How to control Revit properties visibility
vargheselukose
Observer Observer
vargheselukose
Observer
Observer
I am wondering whether we can handle or control the properties in the Revit model file, while viewing it using a webGL supported viewer.
More specifically, if we select a single model element in Revit, it's full properties like width, depth, assembly code, model, manufacturer, cost etc. will be seen in the properties tab. I wish to show properties for some specific requirement like, width, model, cost only in the webGL supported viewer. How to make it possible
Kindly share ur ideas to resolve this requirement ASAP.
jeremytammik
Dear Vargheselukose,
Thank you for your query.
You wish to view the Revit model in a stand-alone web viewer and have access to all the element properties?
You should take a look at the Forge platform:
https://autodesk-forge.github.io
That enables exactly what you are asking for.
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
vargheselukose
Observer
Observer
Dear Jeremy,
Thanks for your kind support.
Varghese Lukose
