Hello! I have warning after creation NewFamilyInstance
"Mass contains only mesh geometry, which can’t be used to compute Mass Floors, volume, or surface area."
document.Create.NewFamilyInstance(New XYZ(0, 0, 0), fs, aw, [Structure].StructuralType.UnknownFraming)
fs -family symbol
aw-view
But when I create instance from same family in Revit (not programmatically) then I have not the warning.
What can I do for the warning not show?
Solved by naveen.kumar.t. Go to Solution.
HI @AndrewButenko,
Are you searching for the code to deleting the warning messages when it appear??
see the below links
Handling failures from IFailuresPreprocessor
