2 Level Nested Family Parameter not Showing when Loaded in Project
jazzsharma200
jazzsharma200
Hello Guys!
I made one Family of Vertical Channel using 2 Level Family Template and nested it into Slab Based Family there i can see the Instance parameter Top Level,Base Level,Top Offset,Base Offset but when loaded into project these parameter gets lost.
Below is the Image of the Project
 This image When nested into Slab Based Family
anze.kumar
I don't understand completelly what you are trying to create or what your goal is, but seems to me that beacuse "slab based family" has different default settings than project, it just shows different parameters.
In project, you insert a famaily (for instance Generic Model) and it shows you the "Level" to which you want to insert it to.
When you operate with Slabs (Beams) or Walls, the default setting is that you have Base Level/Offset and Top level/Offset.
