit
No
When placing a spot elevation in Revit on a sloped driveway (floor) the elevation is initially displayed, but when clicking on the floor it disappears.
Unable to post spot elevation on sloped driveway in Revit
No
When copying elements between Revit files, the program stops responding and the message "A fatal error has occurred.  The application will be terminated" appears and Revit crashes.
"A fatal error has occurred.  The application will be terminated..." error appears when copying elem...
No
When creating a Sheet in Revit, certain parameters cannot be removed from the properties for the Sheet.
Cannot remove certain parameters associated with Sheets in Revit
No
When upgrading a local Revit model between versions, the process fails and the error "Data in file <FileName> is corrupt and needs to be manually recovered" appears.
"Data in file <FileName> is corrupt and needs to be manually recovered" appears when trying to upgra...
No
IFC export taking a long time for a specific set of detailed elements from Revit
No
When printing views or sheets from Revit, unexpected lines show in print output.
Unexpected lines show up on printed output from Revit
No
When opening any family file in Revit, the program crashes with a CER report and an error message, "An unrecoverable error has occurred".
"An unrecoverable error has occurred" appears when opening any Family file in Revit
No
How to add a physical offset to a column from its analytical line in Revit similar to the functionality seen in Tekla
No
Users reported that some revisions do not show on a titleblock revision schedule.
Revision not showing on Titleblock revision schedule in Revit
No
RevitAccelerator.exe and PacCache only run for one user when using Revit cloud worksharing in Citrix VDI environment
RevitAccelerator.exe and PacCache only run for one user in Citrix VDI environment
No
How to select nested families in a project file using a Dynamo script in Revit?
No
When linking an IFC that was created with Shared Coordinates, the coordinate location is lost and the models no longer align.
Exported IFC loses it's coordinates when linking into Revit
Yes
Users reported that "Changes to groups are not allowed..." is displayed exporting model with groups to IFC selecting Store IFC GUID in an element parameter after export from Revit
"Changes to groups are not allowed..." exporting model to IFC selecting IFC GUID to be stored in an ...
Yes
"There are no projects in this BIM 360 account yet" when trying to access Revit BIM 360 models.
No
Unable to select any of created Zone Equipment in the Properties pallet for Energy Analysis in Revit. Although systems have been created, the only one that is selectable is <None>.
No
When trying to calculate flow for piping systems In Revit, the following warning message appears: "<System Name>: It is not possible to calculate the flow since the flow direction mismatch. Please check flow direction on all equipment in the system."
"<System Name>: It is not possible to calculate the flow since the flow direction mismatch..." when ...
Yes
When Revit is launched, there is a major performance drop in other applications. For example when writing text in Word or Notepad or navigating an open 3D model in Navisworks or Solibri.
No
Save time for Revit model on BIM 360 does not match Sync time
No
Users reported that when reviewing the INI for Revit, the Custom Colors are recorded as BRG instead of RGB.
BRG instead of RGB in Revit Custom Colors in INI
No
Users reported that a Detail Component in wall sweep is offset from wall in section views in Revit.
Yes
The following error message is displayed when opening a model from Revit Server: "An unknown error occurred and the operation could not be completed. If this error recurs, please contact customer support.".
"An unknown error occurred and the operation could not be completed..." when opening a model from Re...
No
Users reported that when attempting to see Issues made in BIM 360 on a model in the Shared or Consumed folder, the issues are not visible in Revit via the Revit Issues Add-in. The Load issues dialog displays, "There is no data available".
"There is no data available" when viewing Issues in Revit
Yes
In the Revit export menu, the option to export a Solar Study Animation is greyed out.
Solar Study export greyed out in Revit menu
No
Users report that when launching Revit with a network license, the home page is unresponsive to mouse clicks even though the buttons appear to be interactive.
Revit Home Page and Ribbon greyed out and Inactive
Yes
Users reported that when tagging a property line in Revit, the line segments cannot be tagged and appear to not be working.
Revit cannot tag Property Line
Yes
Users reported that when running a Systems Energy Analysis in Revit, the report comes back with the error, "EnergyPlus simulation did not generate a report for systems analysis."
