- Mute
- Permalink
- Report
While working in a local copy of a central model in the latest version of Revit (2018.2), I've been getting an error message when synchronizing that reads "You cannot synchronize to central until the model is repaired", see the attached image for the full message. This error has recently been happening more frequently - as much as once per week. Myself and two other team members are working from the same central model, but the corruption only occurs when a local copy is saved from my machine. This error has occurred on three separate projects from my computer, meaning the model itself is not part of the issue. We've noticed the corruption often happens when myself and another user synchronize simultaneously. It seem the path to the central model is disrupted when this happens, but out of 23 licenses in our office, this error has only occurred from my machine.
I have uninstalled and reinstalled Autodesk in its entirety on my computer, but this was ineffective as I continue getting the message after reinstalling. My computer meets all of the hardware and space requirements to run Autodesk.
Thanks for any thoughts or suggestions!
