Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Worksets
Worksets
russ.green
Message 1 of 12
Worksets
russ.green
Are there any ways I might be able to create worksets for new models beyond the first 2 when using EnableWorksharing?
Russ Green
Replies (11)
Message 2 of 12
russ.green
Ah..
Workset.Create(m_Doc, name)
Don't know what that too me so long to find.
Russ Green
Message 3 of 12
rosalesduquej
Hi Russ,
Is this working for you ? or do you still need help from us ?
Jaime Rosales D.
Sr. Developer Consultant
Twitter | AEC ADN DevBlog
Message 4 of 12
russ.green
Yeah that solved it for me thanks
Russ Green
Message 5 of 12
Ning_Zhou
is it only available in R2? i'm using 2015
Message 6 of 12
russ.green
Not sure.  I do have R2 installed so could be.
I'm using it like this. where m_Doc is the current document
    CreateWorkset("workset name here")
    Private Sub CreateWorkset(name As String)
        Using t As New Transaction(m_Doc, "Create Workset")
            If t.Start Then
                t.Commit()
            End If
        End Using
    End Sub
Russ Green
Message 7 of 12
Ning_Zhou
thanks russ, i'm downloading SDK R2 now, hopefully it can also be used in Revit 2015 UR4
Message 8 of 12
jeremytammik
Hi Ning.
Can it?
Cf.
http://forums.autodesk.com/t5/revit-api/r2-vs-ur4/td-p/5382029
Thank you!
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Message 9 of 12
Ning_Zhou
hi Jeremy, well, cannot for sure unless i installed R2, SDK R2 only confirm that method is not available in UR4, thanks.
Message 10 of 12
Dale.Bartlett
I have yet to start porting to 2015, and this topic has caught my attention. It is a troubling turn of events if different sub-flavours of Revit (R2 vs UR4) have different API capability. For the moment, can someone please confirm whether Workset.Create is available in standard Revit 2015? Or only in UP4? Or only in R2? Many thanks, Dale
______________
Yes, I'm Satoshi.
Message 11 of 12
jeremytammik
Afaik, only Revit 2015 R2.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 12 of 12
Dale.Bartlett
Thanks Jeremy,
I have taken the discussion over to:
http://forums.autodesk.com/t5/revit-api/r2-vs-ur4/m-p/5439929#M8067
Regards, Dale
______________
Yes, I'm Satoshi.
