2019.1 Unable to select Scope Box
TravisVaughanKJWA
TravisVaughanKJWA
Anyone ever have issues with being able to select and/or modify a scope box once it has been placed?
I've tried picking on it, using a selection box, etc. Turned off Crop View, Crop Region View and Annotation Crop. Have Scope Box set to None. I see the dotted green line representing the Scope Box but I am unable to select it! Tried in 3D, plan and elevation views...
Screen grabScreen grab
Hey,
Looks like your scope box is pinned and you're unable to select it. Bottom of your Revit screen select the pin icon so there is no longer a red x and your problem will be fixed. If that icon has an X through it then any element you've pinned you will not be able to select.
mitchcantlon
late to the party here but for anyone searching for the same issue......
I couldn't select the green dashed scope box until i realised i had created it in a design option!
Once i had opened the design option for editing i could select and adjust the scope box.
Lesson to self for next time - be out of the design option before creating.
