2017 Revit Material Library Issue
I have recently installed 2017 Revit and I can seemingly do everything Revit is capable of except for using the material library. Whether I am changing the material of a wall, trying to "Paint" a material, etc., when I go to opening the material library, it crashes Revit or even my entire computer at times.
I have tried everything that I have seen in the forums include, but not limited to, a complete uninstall and re-install, turning off the "use hardware accelerations", add a new path to the contents, video driver update, etc. None of them have worked to this point.
Does anyone have a solution that actually works?
Thanks in advance!
aleksei.tkachenko
Hello
I have tried this method and It worked well
I tried it and this doesn't work either. My computer hasn't crashed since doing it, but it still crashes Revit.
Any other ideas?
Viveka_CD
Hi @Anonymous
Welcome to the Autodesk Community! Thanks for posting on the forum.Smiley Happy
Please send us your journal file to troubleshoot further.
Please try this link  How to perform a selective startup in Windows
See HERE for a similar issue.
You could also try a clean install of the Revit version on the user's machine.
Please mark this response as "Accept as Solution" if it answers your question. Kudos gladly accepted.
Viveka_CD
Hi @Anonymous
I just wanted to follow up here, were you able to resolve your issue?
Please mark any posts that help with "Accept as Solution" and thanks! Kudos welcome.
