2015: profiles
2015: profiles
arkitek2ss
2015: profiles
arkitek2ss
I am figuring out that when you add a reveal profile (mortar joint) within a cmu wall family, that there is no control over the lineweight of the reveal?
without using the linework command.
thanks,
Howard
ennujozlagam
yes
You added the reveals for the 3/8" mortar joints for every CMU?
Corsten.Au
Hi
I think you can filter the wall types, and give projection line the thickness you need.( even change colour and line type for that matter )
This way you would be controlling only CMU wall projection lines.. and other walls can show
defauly line thickness ..
Cheers!
Corsten
Building Designer
arkitek2ss
Toan,
shallow foundation wall.  just to show the type.
created a profile that I can adjust accordingly.
this would be at 3/8" scale.  our typical wall section
