WPF form not same when run
manhgt214
manhgt214
why my form not show same when run in revit.
<Window x:Class="Basic1.WPF1"
            xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
            xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
            xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
            xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
            xmlns:local="clr-namespace:Basic1"
            mc:Ignorable="d"
            Title="WPF RevitAPI"
            WindowStartupLocation="CenterScreen"
            ResizeMode="NoResize"
            MaxHeight="250"
            MaxWidth="400"
            Height="250"
            Width="400">
    <Grid>
        <Button
            Content="OK"
            VerticalAlignment="Bottom"
            HorizontalAlignment="Right"
            Margin="0,0,20,20"
            Height="25"
            Width="70" Click="Button_Click_1"/>
        <Button
            Content="Cancel"
            Margin="0,0,150,20"
            Height="25"
            Width="70" Click="Button_Click"/>
        <GroupBox
            VerticalAlignment="Stretch"
            HorizontalAlignment="Stretch"
            Header="Get List Family"
            Margin="15,10,15,70"
            Height="150"
            Width="370"
            BorderBrush="Red"
            BorderThickness="2,2,2,2"/>
    </Grid>
</Window>
jeremy_tammik
I cannot say what exact setting might be causing this. However, it is quite common for a WPF form to appear differently in runtime than in the designer. Here is a discussion explaining some possible causes of why a WPF window layout looks different from VS designer when running:
Niko_Davydov
Hi @manhgt214 ,
you can try to change WindowStyle property. Window.WindowStyle Property (System.Windows) | Microsoft Learn
As Example
            WindowStyle="None"
            MaxHeight="250"
            MaxWidth="400"
            Height="250"
            Width="400">
<--... you code-->
Best regards,
Nikolai Davydov
Mohamed_Arshad
HI @manhgt214
    While designing the WPF form make sure you have a complete understanding of Grids.Because Grids play a major role in WPF Form design. I have changed your code a little bit so it became scalable. Try to understand the code which I have written and implement it.
Updated XAML Code
            mc:Ignorable="d"
            MaxHeight="250"
            MaxWidth="400"
            Height="250"
            Width="400">
    <!--Make 10 Pixel Offset-->
    <Grid Margin="10">
        <!--Form Layout-->
        <Grid.RowDefinitions>
            <RowDefinition/>
            <RowDefinition Height="Auto"/>
        </Grid.RowDefinitions>
        <Grid.ColumnDefinitions>
            <ColumnDefinition/>
            <ColumnDefinition Width="70"/>
        </Grid.ColumnDefinitions>
        <GroupBox VerticalAlignment="Stretch"
            BorderBrush="Red"
            Grid.ColumnSpan="3"/>
        <Button Content="OK" Grid.Row="1" Grid.Column="2" Margin="3" Click="Button_Click"/>
        <Button Content="Cancel" Grid.Row="1" Grid.Column="1" Margin="3" Click="Button_Click"/>
    </Grid>
</Window>
Output Image
Hope this will Helps 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
manhgt214
Thank you so much!
