Message 1 of 1
Wire Change End Offset
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Fam,
Does anyone know if there is a way to access or replicate the Wire Change End Offset functionality via the API? When creating a wire, end points have a vertex and a small, non visible bubble like other annotative elements whereby you can adjust the element, in this case the offset of the end of a wire away from the vertex.
I am aware the API has Wire methods to both get and set a vertex, however, I couldn't find one for the offset element. Anyone have any insight? Thanks.
-- The reasoning behind needing this is because the vertex is set to an element connector which I want to keep intact however there are times I need to visually move the wire end away from the vertex without moving the vertex itself.
