Hi forum,
I have been working with Revit since half a year and see that sometimes it would be handy to do thing programatically.
the question is where to start and what language to learn.
I have experience with C, C++( only with Qt framework), javascript, PHP and very little python.
Unfortunately i do not know .NET at all.
I have been playing with dynamo an see big potential with it due to the new dynamo player. The custom nodes seem promising. This would make me choose python. But is the Python used in Revit the same as the usual Python? Are there any limitations so i better choose another language?
What do you think? what is your background and how did you start?
thanks a lot
Jeff
Solved by matthew_taylor. Go to Solution.
Solved by Troy_Gates. Go to Solution.
Solved by GonçaloFeio1321. Go to Solution.
While working in Dynamo you use DesignScript in code blocks. If you want to create custom nodes you can use C# (as well as other .NET languages and Python).
Thanks Jeff, you also!
