Wall Set Top Constraint Parameter.
Hi API Community,
I've created a wall through the API it set the Top Constraint to Unconnected.  I'd like to set the Top Constraint parameter to a level and remove the Unconnected Height.  Is this possible?   I haven't had any luck with my method.
public void CreateWall(Document doc, ObjWalls LinkedWall)
            MyLibrary lib = new MyLibrary();
            LocationCurve locationCurve = LinkedWall.WallCurve;
            List<Level> levels = lib.GetLevels(doc);
            Level BaseLevel = levels.Find(l => l.Name == LinkedWall.BaseConstraint);
            Level TopLevel = levels.Find(l => l.Name == LinkedWall.TopConstranit);
            XYZ startPoint = LinkedWall.startPoint;
            XYZ endPoint = LinkedWall.EndPoint;
            Line line = Line.CreateBound(startPoint, endPoint);
            Transaction t = new Transaction(doc);
            t.Start("Create Wall");
            try
                Wall wall = Wall.Create(doc, line, BaseLevel.Id, true);
                Parameter parm = wall.LookupParameter("Top Constraint");
                parm.Set(TopLevel.Name);
            catch { }
            t.Commit();
Hey Danny,
you can set the top of the wall to a level you want, with
Parameter p = wall.get_Parameter(BuiltInParameter.WALL_HEIGHT_TYPE);
if (null != p)
    p .Set(level.Id);
Hope this helps.
Christian
Thank you.  I've been looking for some time and trying all sorts of things that didn't work.  This is perfect.
You are welcome and I hope you enjoy your coffee.
