Wrong cut geometry
Wrong cut geometry
AndrewButenko
Wrong cut geometry
AndrewButenko
Hello!
I'm trying to cut walls with the cut geometry tool. As a result of the work, I encountered not the correct operation of this tool.
Before the cut, the void and wall I created looked like this:
After the cut, the upper part of the wall had to be cut off. But I get a wall inside a void:
And this is repeated on different walls. I think the problem is in the geometry of the void, formed by me. But I can't guess what exactly. Perhaps someone has come across something similar?
snabil76
Dear,
I think this is Wrong location to your question , here you can ask to Revit API support
moturi.magati.george
Hi @AndrewButenko,
Since this forum is dedicated to Revit API support, you could try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
  Moturi George,     Developer Advocacy and Support,  ADN Open
