Every time I create a Callout it automatically is created as a plan system family when it should be created as a detail.
So I need to manually chose inside the properties menu the correct system family.
So the next time I need to create a new callout it is created correctly.
But, when I need to create a section, it stays as it was a Callout.
So I need to manually change the properties and tell Revit it is a Section.
And when I need a callout again, it shows as a section, and go on.
Can anybody help me fix this?
Solved by jeremy_tammik. Go to Solution.
Afaict, you are not doing anything programmatically yourself using the Revit API, just using the standard Revit user interface.
In that case, I am afraid this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
So, you cannot expect an answer to a question such as yours relating to product setup, optimisation, usage or other end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
The people there are much better equipped to address this topic than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Best regards,
Jeremy