"EnergyPlus simulation did not generate a report for systems analysis" when running a Systems Energy...
Yes
Floor slabs are divided into multiple IFC objects when exported to IFC from Revit
No
Users reported that walls geometry is not correctly exported to IFC from Revit.
Walls geometry not correctly exported to IFC from Revit
Yes
Users reported that wrong model geometry is imported from linked IFC in Revit
Wrong model geometry imported from IFC to Revit
Yes
Users reported that macro manager sharp develop does not launch in Revit
Macro manager sharp develop does not launch in Revit
Yes
Autodesk Desktop Connector crashes on startup in an emulated Windows environment. This happens every time a system image created on AWS is booted. This applies to any version of Autodesk Desktop Connector installed. When the program is shut down, an Error Report is generated to be sent.
No
When editing a Mass in plan in Revit, changing or moving the line only moves the top or bottom edge of the mass.
Editing a Mass in Plan in Revit
No
What is the recommended workflow for designing high-rise buildings in Revit?
Recommended workflow for designing high-rise buildings in Revit
No
A soft crash occurs in Revit when running a script in Dynamo to perform multiple operations on selected files. In addition, it has been observed that a similar soft crash occurs in Revit when closing a recently opened view, sheet, or schedule tab. When more than one model is open and one of them is closed then changes made for the rest of them will not be saved.
When running a script in Dynamo that is supposed to perform multiple operations on files, a soft cra...
No
A problem arises with synchronizing and working with central models in Revit. When a project member synchronizes with the central model, suddenly becomes the owner of random elements (items that have never been touched) and worksets, causing conflict between other users working on the model at the same time. When the same project member synchronizes a second time, without doing anything between synchronizations, suddenly becomes an unexpected owner of all elements in the model.
A project member who synchronizes a model becomes an unexpected owner of randomly selected elements ...
No
Unable to create material takeoff that contains all stair surfaces in Revit. It is possible to generate such a schedule for Runs and Landings but not for the surfaces for side areas and under stairs.
Unable to create material takeoff containing all stair surfaces in Revit
No
Batch Printing process is slow, not efficient and requires internet access while printing in Revit. A similar tool that is available in AutoCAD works more efficiently.
Batch Printing process is slow and not efficient in Revit compared to AutoCAD
No
Users reported that when a structural connection is added to structural beams in Revit 2021 or 2022, the beams disappear from plan view.
Beams disappear after adding a structural Connection in Revit 2021 or 2022
Yes
Users reported that walls geometry are incorrect exporting model to IFC from Revit
Incorrect walls geometry exported to IFC from Revit
Yes
Slow performance in Revit in Remote Desktop Services environment
No
Imported RCP point cloud is causing severe performance issues in Revit.
Point Cloud into Revit is too large and causes performance issues
No
Missing some elements when the IFC exported from ArchiCAD is opened in Revit
No
Where to find the Navisworks NWC Export Utility for Revit
Where to find the Navisworks Exporter for Revit
No
Exported data from the Insight energy model generated from Revit cannot be later analyzed in EnergyPlus. The following error message appears when running the simulation: "Run Complete. Energy Plus Terminated--Fatal Error Detected...".
Exported data from the Insight energy model generated from Revit cannot be later analyzed in EnergyP...
No
Tag not detecting the expected value of a parameter from Filled Region in Revit. More precisely, it does not display a Mark parameter from the Identity Data category. A question mark is displayed instead of a number.
No
Unable to create custom subcategories outside of the available properties list and easily drag and drop option for moving views, sheets or schedules into them in the Project Browser in Revit.
Unable to create custom subcategories outside of the available list and easily drag and drop option ...
No
Users reported that while opening/importing IFC with Revit the column mapping is incorrect.
Incorrect column mapping when opening IFC in Revit
Yes
When upgrading a model to Revit 2022 or above, split keynote schedules disappear and appear duplicated instead
Split Keynote Schedule disappears and duplicates when upgrading a Revit model
Yes
How to export an entire set of views or sheets from Revit to DWFx?
