Wrong BBox in view
Wrong BBox in view
divanciucova
Wrong BBox in view
divanciucova
I'm using a room to create elevations, then crop them to the extents of the room. For some of the models the approach is not working and I cannot figure out why. these are my steps:
- place the sections along each boundary
- get the BBox of the room in each of the created sections
- deduct the outline of the view from the bbox
In some of the models this method returns a BBox that seams to be equal to a 3D Bbox of the room (instead of the desired BBox in view).
here's my code:
def set_crop_to_bb(element, view, crop_offset, doc=revit.doc):
    # set the crop box of the view to elements's bounding box in that view
    # draw 2 sets of outlines for each orientation (front/back, left/right)
    # # deactivate crop first, just to make sure the element appears in view
    view.CropBoxActive = False
    doc.Regenerate()
    bb = element.get_BoundingBox(view)
    active_view = revit.active_view
    #debug
    footprint = get_bb_outline(bb)
    for curve in footprint:
        l = doc.Create.NewDetailCurve(active_view, curve)
    pt1 = DB.XYZ(bb.Max.X, bb.Max.Y, bb.Min.Z)
    pt2 = DB.XYZ(bb.Max.X, bb.Max.Y, bb.Max.Z)
    pt3 = DB.XYZ(bb.Min.X, bb.Min.Y, bb.Max.Z)
    pt4 = DB.XYZ(bb.Min.X, bb.Min.Y, bb.Min.Z)
    pt7 = DB.XYZ(bb.Min.X, bb.Max.Y, bb.Min.Z)
    pt8 = DB.XYZ(bb.Min.X, bb.Max.Y, bb.Max.Z)
    pt5 = DB.XYZ(bb.Max.X, bb.Min.Y, bb.Max.Z)
    pt6 = DB.XYZ(bb.Max.X, bb.Min.Y, bb.Min.Z)
    l1 = DB.Line.CreateBound(pt1, pt2)
    l2 = DB.Line.CreateBound(pt2, pt3)
    l3 = DB.Line.CreateBound(pt3, pt4)
    l4 = DB.Line.CreateBound(pt4, pt1)
    l5 = DB.Line.CreateBound(pt6, pt5)
    l6 = DB.Line.CreateBound(pt5, pt8)
    l7 = DB.Line.CreateBound(pt8, pt7)
    l8 = DB.Line.CreateBound(pt7, pt6)
    curves_set1 = [l1, l2, l3, l4]
    curves_set2 = [l5, l6, l7, l8]
    crsm = view.GetCropRegionShapeManager()
    view_direction = view.ViewDirection
    view.CropBoxActive = True
    try:
        # try with set 1, if doesn't work try with set 2
        crop_loop = DB.CurveLoop.Create(List[DB.Curve](curves_set1))
        # offset the crop with the specified offset
        curve_loop_offset = DB.CurveLoop.CreateViaOffset(crop_loop, crop_offset, view_direction)
        # in case the offset works inwards, correct it to offset outwards
        if curve_loop_offset.GetExactLength() < crop_loop.GetExactLength():
            curve_loop_offset = DB.CurveLoop.CreateViaOffset(crop_loop, crop_offset, -view_direction)
        crsm.SetCropShape(curve_loop_offset)
    except:
        crop_loop = DB.CurveLoop.Create(List[DB.Curve](curves_set2))
        # curve_loop_offset = DB.CurveLoop.CreateViaOffset(crop_loop, crop_offset, view_direction) # fails here
        # if curve_loop_offset.GetExactLength() < crop_loop.GetExactLength():
        #     curve_loop_offset = DB.CurveLoop.CreateViaOffset(crop_loop, crop_offset, -view_direction)
        # crsm.SetCropShape(curve_loop_offset)
    return
Thanks!
Daria
divanciucova
Solved it!
The room was not visible in the created view, so the BBox was failing.
