How to open an Autodesk document file via Revit Api ?
Hans_Dwe
Message 1 of 8
Hans_Dwe
Hello everyone,
I would like to ask how it would be possible to open the file or multiple files from the Autodesk document in Revit via Revit API. I tried to use the OpenAndActiveDocument Method for a local file and it worked,  so I would like to ask if this method works then how to get the Cloudfile path? How to get the File Path in the AutodeskDoc?
here is a sample
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
using Autodesk.Revit.Attributes;
using System;
namespace OpenAutodeskDocFiles
[Transaction(TransactionMode.Manual)]
[Regeneration(RegenerationOption.Manual)]
public class Class1 : IExternalCommand
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
UIApplication uiApp = commandData.Application;
string filePath = @Anonymous;
try
UIDocument uiDoc = uiApp.OpenAndActivateDocument(filePath);
TaskDialog.Show("Document Activated", "Successfully activated: " + uiDoc.Document.Title);
catch (Exception ex)
TaskDialog.Show("Error", "Failed to open and activate document: " + filePath + "\n" + ex.Message);
return Result.Failed;
return Result.Succeeded;
thanks
Replies (7)
Message 2 of 8
Mohamed_Arshad
HI @Hans_Dwe
    OpenDocumentFile Method  will open the document in hidden mode, we can't able to see the documents. To see the document we need to use OpenAndActivateDocument() method.
Reference Code
            Application app = uiApp.Application;
                string cloudPath = @" ";
                try
                    ModelPath modelPath = ModelPathUtils.ConvertUserVisiblePathToModelPath(cloudPath);
                    OpenOptions openOptions = new OpenOptions();
                    UIDocument uiDoc = uiApp.OpenAndActivateDocument(modelPath, openOptions,false);
                    ///Opened File Document
                    Document doc = uiDoc.Document;
                    TaskDialog.Show("Document Opened", "Successfully opened: " + doc.Title);
                    TaskDialog.Show("Error", "Failed to open document: " + cloudPath + "\n" + ex.Message);
Hope this will Helps 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
Message 3 of 8
Hans_Dwe
@Mohamed_Arshad thanks for the answer, this is exactly what i am looking for, but how i can obtain the AutodeskDoc file path ?
Message 4 of 8
Mohamed_Arshad
HI @Hans_Dwe
    You can check the below post, I think it is not possible through Revit API we need to use Forge API.
https://thebuildingcoder.typepad.com/blog/2020/04/revit-2021-cloud-model-api.html#4.4
Mohamed Arshad K
Message 5 of 8
Hans_Dwe
Hi again, so the Path Name when i snoop the active view via LookUp Revit is not what I should look for ?
Message 6 of 8
Mohamed_Arshad
To Open the Cloud Model, You need to register the Forge API (Design Automation API). Kindly read the below post
https://thebuildingcoder.typepad.com/blog/2020/04/revit-2021-cloud-model-api.html#4.4:~:text=To%20co...
Mohamed Arshad K
Message 7 of 8
Hans_Dwe
Okay, thanks i will check it out .
Message 8 of 8
Hans_Dwe
yes it worked according to your suggestion, thanks a lot @Mohamed_Arshad