No
When exporting a DWG from Revit to AutoCAD, hidden lines appear in the exported view or sheet.
Hidden lines appear in AutoCAD when exporting DWG from Revit
No
Users reported that door threshold area is not calculated by Roombook extension for Revit if the project was created using a metric template. If the project is created with an imperial template, door threshold area is calculated.
Roombook extension for Revit does not calculate door threshold area if the project uses a metric tem...
Yes
A stereo panorama created in Revit is not viewable in Chrome and appears to be a gray mass.
Can't view Revit stereo panorama in Chrome
No
After installing Revit LT, the Mechanical, Architecture, and Plumbing templates are not available for use.
Mechanical, Architecture, and Plumbing templates are not available for Revit LT
No
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Nachricht 4 von 4
lim.wendy
als Antwort auf: lim.wendy
Apr 2021
"A fatal error has occurred.  The application will be terminated."  when working in a Revit model
"An unrecoverable error has occurred" ​​​​​​​when signing out of Revit
"A serious error has occurred" while replicating a schedule in Revit
"Error Code: -2147217833 Error Message: The field is too small to accept the amount of data you atte...
"Some families have become unusable" when trying to create a Revit Cloud Model
"This file is open for editing by another user. If you open the file, you cannot save changes until ...
"Unrecoverable error has occurred..." error appears and the program crashes when linking a CAD file ...
"Warning:Data.ImportExcel failed.  The COM object of type 'Microsoft.Office.Interop.Excel.Applicatio...
"You currently don't have access to Revit cloud models..." at Revit home page
After creating an Energy Model, air gaps appear in spot where walls of two different widths are join...
After linking a civil DWG the Revit 3D view stops responding to zoom commands
After syncing, some updates do not appear in Revit model
An unknown error occurred and the operation could not be completed, when initiating a Revit model to...
BIM 360 Drive is missing after updating Desktop Connector
Cannot remove Fixture from Circuit in Revit
Ceiling grids shows through lighting fixtures from linked model in Revit
Centerline symbol for dimensions is not shown for the steel columns with structural steel connection...
Classification of the severity of warnings in Revit
Combined parameters not exported to IFC property sets from Revit
Crash with Customer Error Report when opening computer and computer freezes while working in Revit a...
Create New Local Disabled in Revit when working from home on VPN after working on office network
Custom shared parameters not exported as IFC properties on export to IFC from Revit.
Cut symbol is displayed as a black block in the PDF in Revit
Documentation of Projected Coordinate System Reference for Export IFC in Revit
Duplicate parameter names in IFC files exported from Revit
DWG files exported from Revit are blank when opened
Elements coordinates are different between the exported IFC and the Revit model
Elements from the imported DXF file are missing when exported to SAT file from Revit
Error with shadows displayed in 3D view in Realistic mode in Revit
Exporting Revit files to SDNF or SMLX, the name of the same element is named differently after impor...
File Name path changes after using Modify Setup button in IFC export window in Revit
Glazing renders as shade or hole in roof in Insight analysis in Revit
Gradian unit for angle dimension in Revit German Version
How is the Supply/Return Airflow calculated for a Space in Revit
How to associate section views with a level in Revit
How to create a View Filter for Phase Created in Revit
How to disable background calculations in Revit
How to manually install additional Dynamo packages containing nodes for Revit
How to modify the Route Analysis travel speed in Revit
How to use Shared Views in Revit
How to use System Analysis in Revit
IFC File with rotation linked incorrectly in Revit, shows correctly in BIM 360 and Navisworks
IFC opening element does not cut floor importing IFC to Revit
Insight Daylighting Analysis fails with "All jobs failed or cancelled for LEED v4 EQc7 opt 2"
Internal origin does not exist in Revit
Is it possible to use BIM Collaborate Pro with Plant 3D 2021 and Revit 2020?
Is there training available for Revit that provides CEUs?
