When does Revit use GPU and when does it use CPU? and how do the Computer RAMS relate to Revit performance?
Hello guys,
Can anyone add in and explain in which tasks does Revit use GPU and when does it use CPU? and how do the Computer RAMS relate to Revit performance?
jeremy_tammik
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to system requirements, installation, product setup, optimisation, usage or other end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
