Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Why does GroupType.Groups contain ungrouped groups?
stefanome
Message 1 of 11
stefanome
The following code prints the same number twice:
var groupType = group.GroupType;
Debug.Print(groupType.Groups.Size.ToString());
group.UngroupMembers();
Is this the correct behavior?
What do I need to do to make sure groupType.Groups always returns the correct GroupSet?
Replies (10)
Message 2 of 11
jeremy_tammik
Regenerate the model?
https://thebuildingcoder.typepad.com/blog/about-the-author.html#5.33
Message 3 of 11
stefanome
Thanks for the tip, but I just tried and regenerating doesn't help.
It looks like I need to end and restart the transaction.
This code shows that GroupType.Groups still reports the ungrouped group after doc.Regenerate() and finally disappears after committing and restarting a new transaction. I tried to get a new reference to the GroupType, hoping that avoiding some caching would help, but it didn't:
tx.Start("Test 1");
var elementIds = new List<ElementId>
    Utils.CreateModelLine(new XYZ(0, 0, 0), new XYZ(1, 0, 0), doc).Id,
    Utils.CreateModelLine(new XYZ(0, 1, 0), new XYZ(1, 1, 0), doc).Id,
    Utils.CreateModelLine(new XYZ(0, 2, 0), new XYZ(1, 2, 0), doc).Id,
var group1 = doc.Create.NewGroup(elementIds);
var group2 = doc.Create.PlaceGroup(new XYZ(0, 5, 0), group1.GroupType);
var group3 = doc.Create.PlaceGroup(new XYZ(0, 10, 0), group1.GroupType);
Debug.Print(group1.GroupType.Groups.Size.ToString());
group2.UngroupMembers();
doc.Regenerate();
var groupType = new FilteredElementCollector(doc)
    .OfClass(typeof(GroupType))
    .Cast<GroupType>()
    .FirstOrDefault(gt => gt.Name == group1.GroupType.Name);
tx.Commit();
tx.Start("Test 2");
    .Cast<GroupType>()
tx.Commit();
I tried using a SubTransaction, but didn't help.
At this point I do have a workaround, but I don't like to create transactions only because I can't rely on GroupType.Groups not reporting ungrouped groups.
Any advice?
Message 4 of 11
jeremy_tammik
Glad to hear you were able to discover a workaround.
Yes, committing the transaction is the next level up after regeneration.
Sorry I cannot offer any further suggestions, though.
Message 5 of 11
GaryOrrMBI
"I tried using a SubTransaction, but didn't help.
At this point I do have a workaround, but I don't like to create transactions only because I can't rely on GroupType.Groups not reporting ungrouped groups."
Just firing off the top of my head here but... instead of transactions and subtransactions you might try a transaction group with transactions within it... works just a little differently and perhaps that difference will be a little cleaner in the end...
Just my Two cents, take it for what it's worth 😉
-G
Gary J. Orr
GaryOrrMBI (MBI Companies 2014-Current)
aka (past user names):
Gary_J_Orr (GOMO Stuff 2008-2014);
OrrG (Forum Studio 2005-2008);
Gary J. Orr (LHB Inc 2002-2005);
Orr, Gary J. (Gossen Livingston 1997-2002)
Message 6 of 11
stefanome
Using a transaction group seem to be the best workaround. Here are the steps:
transactionGroup.Start
transaction.Start
group.UngroupMemebers
group.GroupType.Groups still contains the ungrouped group
transaction.Commit
group.GroupType.Groups does not contain the ungrouped group
Unfortunately such a workaround cannot be used in a generic case, because wrapping the group.UngroupMembers inside its own transaction only because any following groupType.Groups would return the wrong result is ugly, because it requires any caller to use a transaction group rather than a transaction.
Message 7 of 11
mhannonQ65N2
I recently had a somewhat similar problem (working w/ completely different objects though). It seems like in some cases the value returned by a Revit API object's property or method is always the same as when it was first obtained from the API, even after regenerating the model. To resolve this in my case I had to obtain a new copy of the object from the API after regenerating the model (e.g. myElement = myDocument.GetElement(myElementId);). I don't know if this will help in your situation but I hope it does.
Message 8 of 11
stefanome
Thanks for the advice. I just tried and in this stale case the cached info sticks around even after getting a new element. Adding these two lines before closing the transaction to my code, still return the wrong value:
group1 = doc.GetElement(group1.Id) as Group;
groupType=doc.GetElement(group1.GroupType.Id)as GroupType;
Message 9 of 11
mhannonQ65N2
Did you regenerate the model before getting the new element?
Message 10 of 11
stefanome
Yes, as suggested by Jeremy, but didn't help.
Message 11 of 11
jeremy_tammik