Keyboard shortcut for "Isolate Element" not working for assembly elements in Revit
KeyboardShortcuts.xml is not copied from UserDataCache to user folder for Revit 2022
Large IFC files when exporting projects with Fabrication parts from Revit
Lighting Analysis Illuminance dots are all red when Range is not Auto in Revit
Lighting and Solar analysis icons not showing in the Analyze tab within Revit 2021
Linked coordination model is not visible in Revit 2020
Linking IFC files need too much time in Revit
MEP Fabrication tag displays question mark when part is offset horizontal and vertical in Revit
Merging and splitting wall elements per levels in Revit
Model dimensions disappear/ change after regen in the Revit view
Multiple blank sheets print before and after in PDF print set produced from Revit
Nested detail families inside host detail families appear and disappear unpredictably when mirrored
Option to import the Rhinocerous 3DM file is missing in Revit LT 2022
Option to use FormIt Interoperability is missing in Revit LT 2022
Parameter for selecting Workset in Schedules for Revit LT 2022
Pipes connected to work plane based equipment are trimmed / extended when rotated which is causing d...
Publishing model from Manage Cloud models dialogue causes freezing and delays in Revit
Random lines appear on conduit fittings in Revit
Realistic Views do not display geometry and there is a prompt to submit an Error Report on exit in R...
Rebar shape handles move from object using the Viewcube in 3D in Revit
Recalculation takes a very long time in Areabook Revit
Revit duplicates mapped Network Drives
Revit freezes when using any commands
Revit Link invisible in some Revit views
Revit suddenly freezes when selecting any of the tools in the Precast tab
Room Bounding constraints are missing for most elements after linking IFC exported from ArchiCAD in ...
Rooms not exported to IFC from Revit
Serious error and program crash when creating a new callout with a specific view template in a speci...
Sloped floors not exported to IFC from Revit
Some elements missing linking IFC in Revit
Some of the instance parameters of a custom parameter set definition fail to export to IFC from Revi...
Staircase family shows thick line width in plan view in Revit
Sweep returns disappear when mirroring Walls in Revit
System Load Summary shows inaccurate results in Revit
System requirements for Revit 2022 products
The selection box of the host family with connector in nested family unexpectedly includes the proje...
Type Name for wall foundations not exported to IFC from Revit
Unable to print to PDF in specified location when using DiRoots add-in in Revit
Unexpected behavior for Inclined Plan region In Revit
Unexpected change in wall geometry when upgrading specific file from Revit 2019 to 2020
Watch 3D node of Dynamo  doesn't work in Remote environment
When a pipe fitting is held through its control point and moved in Revit 2021 the connected pipe doe...
When assigning any IES files to a lighting fixture, the fixture tags shift position in Revit
When a structural plate is placed adjacent to a pile cap and material applied with a ‘solid fill’ co...
When importing Advance Steel files to Revit pipe bend connections are not imported
When opening Revit cloud workshared models, an “_LT” is added to the filename
When using Manage Lookup Tables in Revit family editor, Revit does not open the custom location spec...
Worksharing Monitor not displaying in Revit ribbon
Wrong bounding boxes at in- place windows families from linked IFC data in Revit
Mar 2021
"A fatal error has occurred" when modifying a stair in Revit
"A serious error occurred. The current action has been canceled" when opening a file in Revit
"Cloud worksharing requires a subscription to BIM 360 Design..." when clicking on Worksets icon on o...
"Invalid Image File" shows in the image thumbnail of the Decal dialog after upgrading the Revit file
"Unable to upgrade Revit cloud models" appears for a Cloud model upgrade on BIM 360 but the local up...
"Unhandled exception has occurred in a component in your application" when Calculating Room Quantiti...
Are IFC GUID exported from Revit case sensitive
Autodesk Point Layout not creating points in Revit views
Cannot print from any Autodesk product
Cannot see any Revit Cloud Worksharing models when logging in Revit 2021 with a specific user in a s...
Certain family object does not show when published to BIM 360 while being visible in Revit
Changes to Fabrication connector colors prevent display in Revit
Changing the class output to "IfcBuildingElementProxy" results in the rebars being in the wrong loca...
Cloud workshared Revit Link files are not visible in external reference.
