WSM for my Revit 2019.2 does not display the workshared model properly or not at all - see attachment.
It has kind of gone wors over an period but now it has stopped completly to show anything.
What to do??
Solved by jeremytammik. Go to Solution.
Is this a Revit API issue, or an end user question?
Are you doing anything programmatically yourself, or just using the standard Revit user interface?
If you are not doing anything programmatically, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Hi Jeremy - U are probaly right :)! I'm sorry, but I was submitting in a hurry and the menu "slipped" and selected the wrong Forum before Posting.
Have a nice day!
