1st Floor Walls are showing up on 2nd floor floorplan
Message 1 of 18
I am having an issue with my floor 1 walls showing up grayed out on the floor 2 floorplan. I have checked that the top constraints for the walls are "up to level: Level 2," and have added a floor to level 2. I have also checked the view range for level 2, and it does not extend down to level 1. Does anyone have any idea why this might be happening, and how to hide these walls on level 2?
Thank you!
Replies (17)
Message 2 of 18
Change the view's Underlay to None.
Message 3 of 18
RevitRx
here's where you can find the underlay settings:
www.RevitRx.com
Message 4 of 18
s.borello
Check your view range and turn off underlay.
Message 5 of 18
Thank you!
Message 6 of 18
ericboe
Thanks but even with no underlay, some of the walls are showing up??
Message 7 of 18
zaronzjohnson
Even when I remove underlay 1st floor is not only seen, but it also won't let me draw in the area because level 1 is being affected by what I do on level 2.
Message 8 of 18
Mitchell.currie
Can you please send a snip of your properties in the problem view.
Message 9 of 18
zaronzjohnson
I am sorry I am new to Revit. What is problem view?
Message 10 of 18
Mitchell.currie
Double-check that your view range is above the lower walls (as seen in first image).
Make sure the base of your wall doesn't cut into the top of your lower wall.
Message 11 of 18
zaronzjohnson
This is what its shows in View range. Same as the 1st floor.
Message 12 of 18
Mitchell.currie
When you draw a wall on the second floor what is the base offset and base constraint?
Message 13 of 18
zaronzjohnson
That is what I am trying to figure out. It is first time using Revit. I used autocad mostly for small items and basic 2D chemical engineering related projects. My tutor told me they will help me becuase I set up my whole properties layout wrong at the beginning. Thank you.
Message 14 of 18
shestadKMEUW
Community Visitor
Community Visitor
no. I'm still having the same issue OP shared
Message 15 of 18
shestadKMEUW
Community Visitor
Community Visitor
Where/how do you open this box to access these settings?
Message 16 of 18
designHSZCP
nevermind
Message 17 of 18
venus_verve
THANK YOU FOR POSTING THE VIEW RANGES
Message 18 of 18
venus_verve
THAT FIXED THE ISSUE FOR ME WITH MODEL COMPONETS SHOWING IN THE LVEL ABOVE.
