License Type
License Type
Dale.Bartlett
License Type
Dale.Bartlett
Hi All, I am using InfoCenterService.ProductSerialNumber to return the serial number, but how can I determine the License type (Network/Standalone)? All help appreciated. Dale
______________
Yes, I'm Satoshi.
jeremytammik
Dear Dale,
No idea whether the following helps you in any way:
C:\Program Files\Autodesk\Revit 2015>cat License.ini
[Assignments]
ProductLineID=RVT
MajorRelease=2015
SubRelease=0
MinorRelease=0
ReleaseType=F
FeatureId=
ProductKey=766G1
DefaultProductKey=829G1
FeatureName=Revit_2015
Furthermore, I have the following to offer you:
http://thebuildingcoder.typepad.com/blog/2013/01/determine-revit-demo-mode-and-serial-number.html
https://github.com/jeremytammik/the_building_coder_samples/blob/master/BuildingCoder/BuildingCoder/C...
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Dale.Bartlett
Hi Jeremy,
Thanks for the reply. This information is mostly available via InfoCenterService as per your blog, but need to determine is whether Revit is running as a standalone or network licence. Regards, Dale
______________
Yes, I'm Satoshi.
Dale.Bartlett
bump...
______________
Yes, I'm Satoshi.
mikako_harada
Hi Dale,
How about checking the windows system registory?  I see under
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Revit\2016\REVIT-05:0409
There is InstallationType, and InstallationTypeTxt saved.
Mikako Harada
Dale.Bartlett
Hi Mikako, Thanks, that is a good suggestion. Because corporate systems are locked down, I need to test that this information is accessible via the addin. Regards, Dale
______________
Yes, I'm Satoshi.
Dale.Bartlett
I'd say you are right Makako. I was looking in the wrong direction. Thanks, Dale
http://spiderinnet.typepad.com/blog/2011/09/deploy-install-the-registry-of-revit-2012.html
// InstallationLocation C:\Program Files\Autodesk\Revit Architecture 2012\
// InstallationType standalone
// Language English
// ProductName Autodesk Revit Architecture 2012
// SerialNumber 000-00000000
// Version 2012 (11.03.09231)
______________
Yes, I'm Satoshi.
