Wall wrapping layer geometry
Message 1 of 12
Hi!
I'm currently working with Revit Wall layers and trying to get the geometry information from each layer. I found a solution on Jeremy's blog using PartUtils.GetAssociatedParts() to solve the problem: http://thebuildingcoder.typepad.com/blog/2011/10/retrieving-detailed-wall-layer-geometry.html
This approach works great for layers without wrapping and joint walls, but it fails to detect the wrapping part.
I attached the wall with layers named WrappingLayerWall.png, and the result using Create Parts Tool in Revit (same as the PartUtils APIšŸ˜ž CreateParts.png in attachments.
In this case I have no way to tell if or where the layers are wrapped since it fails to return the wrapping information.
Is there any way that we can separate the wall by different materials?  Otherwise do you have any suggestions on retrieving wrapping layer geometry?
Thanks!
Best,
Siwan
Replies (11)
Message 2 of 12
jeremytammik
If you simply call Element.GetGeometry in a default 3D view, I would expect you to receive a different solid with a different material for each of the wall layers.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Message 3 of 12
Hi Jeremy,
Thanks for your suggestion. I have tried to get geometry from multi-layer wall using the following code but it only returns one solid instead of solid of each layer.
Snippet
public List<solid> getElementSolid(Element elem)
List
<Solid> solidsFound = new List<Solid>();
            Options options = new Options()             {                 ComputeReferences = false,                 DetailLevel = ViewDetailLevel.Fine,                 IncludeNonVisibleObjects = false             };             // get the solid geometry from the element             GeometryElement baseGeomElem = elem.get_Geometry(options);             foreach (GeometryObject geomObj in baseGeomElem)             {                 Solid solid = geomObj as Solid;                 if (solid != null && solid.Faces.Size != 0 && solid.Edges.Size != 0)                 {                     solidsFound.Add(solid);                 }             }
return solidsFound;
also tried to do the Geometry calculation for each layer using WallType.GetCompoundStructure(), however material only provides us the area and volume, layer only provides width, which is apparently not sufficient since I need to get the detailed vertexes of each layer.
Do you have any suggestion on getting that information?
Thanks!
Siwan
Message 4 of 12
Another question is how do I get materials from a solid?
I tried to get material Ids from Element, but even though I get the materials for each layer those information still not enough for me to get the vertexes/outline of each layer including the wrapping part.
Message 5 of 12
jeremytammik
I thought the blog post you pointed to answered exactly the question you are asking on retrieving detailed wall layer geometry:
To determine the material of a solid, checking out this 8 year old blog post:
http://thebuildingcoder.typepad.com/blog/2009/11/solid-material.html
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 6 of 12
Hey Jeremy,
I think I didn't describe my question clear enough.
The approach we mentioned works great for joint walls, but I don't think it works for wrapping layers in a single wall panel.
The PartUtils.GetAssociatedParts() will separate wrapping layers into straight layers.
I'm not sure if it's the same in previous API versions but at least in Revit API 2016 and 2017 it behaves like this:
PartUtils.GetAssociatedParts() will get the wrapping layers into straight layers:
So is there any way for us to retrieve the points highlighted in red for wrapping layers?
Thanks a lot for helping!
Best,
Siwan
Message 7 of 12
jeremytammik
Yes, that is easy.
Those points can be determined by looking at the wall location line, offset from the location line, and thickness of each of its layers.
Simply imagine lines along each layer boundary and calculate their respective intersection points.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 8 of 12
Oh right that sounds good, and we can determine if the layer is being wrapped by checking layerCapFlag parameter.
Thanks again Jeremy.
Message 9 of 12
FAIR59
I don't think you can determine how far the layers get wrapped that way. For Windows / Doors that value is determined by the named reference plane " Int Wrap Plane "and Ext Wrap Plane", it need not be half the wall width.
The layer information in the model seems to be only a "2D hatch" applied to the cutplane of the wall. That 2D information isn't available in the regular API.
Given that the information gets exported to DXF/DWG, you could try retrieving the info from a CustomExporter, though I haven't tried that yet.
Or you could isolate the wall in a plan view and export to DXF, and try and read the DXF file for the line information.
Message 10 of 12
Hi Fair59,
Thanks for your reply. I though the wall wrapping layer part always has the same thickness as the layer itself. (highlighted in red)
If I only need to work with wall panels, flat slabs, not window/door, will the two thicknesses highlighted in red the same?
Thanks!
Siwan
Message 11 of 12
FAIR59
Wrapping is indeed always with the thickness of the layers.
I was commenting on the other axis. With inserts can the wrapping stop before the Finish Face Interior. ( added black line).  Your picture looks like wrapping at the end of the Wall, then the thicknesses will be the same and stops at the inside face of the wall.
For your information:
The "wrap layers" may be cut by the inserts, resulting in irregular shaped faces. In the next picture the outer wrap layer is shorter and the cavity wrap layer gets "squeezed".
Message 12 of 12
Oh I see what you're getting at. That's a interesting situation to consider.
I'll try out your suggestion for this. Thanks!
