Where can I find all the parameters in revit?
Hi all,
I am researching the possibility to do a dutch energy analysis in Revit. For this I need to find all the parameters needed for this analysis in Revit.
Where can I find all the parameters that are by default in Revit.
Thanks y'all!
HermanSolomon
If you want to focus specifically on the default energy parameter types in Revit, you can have a look at this link. For detailed energy analysis, some customised parameters, schedules, calculated values etc will have to be used
http://revitrecess.blogspot.com/
I want to know all the parameters because this analysis requires a lot of different parameters not just the energy parameters. I found an excel sheet named CategoryParameters with parameters that are used in a project. What I want to know is if there is some list of default parameters that are standard in a Revit project so I can match them to the required parameters for this analysis.
Maybe there is another way to look at this problem. There is software that calculates this but it works outside of Revit, so you have to enter all the data in another software program. I research if it is possible to do this analysis within Revit beacause all the data is or can be added to the model. It works like this:BIM->DATA(Parameters)->Calculation->Result. The step between DATA and calculation is now performed manually, but with BIM it is possible to perform it automatically.
jeremytammik
There is no way to know all parameters in Revit in advance, because any user can add any parameters they like, and that is exactly what people do.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
