why is the coordinate different in dxf which I export and in revit?
27925916
27925916
I use the codes to export dwg in revit to dxf file,but the coordinate is not the same between dxf and revit?
            string DXF_Folder = "G:\\";
            string DXF_File = "tmpdxf";
            List<ElementId> list = new List<ElementId>();
            list.Add(app.ActiveUIDocument.ActiveGraphicalView.Id);
            doc.Export(DXF_Folder, DXF_File, list, DXFoptions);
I try a test to pick a line in revit and find it's coordinate is different with the one in my exported dxf.  And I find the revit's own function of exporting dxf could make the coordinate same between in dxf and in revit.
is any suggestion to my code for exporting dxf? thanks much..
matthew_taylor
Hi @27925916,
Have you tried modifying the SharedCoords property of DxfExportOptions? http://www.revitapidocs.com/2017.1/1a291c40-65d6-cae1-a69c-e60ef026645a.htm
The TargetUnit property may have bearing also.
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
