ElementIntersectsElementFilter does not run familyInstance
klkl12234
klkl12234
Hello, ElementIntersectsElementFilter does not run familyInstance
It was successful in Element.
Below is the code.
Is there any other way?
Element ele = doc.GetElement(elementId);
//FamilyInstance insideElement = ele as FamilyInstance;
ElementIntersectsElementFilter elementIntersectsElementFilter = new ElementIntersectsElementFilter(ele);
var filters = new FilteredElementCollector(doc)
.WherePasses(elementIntersectsElementFilter)
.ToList();
I added an explanation.
The current goal is to review the selected ducts and ducts, the selected ducts and fittings, the selected fittings and ducts, and the interference between the selected fittings and fittings.
The current version is the 2019 version.
I would like to conduct an interference review.
For example, in the case of the first photo,
There's a duct called 'a' and a duct called 'b'.
Element ele = doc.GetElement('a');
.ToList();
The value of the filter is 'b'.
There is no problem so far.
This is a problem when a family instance (Duct fitting) called c is added.
.ToList();
The filter has a value of b but not a value of c.
When Duct fitting,I will find other ways.
My English was weak, so I used a translator.
Please excuse me..
jeremy_tammik
You provide little information in your nice and succinct question.
So, the nice and succinct answer is: No, sorry, I am not aware of any other way.
klkl12234
Hello, Thank you for your reply.
.ToList();
I thought there were all the elements in the filters.
I made one more and solved it.
var fittingFilters = new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_DuctFitting)
.ToList();
jeremy_tammik
Thank you for your more detailed explanation and congratulations on solving your task!
The Building Coder shares quite a few articles on this topic:
klkl12234
Thank you. You helped me a lot
