1200mm*1200mm .pat
1200mm*1200mm .pat
alejandromartinmate
1200mm*1200mm .pat
alejandromartinmate
Hi all I need a surface pattern 1200mmx1200mm grid pattern with a dashed line. I know is possible to import patterns but I need the .pat
Does anyone has that pattern?
Thank you very much
Accepted solutions (3)
GHASEM_ARIYANI
hello
you can use "hatchmaker" lisp in autocad for create any hatch pattern and use in revit.
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
hugha
Insufficient information regarding dashed line.
As fill patterns have no linestyle, you will need to explicitly lay out each dashed line segment.
Hugh Adamson
www.hatchkit.com.au
