We need some help about hardware configuration for REVIT 2018
Hi everyone,
We are starting a new project and we'll work on REVIT 2018.
We need to build #10 HP Workstations with Nvidia Quadro Graphic Cards but we have some questions about that. So:
Question 1:
- For raytrace, Revit uses processor to render.
So wich is the best processor to build on our workstations?
We have this options from HP :
https://store.hp.com/us/en/ConfigureView?catalogId=10051&langId=-1&storeId=10151&urlLangId=&catEntry...
Can somebody help us?
Question 2:
We think that Nvidia P5000 is enough to work on our workstations. But if you have a better idea, keep us in touch.
Question 3:
About RAM,  which are the best option to put inside our workstations?
We will appreciate any help.
Thank you Autodesk Team
jeremytammik
Hi.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Hi Jeremy,
Thank you for your help and sorry the misunderstood.