Data loss and visibility issues when exporting In-place elements/Families to IFC 4 from Revit.
Dimension values issue at elements in phases in Revit
Duplicating a Structural Framing element loses almost all the parameters
Elements with area smaller than 2.5 are not ignored in Buildingbook in Revit
End treatment on structural rebar behaves not correctly in Revit
European steel profiles in English are missing when download Revit 2021 content
Fabrication Reports, Labor Installation Set Time shows zero after MAJ export in Revit
False representation of several elements linking IFC to Revit
Far clipping is not correctly restored after using restore view properties in Revit.
Graphical Column Schedules do not display columns’ offset from grids if the column geometry intersec...
Grid lines on ceiling are not exported when IFC is exported from Revit
Hidden lines do not print to PDF as seen on screen in Revit
How to change the number of decimal places in Family Parameter in Revit
How to correct the model orientation after mistakenly drawn aligned to True North instead of Project...
How to find the file location of Revit Generative Design evaluation results
How to get a list of all models located on Revit Server
How to send a Revit model without 2D views or sheets
How to show nested families in Revit schedules
Images not printed from Worksheets, Reports or Labels in Fabrication products
Importing all used families from a linked *.RVT into the main model in Revit
In Revit 2021 decals containing cutouts image displays black and white in realistic view while in Re...
Insulation is not displayed on Fabrication parts in Revit
Lag occurs when moving elements in a Revit structural plan
Linked files are showing as Halftone in Revit
Linking an IFC into Revit places some elements in the wrong location
Material fill patterns are mixed up among user-defined material when using transfer project standard...
Missing folders from Import/Link RVT dialog while linking model via External Resource in Revit
Model gets wrong when exporting IFC from Revit
ModelService logs are much larger on one Revit server than on others
Model won't open unless opening another Revit model first
More wall references are detected automatically when dimensioning in Revit
Names of paint application styles for materials differ in Spanish and English versions of Revit 2021
Non-Uniformly scaled dwg blocks containing 3D Solids do not import or link in Revit
Option to select the "Level-above" or "Level-below" in the view filter for Revit
PDFs printed from Revit have distorted text, incorrect fonts, missing images or other problems after...
Performance in Revit is slow when re-hosting electrical device to a new location
Pipes are not displayed correctly when Plan Region is applied in Revit.
Printing using a ultrawide curved monitor set to split the screen results in distorted text in Revit
Project location doesn't get automatically recognized when acquiring coordinates from a DWG in Revit
Revit crash at closing Revit
Revit doesn't respond or crashes when coping and pasting floor plan into newly created floor plan
Revit model size stored in BIM 360 does not match its downloaded and saved local version
Slanted embedded curtain wall is losing its horizontal grid spacing
Slow performance while panning and zooming on a specific project when opened from BIM360
Some parameter values showing as 0 or do not populate in Revit schedule
Some profiles not coped \ cut importing IFC to Revit
Stairs are duplicated when viewing the NWC exported from Revit in Navisworks
Structural Connection elements in wrong position when exporting an IFC from Revit
Switching to Chinese input language freezes Revit 2021
Temporary Dimensions for Pipes appear far from the object in Revit
Text is stretched or scaled when printed on wide monitor from VDI environment while in Revit
The height of Structual Columns is  missing from the element properties in Revit
The lighting analysis graph within Insight has too large of a range in a Revit model
Trim/Extend command does not work for stacked walls
Two Pole Panel Loads Not Feeding Through Transformers as expected in Revit
Unable to export Rebar Number to IFC for varying rebar sets from Revit
Underground Existing Elements shows as New Construction in Revit
View Filters are not applied correctly on the linked Revit files when publishing them to BIM 360
Wall join options are greyed out when working in a workshared model in Revit
Wall material areas are not calculated in material takeoff for multilayered walls
Wall opening family from Revit has incorrect dimensions when exported to IFC
When exporting a sheet from Revit to AutoCAD the elements in Model are very far away
When import SMLX file into Revit the model comes out all wrong with plenty of warnings and with many...
