what are possible ways and best way for automation in Revit18 ?
I need to automate many tasks in Revit like generating drawing sheets, auto-dimensioning and other repetitive tasks. I am working in precast concrete. I want to generate drawing sheets for each and every element separately like beam, columns, wall panels, etc. Can someone tell me how to do this? I am a proficient python programmer. I can work in C# too.
Accepted solutions (4)
Difficult to say, that's up to you. WIth python you can make scripts (macros) in Revit. Just google "revit python".
You can also take a look at dynamo or you can download the revit sdk and start with c#.
All 3 options should be able to create sheets. automatically place dimensions is a pain (just like manually), so if the emphassys is on dimensions, I should say go with the c# Revit API approach. Then again, I'm not a python expert, so likely someone else here has another opinion.
Arciviz
please find attachment. Wish You all the best.
Arciviz
Arciviz
I am also in the proceeds on rebar for all RCC Element
5da2f71c6a5f4d78793f8f64dfb66ef1-20-18270408.jpgThis is the best reply. 🙂 🙂
Arciviz
Thanks for you replay.
Need any Help use my Mail Id: arch.buildtech@gmail.com