Windows crashes when Revit tries to open a file with Offline Files enabled
Wrong project position when exporting a specific project to IFC using shared coordinates from Revit
“To open or save files in a connected drive, start Desktop Connector” appears after opening a projec...
Feb 2021
"A serious error has occurred. The current action has been canceled." when trying to duplicate a spe...
"A serious error has occurred. The current action has been cancelled." appears when upgrading a Revi...
"Can't draw because Work Plane is at a very sharp angle" error when modifying objects in Revit
"Element could not be exported" while exporting model to SMLX from Revit
"Failed to initialize the add-in 'Revit Issues Addin..." message appears when launching Revit
"It looks like the requested service is unavailable..." when linking a Revit model from Autodesk Dri...
"Operation Could Not Be Completed..." when trying to create new local from or synchronize to a centr...
"Sync with central failed ..." and crash when syncing a Revit Cloud Workshared model in BIM 360
"Unable to Access the Model..." message shows intermittently in a file-based worksharing model in Re...
Adaptive structural deck missing in IFC exported from Revit
BIM 360 project subfolders of the removed parent folder are displayed on the Revit Home page
Bisector connections not exported to IFC from Revit
Cannot upload gbXML files to Green Building Studio due to discontinued Adobe Flash Player support
Clicking any Cloud Model to open causes Revit to crash
Copying wall sweep from the elevation view places the copy to a different level than the original
Create a Custom Tag in Revit
Do specific IP addresses need to be opened for BIM 360 Revit cloud worksharing services to function?
Draw order changes when printing to PDF with Vector setting in Revit
Families with type catalogs cannot be upgraded to Revit 2021
Geometric dimensions of openings are messed up after export to IFC from Revit
Hatches in DWG file linked into Revit disappear when zoomed in
Hosted Voids elevation changes randomly when the Host Beam type is being changed in Revit
How to index point clouds for use with Revit
How to override visibility graphics of families per type in Revit
IFC model is incomplete when linked into Revit
Inconsistent graphics regeneration at specific wall joins in a Revit model
Model shows as Wireframe in non-Wireframe views in Revit
Not correct geometry linking DGN into Revit
Painting a material on the face of split elements does not show correctly in a Revit project
Part preview does not display in Edit Part dialog box for Fabrication parts in Revit
Plate projections for Platform Plate connection are not working correctly in Revit
Point Cloud from Recap is not aligned to the project base point in Revit
Railing posts missing after upgrade in Revit
Rebar cover changes automatically while Editing In-Place a Generic Model with rebars inside
Revit crashes when attempting to sign in to A360
Revit surface points not reporting Absolute Value
Rooms in IFC are missing when exporting IFC from Revit
Selecting multiple items using Ctrl + Left click in Revit is giving a right click
Slow performance in Properties Panel when changing or searching for Detail Items in a specific Revit...
Some floors not exported to IFC from Revit
Some Revit elements appear as boxes in an exported IFC file
Specific elements exported with a new IFC GUID from Revit
Steel beams with Modifiers applied don't show in hidden lines when placed under Floors/Roofs in Revi...
Steel connection does not resize after the size of a beam is changed in Revit
Structural Beam System element causes incorrect graphic display of other elements in Revit
Switchback in Navisworks doesn't work on linked Revit files
Text copied from Microsoft Word does not maintain formatting when pasted in Revit
Text in a Panel Schedule placed on a sheet appears differently than in Panel Schedule view in Revit
The same wall type being exported to IFC does not have all the parameters
Unable to find report generated after performing lightning analysis without any errors in Revit
Unexpected objects show in the Autodesk Viewer model tree for DWFX exported from Revit
Unexpected view range of a linked model is displayed in the host in Revit
Unrecoverable Error when opening a view in cloud model in Revit
Upgrading a Revit model creates very large journal files
Visibility of Layers from linked DWG file is not refreshed in Revit when reloading the file
When pipe penetrates a wall, the cut does not honor pipe thickness in Revit
Where to download Graitec PowerPack for Revit
“An unrecoverable error has occurred…” when opening files in Revit
Wendy Lim
Rails Summit
